Home » Eclipse Projects » RCP Testing Tool » How to add arguments and switches to AUT
How to add arguments and switches to AUT [message #1701737] Wed, 15 July 2015 05:52 Go to next message
Usually when I start my AUT from terminal, I will use command like for example
$ ./appname.bin
This is internally called from RCPTT when it calls AUT. But some times I have to pass some arguments and switches. How shall I do that? Take for example the following,
$ ./appname.bin -data @NoDefault
How can call my AUT using these parameters or arguments and switches?
Kindly let me know.
Jeevan
Re: How to add arguments and switches to AUT [message #1701776 is a reply to message #1701737] Wed, 15 July 2015 10:11 Go to previous messageGo to next message
Hi Jeevan
If in the application tab you click on one of the buttons to open the launch configuration of your AUT and then you click in Advanced, you have the classic Eclipse launch configuration where you can add Arguments to launch your AUT.
Re: How to add arguments and switches to AUT [message #1701981 is a reply to message #1701737] Fri, 17 July 2015 05:20 Go to previous messageGo to next message
Hi Jeevan,
Please see http://www.xored.com/2013/09/03/how-to-pass-a-value-to-a-test-during-its-execution/.
Kind regards,
Ulyana.
Re: How to add arguments and switches to AUT [message #1702570 is a reply to message #1701981] Thu, 23 July 2015 06:31 Go to previous message
Hi Ulyana,
I am not clear about what that link is about to say and I am not able to get my desired output using that. I don't want to pass VM arguments. I want to pass a Runtime Configuration argument which changes the behaviour of my application when I pass -data @noDefault while calling it.
For example:
When I call it "./appname.bin it opens normaly with an already default workspace
When I call it "./appname.bin -data @noDefault" it will not take any default workspace and will ask me for choosing an workspace
Hi Matias,
I can do that, but I want to do this only for one particular test case and not for the entire AUT.
Kindly let me know how to solve this.
Thank you all
Jeevan
[Updated on: Mon, 27 July 2015 05:55] by Moderator
Previous Topic:RCPTT IDE REPORT not valid
Next Topic:Close view inside rcptt
Current Time: Sat Jul 19 20:44:52 EDT 2025
Powered by FUDForum. Page generated in 0.05105 seconds
