Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Annotation to set EAttribute for no-NULL
[Texo] Annotation to set EAttribute for no-NULL [message #1705605] Mon, 17 August 2015 13:56 Go to next message
How do I set a texo annotation for an EAttribute such that the db will refuse to accept NULL values for the column? The db (and presumably hibernate layer) allow a column/EAttribute to be null by default. I want to set a specific EAttribute/column to not accept null values ever.
I've looked over the options when editing my .annotationsmodel but can't seem to find something that matches the above.
Any help would be most appreciated!
[Updated on: Mon, 17 August 2015 13:57] by Moderator
Re: [Texo] Annotation to set EAttribute for no-NULL [message #1705659 is a reply to message #1705605] Tue, 18 August 2015 04:26 Go to previous messageGo to next message
Hi Mike,
You can use a Basic or Column annotation in the annotations model.
http://stackoverflow.com/questions/5602908/jpa-which-should-i-use-basicoptional-or-columnnullable
I would use Basic annotation for this.
gr. Martin
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Annotation to set EAttribute for no-NULL [message #1705730 is a reply to message #1705659] Tue, 18 August 2015 11:33 Go to previous message
Thanks Martin! That did the trick!
Previous Topic:[EMFForms][CDO] ENumLiterals represented by combobox are not stored correctly
Next Topic:[EMFForms] How to access an EObject whose EStructuralFeature is being edited
Current Time: Sun Jul 20 13:15:36 EDT 2025
Powered by FUDForum. Page generated in 0.04160 seconds
