Home » Newcomers » Newcomers » Eclipse has an installer!
Eclipse has an installer! [message #1691614] Wed, 08 April 2015 09:48 Go to next message
The upcoming version of Eclipse (Mars) now has an easy-to-use installer. No more unzipping!
Please try it out:
http://www.eclipse.org/downloads/index-developer-installer.php
Please report bugs , or odd behaviour to Bugzilla:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Oomph&component=Utilities
Eclipse Mars is scheduled for release towards the end of June, 2015.
[Updated on: Thu, 23 June 2016 09:57] by Moderator
Re: Eclipse has an installer! [message #1691680 is a reply to message #1691614] Wed, 08 April 2015 23:07 Go to previous messageGo to next message
Looks cool. What's the advantage of having it install though? Will there be some interesting installation options, like preinstall software stuffs? Hmm...
Re: Eclipse has an installer! [message #1692235 is a reply to message #1691680] Tue, 14 April 2015 08:42 Go to previous messageGo to next message
Andrew Mazar wrote on Wed, 08 April 2015 23:07
Easier to combine packages together, and it also walks you through some default preferences that are easier to miss. Also, it allows you to record/save preferences, and to apply preference changes to all your workspaces.
Re: Eclipse has an installer! [message #1695090 is a reply to message #1692235] Mon, 11 May 2015 21:13 Go to previous messageGo to next message
I am not sure if this is on topic or not, but has there been any thoughts to getting this to work with Raspian on the Pi 2?
Re: Eclipse has an installer! [message #1695171 is a reply to message #1695090] Tue, 12 May 2015 09:12 Go to previous messageGo to next message
I highly doubt that. One would have to contact the IoT project: http://iot.eclipse.org for their insight.
Re: Eclipse has an installer! [message #1695345 is a reply to message #1691614] Wed, 13 May 2015 11:48 Go to previous messageGo to next message
I tried it and loved it :)
I also blogged about it
http://www.lorenzobettini.it/2015/05/using-the-new-eclipse-installer/
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Eclipse has an installer! [message #1696789 is a reply to message #1691614] Thu, 28 May 2015 10:51 Go to previous messageGo to next message
I couldn't get the Canadian mirror (closest to me) to serve the file with error 404 file not found.
Re: Eclipse has an installer! [message #1696812 is a reply to message #1696789] Thu, 28 May 2015 12:42 Go to previous messageGo to next message
Timothy,
You mean the download link for the installer executable? Please let us
know the link; mangle it if you can't post links yet.
Re: Eclipse has an installer! [message #1699718 is a reply to message #1696812] Fri, 26 June 2015 03:28 Go to previous messageGo to next message
How does one package an existing Eclipse Mars installation as a "User package" for Eclipse Installer by Oomph?
What I really want to preserve and be reconfigured on install are:
* Installation settings, eclipse.ini contents
* Plugins and their configuration
* Workspace projects or at least their list and VCS urls
* Settings and configuration (line numbers, formatter, content assist, templates, types to import)
Are these things possible to persist in a User package at all?
Is there any documentation on the subject?
Thank you!
Re: Eclipse has an installer! [message #1699785 is a reply to message #1699718] Fri, 26 June 2015 11:00 Go to previous messageGo to next message
Oleg Šelajev wrote on Fri, 26 June 2015 03:28
Thank you!
Your best option is to ask in the Oomph forum:
https://www.eclipse.org/forums/index.php/f/287/
Re: Eclipse has an installer! [message #1700499 is a reply to message #1691614] Fri, 03 July 2015 00:01 Go to previous messageGo to next message
my eclipse says that it couldnt find the companion shared library
Re: Eclipse has an installer! [message #1700582 is a reply to message #1700499] Sat, 04 July 2015 03:01 Go to previous messageGo to next message
Am 03.07.2015 um 20:29 schrieb Christian Griffiths:
That doesn't sound good. If you tell us the exact steps needed to reproduce that we might be able to find out why that
happens for you and how it can be fixed.
Cheers
/Eike
http://www.esc-net.de
Re: Eclipse has an installer! [message #1700635 is a reply to message #1700582] Mon, 06 July 2015 00:17 Go to previous messageGo to next message
I couldn't get the Vietnamese mirror (closest to me) to serve the file with error 404 file not found.
Re: Eclipse has an installer! [message #1700676 is a reply to message #1700635] Mon, 06 July 2015 08:26 Go to previous messageGo to next message
Am 06.07.2015 um 13:22 schrieb Tien Tran:
Hmm, when I read that sentence I think all is good. But I suspect you mean something else. Maybe you describe your
problem in more detail? What exactly have you done and what is the result?
Cheers
/Eike
Re: Eclipse has an installer! [message #1703100 is a reply to message #1691614] Tue, 28 July 2015 10:27 Go to previous messageGo to next message
The downloads at https://www.eclipse.org/downloads/ Still downloads a .zip file not installer, the page given in your post at https://www.eclipse.org/downloads/index-developer-installer.php is a 404 File not found. Where is the resources section that was in this site now?
Re: Eclipse has an installer! [message #1703127 is a reply to message #1703100] Tue, 28 July 2015 13:55 Go to previous messageGo to next message
Am 28.07.2015 um 16:27 schrieb Varuna Seneviratna:
It's this page: http://www.eclipse.org/downloads/installer.php
A newer version of the installer is available here: https://wiki.eclipse.org/Eclipse_Installer
Cheers
/Eike
Re: Eclipse has an installer! [message #1708684 is a reply to message #1703127] Fri, 18 September 2015 12:56 Go to previous messageGo to next message
I tried to install Eclipse Mars using the Eclipse Installer, and it gave me an error message saying I need JDK 8.
I'm using JDK 7 because my computer still uses Windows XP, where JDK 8 isn't supported.
I was able to get Eclipse to run by installing it manually, and putting a reference to my JDK in eclipse.ini.
Re: Eclipse has an installer! [message #1709274 is a reply to message #1708684] Fri, 25 September 2015 10:28 Go to previous messageGo to next message
Am 18.09.2015 um 21:27 schrieb OpenOffice Bugs:
Please note that the installer binaries that are available on the main download page now only require Java 7.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=477996 for details.
Cheers
/Eike
Re: Eclipse has an installer! [message #1711636 is a reply to message #1709274] Sun, 18 October 2015 16:25 Go to previous messageGo to next message
Eike Stepper wrote on Fri, 25 September 2015 14:28
Apologies for the late reply, but thanks for fixing the installer!
[Updated on: Sun, 18 October 2015 16:26] by Moderator
Re: Eclipse has an installer! [message #1711810 is a reply to message #1711636] Mon, 19 October 2015 16:58 Go to previous messageGo to next message
excellent help, thank you very much, worked well
Re: Eclipse has an installer! [message #1713965 is a reply to message #1711810] Mon, 09 November 2015 03:21 Go to previous messageGo to next message
this is very cool,
Re: Eclipse has an installer! [message #1714030 is a reply to message #1713965] Mon, 09 November 2015 08:40 Go to previous message
This thread is being locked to prevent "thank you" responses. Questions about the installer should be either new threads in the Newcomers group or directed to the Oomph forum.
Previous Topic:Can't open declaration of class in Eclipse
Next Topic:eGit question. One project showing as seperate folder in eclipse...
Current Time: Sat Jul 19 05:00:51 EDT 2025
Powered by FUDForum. Page generated in 0.39153 seconds
