Home » Eclipse Projects » GEF » How to delete an editpart from the diagram
How to delete an editpart from the diagram [message #170315] Thu, 03 March 2005 10:51 Go to next message
Originally posted by: jsk_lam.hotmail.com
Can someone show me how to delete/remove a node editpart from the
diagram manually/programmatically? I try the following:
Diagram diagram; // Diagram is AbstractGraphicalEditPart-derived class
Node node; // Node is AbstractGraphicalEditPart-derived class
// Error: removedChild(0 is not visible, it is a protected
// method in AbstractGraphicalEditPart.
diagram.removeChild(node);
slam
Re: How to delete an editpart from the diagram [message #170346 is a reply to message #170315] Thu, 03 March 2005 17:23 Go to previous messageGo to next message
Originally posted by: binti.ksu.edu
Slam,
You will need to create an edit policy for this node, that extends component
policy. and implements createDeleteCommand(GroupRequest request). In this
method you will need to instatiate a command that deletes the node. If you
need more help let me know.
This should be available in logic example and schema diagram editor example.
Binti.
"slam" <jsk_lam@hotmail.com> wrote in message
news:d07bqp$a0$1@www.eclipse.org...
> Thanks
> slam
Re: How to delete an editpart from the diagram [message #170362 is a reply to message #170346] Thu, 03 March 2005 17:38 Go to previous message
More importantly, you delete the model, not the editpart. When your model
changes, the corresponding editpart will be automatically removed from the
diagram.
"Binti Sepaha" <binti@ksu.edu> wrote in message
news:d082qc$o4v$1@www.eclipse.org...
> Slam,
component
you
example.
> Binti.
> > Hi,
class
> > Thanks
> > slam
Previous Topic:org.eclipse.ui.PlatformUI
Next Topic:Frame on editor problem
Current Time: Sat Jul 19 19:43:52 EDT 2025
Powered by FUDForum. Page generated in 0.03559 seconds
