Home » Eclipse Projects » e(fx)clipse » Embed Eclipse in JavaFX
Embed Eclipse in JavaFX [message #1701778] Wed, 15 July 2015 10:24 Go to next message
We are actually looking to do something different - embed an Eclipse view into a JavaFX application. We would like to be able to use Eclipse and plugins as an editor for specific languages (e.g. Java, DRL, Mvel, etc.). We are currently using a WebView with an HTML editor, Ace, which has some performance and compat. side effects.
Any pointers to resources that have embedded Eclipse into JavaFX would be appreciated.
Re: Embed Eclipse in JavaFX [message #1701850 is a reply to message #1701778] Thu, 16 July 2015 04:24 Go to previous messageGo to next message
You can not embed SWT (heavyweight toolkit) into JavaFX (lightweight
toolkit) so it is impossible to embed an Eclipse-View into it - so I'm
sorry for the bad news.
Still I have good news: e(fx)clipse has components (some of them not yet
released as API) allowing you to implemented editors in pure JavaFX with
the help of (Eclipse-Text-Frame which is the same as used by the Eclipse
IDE) and other core components of eclipse like jdt.core, ... .
See
http://tomsondev.bestsolution.at/2015/07/08/eclipse-democamp-season-javafx-smart-code-editors-eg-for-google-dart/
where I implement a dart editor in JavaFX
http://tomsondev.bestsolution.at/2015/02/17/compensator-a-code-editor-and-a-code-dev-environment-written-in-javafx/
where I implement a simple IDE with Java, JavaScript and git support.
As you can see from the video recording in the first link it is damn
easy to get (lexical) syntax highlighting because you can use the DSL to
describe your language. Semantic highlighting is on our list of features
we'd love to implement but we require funding or someone contributing
the solution.
Generally speaking you can implement editors for fairly any language,
connect them to headless services, like JDT, Xtext, ... and if you
really want to you *don't* have to use OSGi although things get a lot
easier if you use e4 as the application framework because all the
wireing is done for you already!
I've been working on those components in the last few days and hope to
have some cool news and tutorial ready end of the month. We'd naturally
happy if you'd be interested in joining the fun, funding some of its
development or hiring us to help you get started.
Tom
> be appreciated.
Re: Embed Eclipse in JavaFX [message #1702941 is a reply to message #1701850] Mon, 27 July 2015 09:17 Go to previous messageGo to next message
If you are still interested in this topic then
http://tomsondev.bestsolution.at/2015/07/27/developing-a-source-code-editor-in-javafx-on-the-eclipse-4-application-platform/
is interesting to you.
Tom
> See
> the solution.
> Tom
>> be appreciated.
Re: Embed Eclipse in JavaFX [message #1702957 is a reply to message #1702941] Mon, 27 July 2015 10:45 Go to previous messageGo to next message
Thanks Tom for you quick and useful replies. I will take a look at the latest link and get back. My takeaway from your initial response was the best approach was to do this in the WebkitView using a javascript client. My hope was to be able to use the Eclipse plugin not only because it had quite a bit of work done but as well we could have contributed back to the project any improvements we would make.
Instead we are using Ace and WebkitView because of time constraints.
I don't generally use JavaFX (as you could tell by my initial post) and this is a bit of a one off project but am glad to see not only has it become a more viable framework but there are developers such as yourself who are contributing back.
Like I said I will read the links you have provided and get back.
Thanks again.
Re: Embed Eclipse in JavaFX [message #1702978 is a reply to message #1702957] Mon, 27 July 2015 12:34 Go to previous message
The questions is what from the plug-in you could have reused, as you see
reusing core stuff is fairy easy.
Tom
> Thanks again.
Previous Topic:e(fx) and GUI-Testing
Next Topic:Encoding issue in properties files generated with l10n tooling
Current Time: Sun Jul 20 08:33:17 EDT 2025
Powered by FUDForum. Page generated in 0.04355 seconds
