Home » Archived » Hudson » Error installing using yum on CentOS(Error installing using yum on CentOS)
icon4.gif  Error installing using yum on CentOS [message #997713] Tue, 08 January 2013 10:35 Go to next message
I'm trying to install Hudson on a CentOS 6.3 GuestOS within Virtualbox using the following steps from the Installation guide.
1. sudo wget -O /etc/yum.repos.d/hudson.repo "http://" hudson-ci.org/redhat/hudson.repo
2. sudo yum check-update
3. sudo yum install hudson
However when I run step 2 I get the following error;
hudson-ci.org/redhat/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 404"
Any idea why this is happening.
Trevor
PS Forgive the unruly format on http, it's down to me being a new poster.
Re: Error installing using yum on CentOS [message #997750 is a reply to message #997713] Tue, 08 January 2013 12:03 Go to previous messageGo to next message
Hi Trevor, this is also similar to your other posting. I noticed the repomd.xml was not copied correctly. I copied it now and should work properly. Let me know, if it works OK.
Re: Error installing using yum on CentOS [message #1702807 is a reply to message #997750] Fri, 24 July 2015 15:25 Go to previous messageGo to next message
I have been trying to install Hudson on a new VM and I'm seeing this error too. When I looked, I didn't see a repodata directory, but there is a repodata-old directory there.
Gary Santora
Re: Error installing using yum on CentOS [message #1703107 is a reply to message #1702807] Tue, 28 July 2015 10:53 Go to previous message
Thanks Gary, my bad. Copied the repodata folder now.
Previous Topic:Not able to start Hudson Slave
Next Topic:"Cascading job name set but the instance is not set." errors
Current Time: Sun Jul 20 13:04:40 EDT 2025
Powered by FUDForum. Page generated in 0.03782 seconds
