Home » Eclipse Projects » Sirius » What should I use for UI and user actions?
What should I use for UI and user actions? [message #1705766] Tue, 18 August 2015 20:27 Go to next message
Hello.
During the last a few month, I could get help from this community, so I'm very thankful.
Today, I want to know what I should use for UI and user actions.
What I want to do is to popup a window which user can edit model value and when a button clicked, some functions will be processed after close the popup window.
I searched the alternatives as RCP and EMF Forms.
What is more suitable or are there any options?
Could someone help me?
Thank you in advance.
Best Regards,
Eunjung Park
Re: What should I use for UI and user actions? [message #1706036 is a reply to message #1705766] Fri, 21 August 2015 05:34 Go to previous messageGo to next message
Take a look on this thread which contains a discussion on the
subject.(https://www.eclipse.org/forums/index.php/t/1068744/).
But there is no quick answer or solution for that. You could try the
Sirius EEF integration, here is the documentation:
https://www.eclipse.org/sirius/doc/viewpoint-eef.html.
On 08/19/2015 02:27 AM, eunjung park wrote:
> Hello.
> I'm very thankful.
> the popup window.
> Best Regards,
> Eunjung Park
Florian - Obeo
Re: What should I use for UI and user actions? [message #1706235 is a reply to message #1705766] Tue, 25 August 2015 03:56 Go to previous message
Perhaps dialog from EEF [1] could help you.
[1] https://eclipse.org/eef/
Best Regards.
Le 19/08/2015 02:27, eunjung park a écrit :
> Hello.
> I'm very thankful.
> the popup window.
> Best Regards,
> Eunjung Park
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Previous Topic:uml profile
Next Topic:Using a Java Service in a TreeItemStyleDescription
Current Time: Sun Jul 20 17:11:15 EDT 2025
Powered by FUDForum. Page generated in 0.03408 seconds
