Home » Modeling » TMF (Xtext) » Invoke index rebuild programmatically
Invoke index rebuild programmatically [message #1705866] Wed, 19 August 2015 11:19 Go to next message
I have the following problem: I have a model transformation written in Xtend that outputs two kinds of model files, say A and B. There is an Xtext editor for both kinds of models. Elements in B models have references to elements in A models. Everything works perfectly when I create and edit the models using the editors. However, when my model transformation creates multiple A and B models with cross references, the Xtext serializer complains that no EObjectDescription could be found in the scope. I presume the reason is, that the Xtext index is not updated in the meantime and, thus, contains no information about the newly generated A models. How can I solve this problem? I tried explicitly invoking a full rebuild on the project that contains the models after the A models have been written so that the Xtext builder could update the index before writing the B models. However, that did not help.
Stephan
Re: Invoke index rebuild programmatically [message #1705869 is a reply to message #1705866] Wed, 19 August 2015 11:56 Go to previous messageGo to next message
Hi Stephan,
I assume you're generating the artifacts for A and B into the same
resource that contains your Xtend file?
Anyway: You should use a fresh resource set and configure the so called
live scope. All new resources need to be put into that resource set.
Saving should work afterwards without any issues.
Please try to inject the XtextLiveScopeResourceSetProvider and obtain
the a new resource set from that one.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Re: Invoke index rebuild programmatically [message #1705944 is a reply to message #1705869] Thu, 20 August 2015 06:18 Go to previous messageGo to next message
Hi Sebastian,
thank you. That works now. However, the performance of the model transformation is severely degraded, from a couple of seconds to about five minutes for a test model. I could improve the performance already considerably by adding the new elements during the transformation to a normal ResourceSetImpl first. After finishing the transformation, all resources are moved to a resource set provided by the XtextLiveScopeResourceSetProvider and then saved. However, saving the B models still takes a considerable amount of time. Are there any possibilities to improve the save performance?
Stephan
Re: Invoke index rebuild programmatically [message #1706027 is a reply to message #1705944] Fri, 21 August 2015 04:11 Go to previous messageGo to next message
You could install ResourceDescriptionsData into the resource set. That
should improve the performance tremendously. See
ResourceDescriptionsData.ResourceSetAdapter.installResourceDescriptionsData(ResourceSet,
ResourceDescriptionsData).
Best,
Sebastian
Twitter: @szarnekow
Re: Invoke index rebuild programmatically [message #1706039 is a reply to message #1706027] Fri, 21 August 2015 06:36 Go to previous message
Thank you. That helped a lot.
Previous Topic:Is it possible to use formatter and formatter2 both in one project
Next Topic:Cannot inject IHyperlinkHelper in junit
Current Time: Sun Jul 20 12:54:11 EDT 2025
Powered by FUDForum. Page generated in 0.04956 seconds
