AUT is getting hanged up and gets timed out randomly [message #1702257] |
Tue, 21 July 2015 02:49  |
I have some 15 test cases. The AUT gets hang randomly. Often just after restart of the aut or checking out some data from server. Also it happens randomly when it switches between contexts. I am not able to point out a specific time when this happens.
What will be the issue? I am able to do this without RCPTT, but when using RCPTT this issue appears and it happens very often. Is anyone else facing this issue and is there a solution? How can I debug this?
This is one of the scenario which gets hanged randomly which I have noticed
proc "has-item" [val tree -input] [val titem] {
try {
$tree | get-item $titem
bool true // return true
} -catch {
bool false // return false
if [get-view "Resource Navigator" | get-tree | has-item "QTa" ]{
log "abc item exist"
} -else {
get-menu "Databank/Checkout Composite Tag" | click
with [get-window "Checkout Composite Tag Wizard"] {
get-button "Next >" | click
get-table | select "test server master"
with [get-window "Authentication required"] {
with [get-combo -after [get-label Username]] {
set-text jeevan
key-type "TRAVERSE_TAB_NEXT"
get-editbox -after [get-label Password] | set-text [decrypt "8g="]
get-button OK | click
get-combo | select "Masrer_Test_Data (created by: super @Tue May 26 19:35:44 PDT 2015)"
get-button "Clear All" | click
with [get-table] {
get-item "QTa1.1" | check
select "QTa1.1" | get-item "QTa1.1" | check
select "QTa1.1"
get-button Finish | click
// It's Hanging here
This code is in AUT Context where we can write a AUT code. After this I have a context to switch perspective. It is not even entering that context. It goes on playing this context itself.
In log I found something like this:
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-07-21 00:41:36.629
!MESSAGE Tesla server started on port 7003
java.lang.Exception: Bad call to getCoolBarManager()
at org.eclipse.ui.internal.WorkbenchWindow.getCoolBarManager(WorkbenchWindow.java:2634)
at org.eclipse.rcptt.tesla.ui.Q7KeyFormatter.installQ7Formatter(Q7KeyFormatter.java:66)
at org.eclipse.rcptt.tesla.ui.SWTTeslaStartup.earlyStartup(SWTTeslaStartup.java:18)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:87)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.ui.internal.Workbench$55.run(Workbench.java:2555)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Kindly let me know.
Thank you
Jeevan
[Updated on: Tue, 21 July 2015 03:58] by Moderator
Re: AUT is getting hanged up and gets timed out randomly [message #1703669 is a reply to message #1702594] |
Tue, 04 August 2015 02:24   |
I have a new log file attached PFA.
It is taken on the same scenario that is given in my ECL command above.
Before I checkout data I can see the following content in the log.
!ENTRY org.eclipse.osgi 2 0 2015-08-03 03:57:33.505
!MESSAGE While loading class "org.eclipse.rcptt.reporting.core.ReportHelper", thread "Thread[main,6,main]" timed out waiting (5008ms) for thread "Thread[Worker-1,5,main]" to finish starting bundle "org.eclipse.rcptt.reporting_2.0.0.201506110605 [464]". To avoid deadlock, thread "Thread[main,6,main]" is proceeding but "org.eclipse.rcptt.reporting.core.ReportHelper" may not be fully initialized.
!STACK 0!ENTRY org.eclipse.osgi 2 0 2015-08-03 03:57:33.505
After checkout has happened I find
ENTRY org.eclipse.rcptt.ecl.core 4 0 2015-08-03 04:05:41.409
!MESSAGE Result is already set for click
!STACK 0
java.lang.IllegalStateException: Result is already set for click
at org.eclipse.rcptt.reporting.core.ReportHelper$2.apply(ReportHelper.java:146)
It is not fully initialized in the first message. Since it is an issue with threads and deadlock, it is very expected to be not fully reproducible.
Let me know how to solve this.
Thank you,
Jeevan
Attachment: log.log
(Size: 50.47KB, Downloaded 143 times)
FUDForum. Page generated in 0.05285 seconds
