Is RCPTT work with indigo version [message #1701039] |
Wed, 08 July 2015 16:44  |
When i try to add AUT as eclipse version 3.7.2 from IDE then its not able to detect AUT. Throwing error as "Directory "<Eclipse Installtion home>\plugins" does not exist"
Has any one faced this issue.
Also when i try to lauch it from the RCPTT Runner 2.0 it throwing following error
"!ENTRY org.eclipse.jdt.launching.macosx 4 0 2015-07-08 13:24:52.931
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.macosx [103]
Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.os=macosx)"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.jdt.launching.ui.macosx 4 0 2015-07-08 13:24:55.103
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jdt.launching.ui.macosx [246]
!ENTRY org.eclipse.emf.workspace.ui 4 0 2015-07-08 13:24:55.117
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.workspace.ui [307]
Unresolved requirement: Require-Bundle: org.eclipse.emf.edit.ui; bundle-version="[2.3.0,3.0.0)"; visibility:="reexport"
!ENTRY org.eclipse.emf.workspace 4 0 2015-07-08 13:24:55.125
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.workspace [350]
Another singleton bundle selected: osgi.identity; osgi.identity="org.eclipse.emf.workspace"; type="osgi.bundle"; version:Version="1.5.1.v20110823-1800"; singleton:="true"
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)"
Can some one help me to resolve this issue. This was working fine with Q7 IDE and Q7 runner
Re: Is RCPTT work with indigo version [message #1705065 is a reply to message #1704999] |
Tue, 11 August 2015 14:43   |
Hi Ulyana
I tried again and now its throwing error saying invalid AUT same as what it usually give while adding AUT on IDE.
[WARNING] Checksum validation failed, no checksums available for https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/
Downloaded: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/ (108 KB at 38.3 KB/sec)
[DEBUG] Writing tracking file C:\Users\pbhalera\.m2\repository\org\eclipse\rcptt\runner\rcptt.runner\2.1.0-SNAPSHOT\resolver-status.properties
[INFO] Resolving artifact org.eclipse.rcptt.runner:rcptt.runner:zip:2.1.0-SNAPSHOT, this may take a while ...
[DEBUG] Could not find metadata org.eclipse.rcptt.runner:rcptt.runner:2.1.0-SNAPSHOT/maven-metadata.xml in local (C:\Users\pbhalera\.m2\repository)
[DEBUG] Failure to find org.eclipse.rcptt.runner:rcptt.runner:2.1.0-SNAPSHOT/maven-metadata.xml in https://repo.eclipse.org/content/repositories/rcptt-releases/ was cached in the local repository, resolution will not be reattempted until th
e update interval of rcptt-releases has elapsed or updates are forced
[DEBUG] Using transporter WagonTransporter with priority -1.0 for https://repo.eclipse.org/content/repositories/rcptt-snapshots/
[DEBUG] Using connector BasicRepositoryConnector with priority 0.0 for https://repo.eclipse.org/content/repositories/rcptt-snapshots/
Downloading: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/maven-metadata.xml
Downloaded: https://repo.eclipse.org/content/repositories/rcptt-snapshots/org/eclipse/rcptt/runner/rcptt.runner/2.1.0-SNAPSHOT/maven-metadata.xml (789 B at 1.9 KB/sec)
[INFO] Artifact org.eclipse.rcptt.runner:rcptt.runner:zip:2.1.0-SNAPSHOT is resolved to C:\Users\pbhalera\.m2\repository\org\eclipse\rcptt\runner\rcptt.runner\2.1.0-SNAPSHOT\rcptt.runner-2.1.0-SNAPSHOT.zip
[INFO] Using AUT from E:\MDMS420\studio-mdm\5.0\eclipse
[INFO] Extracting RCPTT runner to E:\Software\Q7\RCPTT\Workspace\MDMStudio\target\runner
[DEBUG] Expanding: C:\Users\pbhalera\.m2\repository\org\eclipse\rcptt\runner\rcptt.runner\2.1.0-SNAPSHOT\rcptt.runner-2.1.0-SNAPSHOT.zip into E:\Software\Q7\RCPTT\Workspace\MDMStudio\target\runner
[DEBUG] expand complete
[INFO] Copying project contents to target directory...
[INFO]
[INFO] --- rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) @ rcpttTests1 ---
[DEBUG] Configuring mojo org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute from plugin realm ClassRealm[extension>org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT, parent: sun.misc.Launcher$AppClassLoader@6a7be687]
[DEBUG] Configuring mojo 'org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute' with basic configurator -->
[DEBUG] (s) explicit = E:\MDMS420\studio-mdm\5.0\eclipse
[DEBUG] (s) vmArgs = [-Xmx1536m, -XX:MaxPermSize=256m]
[DEBUG] (f) aut = Coords [artifactId=null, groupId=null, version=null]
[DEBUG] (f) outDir = E:\Software\Q7\RCPTT\Workspace\MDMStudio\target
[DEBUG] (f) project = MavenProject: projectName:rcpttTests1:2.1.0-SNAPSHOT @ E:\Software\Q7\RCPTT\Workspace\MDMStudio\pom.xml
[DEBUG] (f) repoSession = org.eclipse.aether.DefaultRepositorySystemSession@24d0bcec
[DEBUG] (s) version = 2.1.0-SNAPSHOT
[DEBUG] (s) vmArgs = [-Xmx1024m, -XX:MaxPermSize=256m]
[DEBUG] (f) runner = Coords [artifactId=null, groupId=null, version=2.1.0-SNAPSHOT]
[DEBUG] (f) skipTests = false
[DEBUG] (f) suites = [ProcessDesignerSanity]
[DEBUG] (f) testFailureIgnore = false
[DEBUG] (f) testOptions = {testExecTimeout=1200}
[DEBUG] -- end configuration --
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 43.953 s
[INFO] Finished at: 2015-08-11T11:38:11-07:00
[INFO] Final Memory: 10M/177M
[ERROR] Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) on project rcpttTests1: Invalid RCP location E:\MDMS420\studio-mdm\5.0\eclipse -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.eclipse.rcptt:rcptt-maven-plugin:2.1.0-SNAPSHOT:execute (default-execute) on project rcpttTests1: Invalid RCP location E:\MDMS420\studio-mdm\5.0\eclipse
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoFailureException: Invalid RCP location E:\MDMS420\studio-mdm\5.0\eclipse
at org.eclipse.rcptt.maven.AbstractRCPTTMojo.getResolvedRcpLocation(AbstractRCPTTMojo.java:225)
at org.eclipse.rcptt.maven.AbstractRCPTTMojo.getResolvedAutDir(AbstractRCPTTMojo.java:207)
at org.eclipse.rcptt.maven.ExecuteMojo.execute(ExecuteMojo.java:131)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
... 20 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Re: Is RCPTT work with indigo version [message #1705091 is a reply to message #1705065] |
Wed, 12 August 2015 02:16  |
Hi Parag,
1) Could you please attach full log file?
2) Is it possible to get your AUT to reproduce the issue on our side?
3) Did you try to set plugins location in pom.xml file (like you already did starting AUT from IDE)? If no, could you please try?
Kind regards,
Ulyana.
[Updated on: Wed, 12 August 2015 02:20] by Moderator
FUDForum. Page generated in 0.05254 seconds
