Home » Eclipse Projects » Oomph » How do I make preferences global?
How do I make preferences global? [message #1704005] Thu, 06 August 2015 11:03 Go to next message
This Oomph looks interesting but quite complex! I'm using eclipse for C/C++, and I have a custom code formatting style, and a custom syntax coloring style I use. In previous versions of eclipse I had to export both of those, and then import them in every workspace which is a bit of a pain.
So I imported the .epf and the formatting .xml files in Mars, and when I create a new workspace, my custom settings are not there. I do have the preferences recorder turned on. How do I make my syntax coloring, and code formatting work across workspaces without having to import them each time?
Re: How do I make preferences global? [message #1704069 is a reply to message #1704005] Fri, 07 August 2015 03:20 Go to previous messageGo to next message
Am 06.08.2015 um 23:28 schrieb Moses McKnight:
When the recorder is turned on you need to apply preference changes manually *in the Preferences dialog*. When you press
the Ok button Oomph pops up an extra dialog to ask you whether you want to record or ignore these preferences (now and
in the future). And recorded preferences are automatically applied to existing or new workspaces (unless you selected
the "Skip automatic task execution at startup" preference in Oomph. Did that not happen for you?
Cheers
/Eike
http://www.esc-net.de
Re: How do I make preferences global? [message #1704130 is a reply to message #1704069] Fri, 07 August 2015 10:09 Go to previous messageGo to next message
Yes, it pops up a dialog to ask about recording preferences I changed.
So I take it from your response, that there is not a way to make it save all current workspace preferences globally (or user wide anyhow)?
That would mean that I would need to go through and manually change every preference which I have already saved in my .epf - bascially start from scratch?
Eclipse is the only IDE/editor I've ever used that does not save preferences user wide. It's been a bit of a pain, and I'm glad that is finally changing!
Moses
Re: How do I make preferences global? [message #1704135 is a reply to message #1704130] Fri, 07 August 2015 10:37 Go to previous messageGo to next message
Am 07.08.2015 um 16:09 schrieb Moses McKnight:
I fear that's the case.
Yes, or maybe you find a way to convert from the .epf to the .setup format? Perhaps with XSLT...
Indeed. And we're still looking at improving our improvements as soon as possible ;-)
Cheers
/Eike
Re: How do I make preferences global? [message #1704222 is a reply to message #1704135] Sun, 09 August 2015 02:21 Go to previous message
Moses,
Certainly there are a number of things we might consider adding as
features, e.g., drag and drop of an *.epf file might convert them to
preference tasks. Being able to record preferences into something other
than your user.setup, e.g., a project setup. Some ability to
selectively record the current setting of preferences as preference
tasks, much like the Eclipse's existing preference exporter (which is
very poor at being selective, so one often must literally paw through
the XML to remove unwanted things).
Think about which specific things would be very helpful, open
enhancement requests for them, and consider contributing something
towards those ends.
>> start from scratch?
> as possible ;-)
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Previous Topic:Finding preferences
Next Topic:More Settings for Projects Import Task
Current Time: Sun Jul 20 03:32:23 EDT 2025
Powered by FUDForum. Page generated in 0.56378 seconds
