Home » Eclipse Projects » Rich Client Platform (RCP) » RCP export for mac os
RCP export for mac os [message #870310] Mon, 07 May 2012 11:52 Go to next message
I have made an RCP application. I want to export the product for mac os. I have downloaded delta pack. I have updated target platform.
Now there are 2 two problems.
1 - if i select "The product includes native launcher" then i get error "Unable to find plugin org.eclipse.equinox.launcher".
2 - if i do not select "The product includes native launcher" then export works fine and it create folders for selected platforms. Now in windows OS folder there is no .exe file. So i created batch file with following command
java -Xss10m -Xms256m -Xmx1400m -jar plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
it works peferfectly but when i create .sh file for mac folder then i get following errors shown in log file
org.osgi.framework.BundleException: The activator org.eclipse.ui.internal.WorkbenchPlugin for bundle org.eclipse.ui.workbench is invalid
Do you have any idea why it happens.
cheers,
Re: RCP export for mac os [message #871241 is a reply to message #870310] Fri, 11 May 2012 10:57 Go to previous messageGo to next message
I have downloaded the delta pack of same version as Eclipse SDK and it is exporting now without any errors, but when i see the folders created then there is no .exe file for windows os and no .app file for mac os.
Any idea?
Re: RCP export for mac os [message #871284 is a reply to message #871241] Fri, 11 May 2012 14:35 Go to previous messageGo to next message
Did you restore the "uses native launcher" flag?
Re: RCP export for mac os [message #871377 is a reply to message #871284] Sat, 12 May 2012 15:43 Go to previous messageGo to next message
Actually it is fixed now, the problem was quite strange. I deleted the existing product file and created new one and now folders does contain executables but now when i run the exe file i get the following execption.
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
Any idea what is going wrong?
Re: RCP export for mac os [message #871378 is a reply to message #871377] Sat, 12 May 2012 17:21 Go to previous messageGo to next message
I have been trying different thing, i have read to include org.eclipse.core.runtime with level 2 to resolve the problem and i did so, but now i am getting the following exception saying that system is unable to find the application class for my plugin.
org.eclipse.core.runtime.CoreException: Plug-in test.abc.application.main was unable to load class test.abc.application.main.Application.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
please guide me solving this.
regards,
Re: RCP export for mac os [message #871398 is a reply to message #871378] Sun, 13 May 2012 04:59 Go to previous messageGo to next message
And what's your OS? If same as you're exporting from try to switch to
"running platform" target in Preferences / PDE / Target Platform. Then
export and try it again. Most of such problems origins in uncomplete
target or run configuration.
Libor
On 05/12/2012 11:21 PM, ModelGeek Mising name wrote:
> at
> at
> at
> at
> at
> regards,
Re: RCP export for mac os [message #871497 is a reply to message #871398] Mon, 14 May 2012 04:49 Go to previous messageGo to next message
I have windows 8(32 bit) and i want to export product for Windows(32, 64) and Mac(32, 64).
Re: RCP export for mac os [message #871509 is a reply to message #871497] Mon, 14 May 2012 05:46 Go to previous messageGo to next message
now even i have tried to use MacOS. I have downloaded the Eclipse for MAC( 10.6.8 ). I have imported project. Now i am not exporting for multipltaform. I am trying to export for same plateform(Mac to Mac).
but still i am gettting
Please guide me how to solve this.
[Updated on: Mon, 14 May 2012 05:46] by Moderator
Re: RCP export for mac os [message #1706511 is a reply to message #871509] Thu, 27 August 2015 08:51 Go to previous message
Hi friend you can you this link http://ugosan.org/eclipse-rcp-delta-pack/
Previous Topic:RCP Perspectives Views and Editors
Next Topic:How to get drop event in Eclipse RCP tableview cell?
Current Time: Sat Jul 19 22:31:45 EDT 2025
Powered by FUDForum. Page generated in 0.03702 seconds
