emf does not resolve reference on load [message #1703201] |
Wed, 29 July 2015 06:21  |
I have a function where I try to load a m1gen-file and then to resolve the resourceSet to get the referenced ecore-file. After that the target of the instantiators should be available. But they aren't. The line System.out.println("instantiator: " + instantiator.getTarget().getName()); produces every time null value for the name...
@Mojo(name = "generate")
public class GeneratorMojo extends AbstractMojo {
@Parameter
private File m1genFile;
public void execute() throws MojoExecutionException {
List<ClassInstantiator> instantiators = new ArrayList<ClassInstantiator>();
List<Goal> goals = new ArrayList<Goal>();
EPackage.Registry packReg = EPackage.Registry.INSTANCE;
packReg.put(M1genPackage.eNS_URI, M1genPackage.eINSTANCE);
Resource.Factory.Registry fReg = Resource.Factory.Registry.INSTANCE;
Map<String, Object> m = fReg.getExtensionToFactoryMap();
m.put("m1gen", new XMIResourceFactoryImpl());
m.put("ecore", new XMIResourceFactoryImpl());
ResourceSet resSetIn = new ResourceSetImpl();
resSetIn.setPackageRegistry(packReg);
resSetIn.setResourceFactoryRegistry(fReg);
Resource resourceIn = resSetIn.getResource(URI.createURI("file:/" + m1genFile.toString()), true);
try {
resourceIn.load(m);
} catch (IOException e1) {
e1.printStackTrace();
EcoreUtil.resolveAll(resSetIn);
TreeIterator<EObject> instances = resourceIn.getAllContents();
M1GenModel m1gen = (M1GenModel) instances.next();
EPackageImpl ePackage = (EPackageImpl) m1gen.getRefers().get(0);
EObject next = null;
while (instances.hasNext()) {
next = instances.next();
if (next instanceof Goal) {
goals.add((Goal) next);
if (next instanceof ClassInstantiator) {
instantiators.add((ClassInstantiator) next);
for (ClassInstantiator instantiator : instantiators) {
Re: emf does not resolve reference on load [message #1703204 is a reply to message #1703201] |
Wed, 29 July 2015 06:43   |
Clemens,
What value does m1genFile have? Is it an absolute path? Better use use
URI.createFileURI than what you did (because on Linux it will produce
file://path), assuming the path is absolute in the first place. You can
also try casting instantiator.getTarget() to InternalEObject so you can
inspect the eProxyURI of it.
On 29/07/2015 12:21 PM, Clemens Schneider wrote:
> Hello,
> @Parameter
> try {
> resourceIn.load(m);
Re: emf does not resolve reference on load [message #1703205 is a reply to message #1703204] |
Wed, 29 July 2015 07:01  |
Thank you! It works.
I changed it to:
Resource resourceIn = resSetIn.getResource(URI.createFileURI(m1genFile.toString()), true);
m1gen is:
<m1genFile>C:/Users/cschneid/Desktop/workspace-tdg/model/Company.m1gen</m1genFile>
[Updated on: Wed, 29 July 2015 07:03] by Moderator
FUDForum. Page generated in 0.02301 seconds
