Old output keeps displaying, till process is ended in task manager [message #1706335] |
Wed, 26 August 2015 00:49  |
Hi there,
I am running Eclipse Version: Mars Release (4.5.0),
Build id: 20150621-1200 for C programming, on Windows 7.
Compiler: mingw32
Every time I make a change in my program, save it, re-build it and run it, the output is still the same.
The only way to run with the changes, is to end the C/C++ Application executable process (Debug/filename.exe) in task manager, and then rebuild and re-run the program.
Any way to make the process restart or make the program take the changes upon re-building?
Also I get the following error:
cannot open output file Deitel.exe: Permission denied
collect2.exe: error: ld returned 1 exit status
Eclipse is running with admin rights.
I have attached the screenshots, before and after restarting the process.
Any suggestions would be greatly appreciated.
Jim
Attachment: Old.PNG
(Size: 59.07KB, Downloaded 1621 times)
Attachment: New.PNG
(Size: 56.81KB, Downloaded 1717 times)
FUDForum. Page generated in 0.03336 seconds
