Home » Eclipse Projects » Oomph » Problem in building an Eclipse installation with oomph
Problem in building an Eclipse installation with oomph [message #1703003] |
Mon, 27 July 2015 16:44  |
Hallo,
I am setting up an Eclipse distribution with several plugins needed to have a proper IDE for an Eclipse Project (GEF).
When adding the plugins to Eclipse everything is Ok, until I install the Oomph Version Management Tool plugin.
After installing the Oomph VMT Plugin, from the next startup I see the below error:
Plugins contained in the Eclipse distribution.
As specified in the GEF contributor guide, the GEF-IDE consists of
After installing the Oomph Version Management Tool plug-in, at the next Eclipse Startup I see the following error:
An internal error occurred during: "Setup check".
USER_HOME
I was actually thinking my install was ok, but in bugzilla, I got that I did an "inconsistent installation" - see bug 473599.
Indeed, I checked in the About eclipse features for the Oomph, and I saw the Version Management Tool version is not matching with Oomph Setup Core , but only for a small "delta"
I tried to do an Update of the IDE using the Help > Check for updates, but I realized it is not a Complete IDE update , as suggested in the bug 473599.
So, I have two questions:
- how to perform a Complete IDE Update ?
- how can I make a consistent installation, by assembling the five plugins above, including the Oomph version management ?
Thank you very much for the time you're spending on my question.
I hope my question does not seem impolite or excessively complex.
Regards.
[Updated on: Tue, 28 July 2015 03:32] by Moderator
Re: Problem in building an Eclipse installation with oomph [message #1703032 is a reply to message #1703003] |
Tue, 28 July 2015 03:26   |
Hi Patrik,
The p2f file that you mentioned in https://bugs.eclipse.org/bugs/show_bug.cgi?id=473599 seems totally useless to me. It
locks in specific versions of the listed IUs, no matter whether the identified repositories will provide those versions
in the future or not. For example:
<iu id='org.eclipse.oomph.setup.feature.group' name='Oomph Setup' version='1.2.0.v20150720-0925'>
<repositories size='2'>
<repository location='http://download.eclipse.org/oomph/updates'/>
<repository location='http://download.eclipse.org/oomph/updates/latest'/>
</repositories>
</iu>
A P2Director task in an Oomph setup model for GEF seems like a better alternative.
More comments below...
Cheers
/Eike
http://www.esc-net.de
Am 27.07.2015 um 22:44 schrieb Patrik Suzzi:
> Hallo,
> I am trying to build a complex eclipse installation needed for development of the Eclipse GEF project.
> Eclipse IDE for committers Mars R as base eclipse ( in my case is win32)
> API Tools Execution Environment Description v 1.0.1 from http://download.eclipse.org/releases/mars update site
> e(fx)clipse IDE - PDE version .2.0.0, from http://download.eclipse.org/efxclipse/updates-released/2.0.0/site/ update site
> m2e - Maven Integration for Eclipse - version 1.6.0, from http://download.eclipse.org/releases/mars update site
> Xtext Complete SDK - version 2.8.3, from http://download.eclipse.org/releases/mars update site
> Oomph Version Management Tool, from http://download.eclipse.org/oomph/updates
> During the installation everything is Ok, until I install the last plugin: the Oomph Version Management Tool.
> USER_HOME
> I was actually thinking my install was ok, but in bugzilla, I got that I did an "inconsistent installation" - see https://bugs.eclipse.org/bugs/show_bug.cgi?id=473599.
> Indeed, I checked in the About eclipse features for the Oomph, and I saw the Version Management Tool version is not matching with Oomph Setup Core .
> I tried to do an Update of the IDE using the Help > Check for updates, but I realized it is not a Complete IDE update , as suggested in the https://bugs.eclipse.org/bugs/show_bug.cgi?id=473599.
I'm not 100% sure but I think you can't easily get out of this inconsistent state because the plugins that would do that
for you are also impacted. I would recommend that you create a new installation with Oomph's Eclipse Installer.
I would suggest that you put pressure on the GEF people to provide a GEF project setup model, so that you can just add
it to your install.
Current Time: Sun Jul 20 03:14:22 EDT 2025
Powered by FUDForum. Page generated in 0.03479 seconds
