Home » Archived » Eclipse Process Manager (Stardust) » JBoss EAP 6.2 and UserService(JBoss EAP 6.2 and UserService)
JBoss EAP 6.2 and UserService [message #1703403] Fri, 31 July 2015 06:23 Go to next message
I am using Stardust 2.1.1, JBoss EAP 6.2 and EJB3 in my EAR.
In my application code, I am making the following call:
workflowService = ServiceFactoryLocator.get(request).getWorkflowService();
I get a error (see attached stacktrace file).
The relevant lines from carnot.properties are
Web.ServiceFactory = org.eclipse.stardust.engine.api.ejb3.EjbEnvServiceFactory
Security.Authentication.Mode = principal
I appreciate any help or suggestions
-Ramakrishnan
  • Attachment: stacktrace
    (Size: 8.86KB, Downloaded 248 times)
Re: JBoss EAP 6.2 and UserService [message #1703625 is a reply to message #1703403] Mon, 03 August 2015 13:43 Go to previous messageGo to next message
Hi Ramakrishnan,
When you say application code, you mean from the Client or still executing this from the engine context?.
Re: JBoss EAP 6.2 and UserService [message #1704013 is a reply to message #1703625] Thu, 06 August 2015 12:31 Go to previous message
Hello Vikram Kodak
I am not using the stardust portal as provided. The application (named xxx-bpm) is packaged as a jar inside ear archive. One of the many wars inside the ear is the"customised" stardust portal/client 2.1.1.
Hence, I presume "engine context" would be correct.
-Ramakrishnan
Previous Topic:Issues while working with SOAP web services (HTTPS)
Next Topic:Deployed models are cached during unit tests
Current Time: Sat Jul 19 19:22:36 EDT 2025
Powered by FUDForum. Page generated in 0.04544 seconds
