Home » Modeling » TMF (Xtext) » [SOLVED] Disabling DSL metamodel source generation
[SOLVED] Disabling DSL metamodel source generation [message #1704188] Sat, 08 August 2015 06:47 Go to next message
Hi, i'm writing a grammar using Xtext that includes the following rules:
MyList
	  elements+=Element
	| elements+=Element ',' elements+=Element
Element
	name=ID
and i would like to implements the interface Iterable<EObject> to the class MyListImpl that
implements the data type for MyList rule. MyListImpl is automatically generated from Xtext every time I launch the .mwe2 script. However I would like Xtext to prevent from automatically generating and updating MyListImpl class, so I can add custom fields or methods to it and eventually changing the grammar rules without modifying every time the class MyListImpl. Is it possible to do this?
[Updated on: Sun, 09 August 2015 11:00] by Moderator
Re: Disabling DSL metamodel source generation [message #1704193 is a reply to message #1704188] Sat, 08 August 2015 10:16 Go to previous messageGo to next message
i dont know if this is a good idea.
but you can:
- swtich to a manually maintained metamodel (XCore or pure ecore with org.eclipse.emf.mwe2.ecore.EcoreGenerator that supports generation gap)
- use IXtext2EcorePostProcessor to customize the metamodel generation and add derived stuff there (Depending on your usecase)
[Updated on: Sat, 08 August 2015 10:17] by Moderator
Re: Disabling DSL metamodel source generation [message #1704231 is a reply to message #1704193] Sun, 09 August 2015 07:59 Go to previous messageGo to next message
Christian Dietrich wrote on Sat, 08 August 2015 10:16
but you can:
Thank you for your fast response. I think I've found a simple solution:
- Create the grammar EMF metamodel project, and define a metamodel.
- Create an Xtext project using the created metamodel project.
Why to do this? Because I've found much clearer and elegant to separate between the metamodel source code and the grammar/Xtext code (when an external metamodel is used, Xtext projects doesn't contains ecore generated classes). Furthermore, I've found the tag "@generated not" is working into the EMF projects, so that fields and methods can be manually defined: in this way any modification is not lost even when the ecore metamodel needs to be changed.
Re: Disabling DSL metamodel source generation [message #1704232 is a reply to message #1704231] Sun, 09 August 2015 08:22 Go to previous messageGo to next message
this is what i mean with manually maintained metamodel.
Re: Disabling DSL metamodel source generation [message #1704234 is a reply to message #1704232] Sun, 09 August 2015 10:59 Go to previous message
Christian Dietrich wrote on Sun, 09 August 2015 08:22
I got it! Thanks a lot Wink
Previous Topic:MWE failing on referenced Ecore Model
Next Topic:Do we have a way to get the differences between xtext model before and after partial parse?
Current Time: Sat Jul 19 15:46:14 EDT 2025
Powered by FUDForum. Page generated in 0.04742 seconds
