Home » Eclipse Projects » RCP Testing Tool » Data Driven using RCPTT(Data Driven using RCPTT)
Data Driven using RCPTT [message #1701961] Fri, 17 July 2015 03:07 Go to next message
I would like to use data driven concept in RCPTT for the below purpose.
I have a test case, where user wants to create multiple projects and project names should be defined in csv and those values should read during script execution.
Could you please help me on this.
Re: Data Driven using RCPTT [message #1701973 is a reply to message #1701961] Fri, 17 July 2015 04:38 Go to previous messageGo to next message
Hi Vinod,
Created a procedure and example test for your interest (see attached).
You can use it as an example.
1) So there is a MyProcedures ECL Script Context where you may find the following procedures:
proc "index-of" [val list -input] [val item] {
$list | each [val elem] [val index] {
if [$elem | eq $item] { $index }
} | to-list | get 0 [int "-1"]
proc "get-value" [val table] [val columnName] [val rowNumber] {
let [val columnIndex [$table | get columns | to-list | index-of $columnName]] {
$table | get rows | to-list
  | get $rowNumber | get values | to-list
  | get $columnIndex
2) And the TestCase with this ECL Script Context added:
//set initial index value for foreach loop
global [val -name indx -value  0]
//please replace file uri here
let [val table [read-csv-file "file:///Users/Ulik_MacAir/Desktop/ccc.csv"]] {
//..and here
read-csv-file "file:///Users/Ulik_MacAir/Desktop/ccc.csv" | get rows | foreach {
//here you can do anything you wish, e.g. create a new Project with a key name instead of logging it
get-value $table "Name" $indx | log
//increasing index value +1
global [val indx [$indx | plus 1]] -override
3) ccc.csv file attached as well.
I hope it will be helpful.
Kind regards,
Ulyana.
  • Attachment: DataDriven.test
    (Size: 2.44KB, Downloaded 132 times)
  • Attachment: ccc.csv
    (Size: 0.06KB, Downloaded 138 times)
Re: Data Driven using RCPTT [message #1702008 is a reply to message #1701973] Fri, 17 July 2015 08:22 Go to previous messageGo to next message
The below is the script which I am using. For the below script I want to pass different project names through csv file.
Expected : Would like to pass different project names and like to create multiple projects.
Please provide the script ASAP.
get-menu "File/New/Project..." | click
with [get-window "New Project"] {
get-tree | select "General/Project"
get-button "Next >" | click
with [get-editbox -after [get-label "Project name:"]] {
set-text testproject
get-button Finish | click
[Updated on: Tue, 21 July 2015 00:52] by Moderator
Re: Data Driven using RCPTT [message #1702561 is a reply to message #1702008] Thu, 23 July 2015 04:57 Go to previous messageGo to next message
Please provide the soultion
Re: Data Driven using RCPTT [message #1702719 is a reply to message #1702561] Fri, 24 July 2015 05:35 Go to previous messageGo to next message
In the following snippet it is needed to change path to the csv-file:
read-lines [uri-from-path "C:/Users/olga/Downloads/ccc.csv"] | foreach [val testproject]{
set-text $testproject
Please take a look and let me know if you have any questions.
Re: Data Driven using RCPTT [message #1702801 is a reply to message #1702719] Fri, 24 July 2015 13:24 Go to previous messageGo to next message
Hi Olga,
Thanks for the reply and it is working as expected Smile. Thank you very much.
I have one more clarification in continuation to my previous question.
Please see the below script. In this script, it has two wizards. One is Project creation wizard and Second one is Data model creation wizard. I have a test case first I have to create project and under the project I have to create a data model. Using single csv file, can I pass two different values to two different wizard.
Sample csv data file:
PN1,DM1
PN2,DM2
PN3,DM3
get-menu "File/New/Project" | click
get-editbox -after [get-label "Project File Name"] | set-text PN
get-view "Package Explorer" | get-tree | select PN | get-menu "New/Data Model" | click
with [get-window "New Data Model"] {
get-editbox -index 5 | set-text DM
Please provide the solution ASAP. Waiting for your early reply.
Vinod
Re: Data Driven using RCPTT [message #1703027 is a reply to message #1702801] Tue, 28 July 2015 02:49 Go to previous messageGo to next message
Could you please update me for my question with resolution.
Vinod
Re: Data Driven using RCPTT [message #1703163 is a reply to message #1703027] Wed, 29 July 2015 01:35 Go to previous messageGo to next message
Using Ulyana's script I've made the following snippet:
			$index
		$table | get rows | to-list | get $rowNumber | get values | to-list | get $columnIndex
let [val table [read-csv-file[uri-from-path "/Users/olgayurchuk/Downloads/test.csv"]]] {
//..and here
$table | get rows | foreach [val item] {
get-view "Test Explorer" | get-tree | get-menu "New/Project..." | click
    get-tree | select "RCP Testing Tool/RCP Testing Tool Project"
    get-editbox -after [get-label "Project name:"] | set-text [get-value $table name1 $indx]
//here you can create files in your project
get-view "Test Explorer" | get-tree | select [get-value $table name1 $indx] | get-menu "New/Test Case" | click
with [get-window "New Test Case"] {
    get-editbox -after [get-label "Name:"] | set-text [get-value $table name2 $indx]
In my csv file name1 and name2 are column headers.
Please let me know if this construction is suitable for you.
[Updated on: Wed, 29 July 2015 01:36] by Moderator
Re: Data Driven using RCPTT [message #1703173 is a reply to message #1703163] Wed, 29 July 2015 03:02 Go to previous message
Its working as expected.
Thank you very much for providing required solution Smile
Previous Topic:running RCPTT during development
Next Topic:Excessive memory consumption in Test Runner
Current Time: Sun Jul 20 12:35:44 EDT 2025
Powered by FUDForum. Page generated in 0.03210 seconds
