Home » Eclipse Projects » RCP Testing Tool » Is RCPTT work with indigo version(RCPTT with Indigo)
Is RCPTT work with indigo version [message #1701039] Wed, 08 July 2015 16:44 Go to next message
When i try to add AUT as eclipse version 3.7.2 from IDE then its not able to detect AUT. Throwing error as "Directory "<Eclipse Installtion home>\plugins" does not exist"
Has any one faced this issue.
Also when i try to lauch it from the RCPTT Runner 2.0 it throwing following error
"!ENTRY org.eclipse.jdt.launching.macosx 4 0 2015-07-08 13:24:52.931
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.macosx [103]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.os=macosx)"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.jdt.launching.ui.macosx 4 0 2015-07-08 13:24:55.103
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.ui.macosx [246]
!ENTRY org.eclipse.emf.workspace.ui 4 0 2015-07-08 13:24:55.117
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.workspace.ui [307]
Unresolved requirement: Require-Bundle: org.eclipse.emf.edit.ui; bundle-version="[2.3.0,3.0.0)"; visibility:="reexport"
!ENTRY org.eclipse.emf.workspace 4 0 2015-07-08 13:24:55.125
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.workspace [350]
Another singleton bundle selected: osgi.identity; osgi.identity="org.eclipse.emf.workspace"; type="osgi.bundle"; version:Version="1.5.1.v20110823-1800"; singleton:="true"
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)"
Can some one help me to resolve this issue. This was working fine with Q7 IDE and Q7 runner
Re: Is RCPTT work with indigo version [message #1701518 is a reply to message #1701039] Mon, 13 July 2015 16:03 Go to previous messageGo to next message
Can somebody help me to resolve these errors
Re: Is RCPTT work with indigo version [message #1701565 is a reply to message #1701518] Tue, 14 July 2015 03:59 Go to previous messageGo to next message
Does the directory which you select as a location contain "plugins" directory?
As for runner could you please attach the following details:
1. Original <your AUT>.ini, <your AUT>/configuration/config.in and <your AUT>/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info
2. RCPTT runner workspace
3. Your pom.xml if you use Maven or runner command line.
Thanks in advance!
Re: Is RCPTT work with indigo version [message #1702034 is a reply to message #1701565] Fri, 17 July 2015 13:30 Go to previous messageGo to next message
Hi Olga
Plugin directory is not present in the directory where my AUT exe located. Here is the Directory Structure
<Eclipse installation root>\<productName>\<version>\eclipse\<productName>.exe
<Eclipse installation root>\<productName>\<version>\eclipse\<productName>.ini
<Eclipse installation root>\<productName>\<version>\eclipse\configuration
<Eclipse installation root>\eclipse-platform\bundlepool\1.0
I am selecting <Eclipse installation root>\<productName>\<version>\eclipse directory to add AUT in IDE. But its throwing "plugins" does not exist" error and AUT doesnt get added.
Same thing was working properly when i tried it with Q7 IDE.
Please find requested files attached here with
Parag
Re: Is RCPTT work with indigo version [message #1702217 is a reply to message #1702034] Mon, 20 July 2015 13:15 Go to previous messageGo to next message
Hi Olga,
Any luck on this issue
Parag
Re: Is RCPTT work with indigo version [message #1703142 is a reply to message #1702217] Tue, 28 July 2015 16:42 Go to previous messageGo to next message
Can someone please help me to resolve this issue?
Parag
Re: Is RCPTT work with indigo version [message #1703171 is a reply to message #1703142] Wed, 29 July 2015 02:44 Go to previous messageGo to next message
It will take time to investigate this issue.
Currently, this task doesn't have a high priority.
To get faster fix you may contact professional support center.
All contacts are available here.
Re: Is RCPTT work with indigo version [message #1703294 is a reply to message #1702217] Thu, 30 July 2015 07:28 Go to previous messageGo to next message
Hi Parag,
Where do you have plugins folder of your AUT?
Did you try to point plugins location while creating AUT configuration in RCPTT IDE?
Kind regards,
Ulyana.
Re: Is RCPTT work with indigo version [message #1703295 is a reply to message #1702217] Thu, 30 July 2015 07:33 Go to previous messageGo to next message
Hi Parag,
Could you please try to launch your AUT using RCPTT Maven plugin 2.1.0-SNAPSHOT?
What is the result?
Kind regards,
Ulyana.
Re: Is RCPTT work with indigo version [message #1703763 is a reply to message #1703294] Tue, 04 August 2015 14:15 Go to previous messageGo to next message
Hi ulyana
The plugin folder is present under <Eclipse installation root>\eclipse-platform\bundlepool\1.0 location. But my application exe and ini file is present under <Eclipse installation root>\<productName>\<version>\eclipse folder.
I tried to provide AUT as <Eclipse installation root>\eclipse-platform\bundlepool\1.0 in which plugin folder is located, i am able to start AUT from IDE. But when i execute test cases then some of the test cases are failing.
Also i tried with Maven plugin but facing same issue
Its throwing following error
[ERROR] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) on project rcpttTests: Execution default-execute of goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute failed. NullPo
interException -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) on project rcpttTests: Execution default-execute of goal org.eclipse.rcptt:rcptt-ma
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:224)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.PluginExecutionException: Execution default-execute of goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute failed.
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:145)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
... 20 more
at org.eclipse.rcptt.maven.AbstractRCPTTMojo.getResolvedRcpLocation(AbstractRCPTTMojo.java:218)
at org.eclipse.rcptt.maven.AbstractRCPTTMojo.getResolvedAutDir(AbstractRCPTTMojo.java:207)
at org.eclipse.rcptt.maven.ExecuteMojo.execute(ExecuteMojo.java:131)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
... 21 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
Please find pom file and logs attached here with
Parag
  • Attachment: pom.xml
    (Size: 1.95KB, Downloaded 141 times)
  • Attachment: logs.txt
    (Size: 50.39KB, Downloaded 231 times)
Re: Is RCPTT work with indigo version [message #1703796 is a reply to message #1703763] Wed, 05 August 2015 01:49 Go to previous messageGo to next message
Hi Parag,
What Maven version do you use?
Kind regards,
Ulyana.
Re: Is RCPTT work with indigo version [message #1704918 is a reply to message #1703796] Mon, 10 August 2015 13:54 Go to previous messageGo to next message
Hi Ulyana
I am using Apache Maven 3.3.3.
Please find version details as follows
Apache Maven 3.3.3 (7994120775791599e205a5524ec3e0dfe41d4a06; 2015-04-22T04:57:37-07:00)
Maven home: E:\Software\apache-maven-3.3.3-bin\apache-maven-3.3.3\bin\..
Java version: 1.7.0_21, vendor: Oracle Corporation
Java home: C:\Java\jdk1.7.0_21\jre
Default locale: en_US, platform encoding: Cp1252
OS name: "windows 7", version: "6.1", arch: "amd64", family: "windows"
Parag
Re: Is RCPTT work with indigo version [message #1704999 is a reply to message #1704918] Tue, 11 August 2015 07:04 Go to previous messageGo to next message
Hi Parag,
Could you please try one more time with 2.1.0-SNAPSHOT as you already did?
We've made a fix in RCPTT maven plugin and it should work now.
Kind regards,
Ulyana.
Re: Is RCPTT work with indigo version [message #1705065 is a reply to message #1704999] Tue, 11 August 2015 14:43 Go to previous messageGo to next message
Hi Ulyana
I tried again and now its throwing error saying invalid AUT same as what it usually give while adding AUT on IDE.
[WARNING] Checksum validation failed, no checksums available for https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/
Downloaded: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/ (108 KB at 38.3 KB/sec)
[DEBUG] Writing tracking file C:\Users\pbhalera\.m2\repository\org\eclipse\rcptt\runner\rcptt.runner\2.1.0-SNAPSHOT\resolver-status.properties
[INFO] Resolving artifact org.eclipse.rcptt.runner:rcptt.runner:zip:2.1.0-SNAPSHOT, this may take a while ...
[DEBUG] Could not find metadata org.eclipse.rcptt.runner:rcptt.runner:2.1.0-SNAPSHOT/maven-metadata.xml in local (C:\Users\pbhalera\.m2\repository)
[DEBUG] Failure to find org.eclipse.rcptt.runner:rcptt.runner:2.1.0-SNAPSHOT/maven-metadata.xml in https://repo.eclipse.org/content/repositories/rcptt-releases/ was cached in the local repository, resolution will not be reattempted until th
e update interval of rcptt-releases has elapsed or updates are forced
[DEBUG] Using transporter WagonTransporter with priority -1.0 for https://repo.eclipse.org/content/repositories/rcptt-snapshots/
[DEBUG] Using connector BasicRepositoryConnector with priority 0.0 for https://repo.eclipse.org/content/repositories/rcptt-snapshots/
Downloading: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/maven-metadata.xml (789 B at 1.9 KB/sec)
[INFO] Artifact org.eclipse.rcptt.runner:rcptt.runner:zip:2.1.0-SNAPSHOT is resolved to C:\Users\pbhalera\.m2\repository\org\eclipse\rcptt\runner\rcptt.runner\2.1.0-SNAPSHOT\rcptt.runner-2.1.0-SNAPSHOT.zip
[INFO] Using AUT from E:\MDMS420\studio-mdm\5.0\eclipse
[INFO] Extracting RCPTT runner to E:\Software\Q7\RCPTT\Workspace\MDMStudio\target\runner
[DEBUG] Expanding: C:\Users\pbhalera\.m2\repository\org\eclipse\rcptt\runner\rcptt.runner\2.1.0-SNAPSHOT\rcptt.runner-2.1.0-SNAPSHOT.zip into E:\Software\Q7\RCPTT\Workspace\MDMStudio\target\runner
[DEBUG] expand complete
[INFO] Copying project contents to target directory...
[INFO]
[INFO] --- rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) @ rcpttTests1 ---
[DEBUG] Configuring mojo org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute from plugin realm ClassRealm[extension>org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT, parent: sun.misc.Launcher$AppClassLoader@6a7be687]
[DEBUG] Configuring mojo 'org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute' with basic configurator -->
[DEBUG] (s) explicit = E:\MDMS420\studio-mdm\5.0\eclipse
[DEBUG] (s) vmArgs = [-Xmx1536m, -XX:MaxPermSize=256m]
[DEBUG] (f) aut = Coords [artifactId=null, groupId=null, version=null]
[DEBUG] (f) outDir = E:\Software\Q7\RCPTT\Workspace\MDMStudio\target
[DEBUG] (f) project = MavenProject: projectName:rcpttTests1:2.1.0-SNAPSHOT @ E:\Software\Q7\RCPTT\Workspace\MDMStudio\pom.xml
[DEBUG] (f) repoSession = org.eclipse.aether.DefaultRepositorySystemSession@24d0bcec
[DEBUG] (s) version = 2.1.0-SNAPSHOT
[DEBUG] (s) vmArgs = [-Xmx1024m, -XX:MaxPermSize=256m]
[DEBUG] (f) runner = Coords [artifactId=null, groupId=null, version=2.1.0-SNAPSHOT]
[DEBUG] (f) skipTests = false
[DEBUG] (f) suites = [ProcessDesignerSanity]
[DEBUG] (f) testFailureIgnore = false
[DEBUG] (f) testOptions = {testExecTimeout=1200}
[DEBUG] -- end configuration --
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 43.953 s
[INFO] Finished at: 2015-08-11T11:38:11-07:00
[INFO] Final Memory: 10M/177M
[ERROR] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) on project rcpttTests1: Invalid RCP location E:\MDMS420\studio-mdm\5.0\eclipse -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) on project rcpttTests1: Invalid RCP location E:\MDMS420\studio-mdm\5.0\eclipse
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
Caused by: org.apache.maven.plugin.MojoFailureException: Invalid RCP location E:\MDMS420\studio-mdm\5.0\eclipse
at org.eclipse.rcptt.maven.AbstractRCPTTMojo.getResolvedRcpLocation(AbstractRCPTTMojo.java:225)
... 20 more
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Re: Is RCPTT work with indigo version [message #1705091 is a reply to message #1705065] Wed, 12 August 2015 02:16 Go to previous message
Hi Parag,
1) Could you please attach full log file?
2) Is it possible to get your AUT to reproduce the issue on our side?
3) Did you try to set plugins location in pom.xml file (like you already did starting AUT from IDE)? If no, could you please try?
Kind regards,
Ulyana.
[Updated on: Wed, 12 August 2015 02:20] by Moderator
Previous Topic:Problem launching AUT: FrameworkEvent ERROR
Next Topic:Preset Variables in RCPTT
Current Time: Sun Jul 20 09:57:26 EDT 2025
Powered by FUDForum. Page generated in 0.07827 seconds
