Home » Eclipse Projects » Oomph » Access project set from URL that requires authentication
Access project set from URL that requires authentication [message #1461365] Tue, 04 November 2014 08:36 Go to next message
We have stored a project set into the source repository and want to consume it from there. Accessing this file requires authentication. I tried to encode user/pwd into the URL like "http://<uid>:<pwd>@host/path/myProjectSet.psf".
Unfortunately this does not work. I am getting the error below. In ProjectSetImportTaskImpl I see that in getXMLContent() no options are passed to the URI converter. Does this mean anything? How does the AuthorizationHandler kick in to get the auth data?
What must be done to take the basic authentication challenge?
[11:48:47] Performing setup task Project Set Import http://karsten.thoms:jE59TDkhuXzYdLxiPDZ3Vg==@path/projectset.psf
[11:48:47] org.eclipse.oomph.util.IOExceptionWithCause: Unauthorized
  at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:548)
  at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
  at org.eclipse.oomph.setup.projectset.impl.ProjectSetImportTaskImpl$Helper.getXMLContent(ProjectSetImportTaskImpl.java:291)
  at org.eclipse.oomph.setup.projectset.impl.ProjectSetImportTaskImpl$Helper.perform(ProjectSetImportTaskImpl.java:272)
  at org.eclipse.oomph.setup.projectset.impl.ProjectSetImportTaskImpl.perform(ProjectSetImportTaskImpl.java:219)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2563)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2534)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:3550)
  at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:3544)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:3542)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2525)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2509)
  at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2439)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:501)
  at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:581)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
ERROR: org.eclipse.ecf.identity code=0 Unauthorized
  at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:652)
  at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:885)
  at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
  at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
  at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:482)
  ... 1 more
[11:48:47] ERROR: org.eclipse.oomph.setup.core code=0 Unauthorized
  ... 1 more
Re: Access project set from URL that requires authentication [message #1461467 is a reply to message #1461365] Tue, 04 November 2014 10:41 Go to previous messageGo to next message
Karsten,
Much depends on the authority's authentication scheme. I've tested
with authorities that return 401; in that case, you should be prompted
for a user name and password, which will be cached and reused. Have you
tried that? And shouldn't it be an https URI? If you can share an
example, I can test what's going wrong for that case... I know other
cases, the authority redirects to a login page; that's more difficult to
deal with...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 1 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 1 more
Re: Access project set from URL that requires authentication [message #1700677 is a reply to message #1461467] Mon, 06 July 2015 08:31 Go to previous messageGo to next message
Karsten,
I had the same problem. Did you solve it?
Ed,
I think the problem is as Karsten wrote. The ProjectSetImportTaskImpl passes no options to the URIConverter.
In org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil.configureResourceSet() the AuthorizationHandler is correctly initialized. I patched the ProjectSetImportTaskImpl to pass the resourceSet.getLoadOptions() to the URIConverter and I get asked for user and password.
May you open an bug entry and fix it in future versions?
Re: Access project set from URL that requires authentication [message #1700720 is a reply to message #1700677] Mon, 06 July 2015 11:54 Go to previous messageGo to next message
Tobias,
I see! Yes, please open a bugzilla and we'll address this. Thanks for
investigating!
On 06/07/2015 5:27 PM, Tobias Pongs wrote:
> Karsten,
> Ed,
> In
Re: Access project set from URL that requires authentication [message #1700766 is a reply to message #1700720] Tue, 07 July 2015 01:21 Go to previous messageGo to next message
Ed,
I've created Bug 471994.
Re: Access project set from URL that requires authentication [message #1702686 is a reply to message #1700766] Fri, 24 July 2015 02:58 Go to previous messageGo to next message
Hey there,
hope this problem here is not too off topic, I think it's kind of related.
I am trying to get my oomph setups from a git repository.
I edited the eclipse-inst.ini and added -Doomph.redirection.setups=... (the forum won't let me post any links here, but the URLs are correct)
When starting the installer, I get a prompt for username and password. Unfortunately no login works. I tried it with my standard user which authenticates via LDAP. That didn't work. I also tried a dummy user we created which athenticates not via LDAP (a normal user created in our GitLab) but both doesn't work. Of course they have access to our project in which the setups are located. There is no obvious error message, the prompt just opens again and after a few attempts he says he could not connect.
Here is what I found in my logs:
!SESSION 2015-07-24 08:49:42.588 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_45
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Command-line arguments:  -os win32 -ws win32 -arch x86_64 -data @none
!ENTRY org.eclipse.oomph.setup.ui 4 0 2015-07-24 08:49:59.026
!MESSAGE org.eclipse.oomph.util.IOExceptionWithCause:
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.oomph.util.IOExceptionWithCause:
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob$1.handleDemandLoadException(ResourceMirror.java:219)
	at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob.perform(ResourceMirror.java:226)
	at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:416)
Caused by: org.eclipse.oomph.util.IOExceptionWithCause:
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:266)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
	at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob.perform(ResourceMirror.java:208)
	... 2 more
Caused by: org.eclipse.ecf.filetransfer.IncomingFileTransferException:
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$FileTransferListener.handleTransferEvent(ECFURIHandlerImpl.java:772)
	at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.fireReceiveStartEvent(AbstractRetrieveFileTransfer.java:671)
	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.openStreams(HttpClientRetrieveFileTransfer.java:646)
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:201)
	... 5 more
Do you have any idea what could be the problem?
Thanks in advance
Re: Access project set from URL that requires authentication [message #1702692 is a reply to message #1702686] Fri, 24 July 2015 03:16 Go to previous messageGo to next message
Matthias,
Without being able to reproduce it, it's hard to comment on what might
be wrong...
The current support was implemented to authenticate a setup hosted at
bitbucket, so you see there is prompting of the username and password,
but perhaps there are different authentication styles. Currently we only
use "Basic" as in this implementation:
org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.AuthorizationHandler.Authorization.getAuthorization()
public String getAuthorization()
return "Basic " + obscure(user.length() == 0 ? getPassword() :
user + ":" + getPassword());
On 24/07/2015 8:58 AM, Matthias Nicklisch wrote:
> Hey there,
> related.
> java.vendor=Oracle Corporation
> !MESSAGE org.eclipse.oomph.util.IOExceptionWithCause: !STACK 0
> org.eclipse.oomph.util.IOExceptionWithCause: at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by: org.eclipse.oomph.util.IOExceptionWithCause: at
> at
> at
> at
> ... 2 more
> at
> at
> at
> at
> at
> at
> at
> ... 5 more
> Thanks in advance
Re: Access project set from URL that requires authentication [message #1702736 is a reply to message #1702692] Fri, 24 July 2015 07:47 Go to previous messageGo to next message
Hmm, that's unfortunate...
However, we have a method in GitLab to access a repository without the usual authentication. You can add a private token (https://[URL]?private_token=someCrypticKey) to access the repository, unfortunately, if I add this token, the redirection isn't recognized anymore. Do you have an idea how I can use this token? Is there another entry I could add to the ini file?
[EDIT] I set my project to public access and the installer still want's an authentication
[Updated on: Fri, 24 July 2015 09:06] by Moderator
Re: Access project set from URL that requires authentication [message #1702786 is a reply to message #1702736] Fri, 24 July 2015 10:36 Go to previous messageGo to next message
Matthias,
Please open a bugzilla and I'll test/determine how this can be made to
work for a private github repository. Github also uses this token
approach, and indeed that doesn't play well with redirection because the
query string isn't part of what will be redirected. So perhaps if I can
get authentication to work with Github, it will also work for your case.
Re: Access project set from URL that requires authentication [message #1702882 is a reply to message #1702786] Mon, 27 July 2015 04:23 Go to previous messageGo to next message
it works now with our public project. I just had to fill in the raw link to the file. Before I used the standard https link to the setup file. With the raw link everything works fine.
Re: Access project set from URL that requires authentication [message #1702890 is a reply to message #1702882] Mon, 27 July 2015 05:12 Go to previous message
Matthias,
In case anyone finds this thread later, I did commit changes for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=473602 such that it's now
possible to provide a stable link for a setup in a private github
repository.
On 27/07/2015 10:23 AM, Matthias Nicklisch wrote:
Previous Topic:default Java runtime
Next Topic:Order of git checkout and resource copy
Current Time: Sun Jul 20 05:33:14 EDT 2025
Powered by FUDForum. Page generated in 0.06247 seconds
