DI problem with EmbeddedEditor [message #1705018] |
Tue, 11 August 2015 08:59  |
Hi everyone,
I'm building a new DSL from scratch and this is my first time using XText. Until now I've created a language by specifying the grammar, and it works as intended when I start new Eclipse instance. I have not changed anything manually except for the grammar itself. Everything else is generated by the framework.
The next step is to embed this editor in another plugin which is an Eclipse-based editor. Its a sort of graphical editor and on double click on some element I want to open a SWT/JFace dialog in which the DSL statements should be written. And now I have some problems with this part. For a while I'm trying out all these different solutions from old eclipse forum posts, forums, xtextcon presentations, some jface interation plugins with StyledText etc. For each of the tutorials I've tried I come to this error and cannot go past it:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2015-08-11 14:39:23.536
!MESSAGE Internal Error
!STACK 0
com.google.inject.ProvisionException: Guice provision errors:
1) null returned by binding at org.eclipse.xtext.ui.shared.internal.SharedModule.configure(SharedModule.java:132)
but org.eclipse.xtext.ui.editor.GlobalURIEditorOpener.workbench is not @Nullable
while locating org.eclipse.ui.IWorkbench
for field at org.eclipse.xtext.ui.editor.GlobalURIEditorOpener.workbench(Unknown Source)
while locating org.eclipse.xtext.ui.editor.GlobalURIEditorOpener
while locating org.eclipse.xtext.ui.editor.IURIEditorOpener
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:75)
for field at org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider.uriEditorOpener(Unknown Source)
while locating org.eclipse.xtext.ui.editor.hover.html.DefaultEObjectHoverProvider
while locating org.eclipse.xtext.ui.editor.hover.IEObjectHoverProvider
for field at org.eclipse.xtext.ui.editor.XtextInformationProvider.hoverProvider(Unknown Source)
while locating org.eclipse.xtext.ui.editor.XtextInformationProvider
for field at org.eclipse.xtext.ui.editor.XtextSourceViewerConfiguration.informationProvider(Unknown Source)
while locating org.eclipse.xtext.ui.editor.XtextSourceViewerConfiguration
1 error
at com.google.inject.internal.InjectorImpl$4.get(InjectorImpl.java:987)
at org.eclipse.xtext.ui.editor.embedded.EmbeddedEditorFactory$Builder.withParent(EmbeddedEditorFactory.java:200)
at anymap.dialogs.ExpressionDialog.createDialogArea(ExpressionDialog.java:58)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:768)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1096)
at org.eclipse.jface.window.Window.open(Window.java:792)
at anymap.states.SelectionState.openDialog(SelectionState.java:209)
at anymap.states.SelectionState.execute(SelectionState.java:183)
at anymap.listeners.CanvasMouseListener.mouseDoubleClick(CanvasMouseListener.java:43)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:196)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:159)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Here is the code where I try to inject the needed things. This code is based on the most recent code example I could find online.
package anymap.dialogs;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.xtext.resource.FileExtensionProvider;
import org.eclipse.xtext.resource.XtextResource;
import org.eclipse.xtext.ui.editor.embedded.IEditedResourceProvider;
import org.eclipse.xtext.ui.resource.IResourceSetProvider;
import com.google.inject.Inject;
@SuppressWarnings("restriction")
public class FilterResourceProvider implements IEditedResourceProvider {
@Inject
private IResourceSetProvider resourceSetProvider;
@Inject
private FileExtensionProvider ext;
public XtextResource createResource() {
ResourceSet resourceSet = resourceSetProvider.get(null);
URI uri = URI.createURI("example/test1." + ext.getPrimaryFileExtension());
XtextResource result = (XtextResource) resourceSet.createResource(uri);
resourceSet.getResources().add(result);
return result;
import org.eclipse.jface.dialogs.Dialog;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.StyledText;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import org.eclipse.xtext.ui.editor.embedded.EmbeddedEditor;
import org.eclipse.xtext.ui.editor.embedded.EmbeddedEditorFactory;
import org.eclipse.xtext.ui.editor.embedded.EmbeddedEditorModelAccess;
import com.google.inject.Injector;
import anymap.language.assignment.ui.internal.FilterDSLActivator;
public class ExpressionDialog extends Dialog {
public static int ASSIGNMENT = 0;
public static int FILTER = 1;
private Text txtError;
private String value;
private String type;
private StyledText txtExpression;
* Create the dialog.
* @param parentShell
public ExpressionDialog(Shell parentShell, int type, String value) {
super(parentShell);
setShellStyle(SWT.DIALOG_TRIM | SWT.RESIZE);
this.type = (type == ASSIGNMENT) ? "Assignment" : "Filter";
if (value != null) {
this.value = value;
* Create contents of the dialog.
* @param parent
@SuppressWarnings({ "unused", "restriction" })
protected Control createDialogArea(Composite parent) {
Composite container = (Composite) super.createDialogArea(parent);
FilterDSLActivator activator = FilterDSLActivator.getInstance();
Injector injector = activator.getInjector(FilterDSLActivator.ANYMAP_LANGUAGE_ASSIGNMENT_FILTERDSL);
FilterResourceProvider provider = injector.getInstance(FilterResourceProvider.class);
EmbeddedEditorFactory factory = injector.getInstance(EmbeddedEditorFactory.class);
EmbeddedEditor editor = factory.newEditor(provider).withParent(container);
EmbeddedEditorModelAccess model = editor.createPartialEditor();
return container;
* Create contents of the button bar.
* @param parent
protected void createButtonsForButtonBar(Composite parent) {
createButton(parent, IDialogConstants.OK_ID, IDialogConstants.OK_LABEL, true);
createButton(parent, IDialogConstants.CANCEL_ID, IDialogConstants.CANCEL_LABEL, false);
If anyone knows what am I doing wrong, please help. Maybe I've skipped some obvious steps that have to be performed in order for DI to work. I'm new to this so i'm not really sure what to do.
Best Regards,
Vladimir
[Updated on: Tue, 11 August 2015 09:00] by Moderator
FUDForum. Page generated in 0.07305 seconds
