Home » Eclipse Projects » Oomph » autocrlf on GitCloneTask
autocrlf on GitCloneTask [message #1700991] Wed, 08 July 2015 10:23 Go to next message
whenever I use the GitCloneTask in my setups (running on Windows) I see in the log output "Setting autocrlf = true"
is there any way to change that ?
our sources rely on keeping the lineendings exactly as they are in the repository.
I have autoCRLF set to FALSE in the global gitconfig and also in my user config.
is it a bug that these values are ignored ?
it would also be nice to have an option on the GitCloneTask to enforce the needed setting, as it might not be correct in the global gitconfig.
Re: autocrlf on GitCloneTask [message #1701317 is a reply to message #1700991] Fri, 10 July 2015 21:00 Go to previous messageGo to next message
Michael,
Comments below.
Yes, this is hard coded in the git clone task implementation.
No.
> repository.
In other words Unix-style. How is it that they "rely" on this?
> user config.
No.
I suppose, though "correct" is rather subjective. Unfortunately there
are tools on Windows that will produce Windows line delimiters and if
you're not careful, those will be committed to the repository without
conversion. Then a user checking it out on Unix will see Windows
delimiters, and all will be a huge mess. This seems very dangerous so it
seems to us better to always do the conversion, especially on Windows.
Of course that's a subjective statement as well, and we don't really
want to dictate to everyone what we think is right. But I am curious
how your source relies on this.
Re: autocrlf on GitCloneTask [message #1701362 is a reply to message #1701317] Sun, 12 July 2015 16:44 Go to previous messageGo to next message
Ed Merks wrote on Fri, 10 July 2015 21:00
Michael,
.. no in the repository we have Windows-style line breaks for all java files.
well the java source files are obviously not a problem, since Eclipse has no problems using any kind of line ending.
... but we have many data files that are needed for unit tests and integration tests (for example MIME structures which have to use CRLF line breaks).
the autoCRLF, can also break non-text files, and it becomes really messy if you use egit in combination with command-line git, or some other git tool that correctly uses the .gitattribute settings defined in a repository.
(see https://bugs.eclipse.org/bugs/show_bug.cgi?id=342372)
Since all our developers use Eclipse I don't see any benefit of the autoCRLF feature at all.
We had the same problems also with SVN, so we decided many years ago, that we would not allow any "conversion magic" to be performed by version control tools.
I looked at the source of the GitCloneTask and saw that autoCRLF is always enabled on Windows and always disabled on any other operating system.
So when someone uses Eclipse on Linux but has it configured to use CRLF as lineendings (as we have defined in our globally shared eclipse settings) then they will commit CRLF to GIT, whereas the Windows users will not ... that is just creating the same mess that you had described above.
I would expect to have autoCRLF enabled always or never, but not depending on the OS.
As it is implemented now, it is a showstopper for us, since there is no workaround ... unfortunately I noticed this problem after I had prepared the setup files for most of our projects Sad
[Updated on: Sun, 12 July 2015 16:55] by Moderator
Re: autocrlf on GitCloneTask [message #1701363 is a reply to message #1701362] Sun, 12 July 2015 19:04 Go to previous messageGo to next message
Michael,
Comments below.
> integration tests (for example MIME structures).
I'd be kind of surprised if there is a tool that works on Windows that
can't deal with Windows line breaks...
> in a repository.
That's quite the saga. I believe the setting we do is stored in the
repo's config, so should be respected by command line tools...
There is the danger that you'll commit Windows line endings...
It's always a bit of a nightmare, but some tools just produce Windows
line endings on Windows and then you end up with a different version of
the nightmare.
> system.
Yes.
> described above.
So you commit Windows line endings and people on Linux see that. That
sounds bad to me too...
I suppose that's true, but the expectation is that the actual repository
uses Linux conventions so conversion on Linux is a no-op.
> prepared the setup files for most of our projects :(
We could certainly look at making it more flexible, though I'm very
surprised you're committing Windows line endings to your repository;
I've never seen anyone do that intentionally.
As a workaround, I suppose you could have a resource modify task that
modifies the ${foo.git.clone.location/.git/config} to change the value
of that attribute.
Re: autocrlf on GitCloneTask [message #1701611 is a reply to message #1701363] Tue, 14 July 2015 08:39 Go to previous messageGo to next message
as mentioned before, the main reason for this is that we need to have our test files unchanged (regardless of the operating system)
For the source files, there is no real need to commit the windows line endings, but it is more consistent in our opinion to avoid conversion completely.
I also thought about using the resource modify task, however that does not work because the git clone task is already causing a conversion while doing the checkout of the working copy.
changing the flag afterwards only affects future operations.
as a proof of concept I have patched the GitCloneTask to set the Flag to false, which works just fine. however replacing the eclipse plugin is not really convenient for deployment.
Is there any way to use custom SetupTasks that would be available on our own eclipse update site ?
Re: autocrlf on GitCloneTask [message #1701623 is a reply to message #1701611] Tue, 14 July 2015 09:42 Go to previous messageGo to next message
Michael,
Comments below.
On 14/07/2015 2:39 PM, Michael Haeusler wrote:
> Quote:
I'll have to take your word for it that this is a need and not just a
want. I suppose you could mark them as binary but that would have other
not nice side effects do doubt.
> completely.
To me it seems very odd given that the whole design around this in git
itself is intended to keep the repository's line endings in a standard
form (which is Linux) and to surface this in the OS form on checkout.
With what you're proposing, there is nothing to prevent a mixture of
forms being committed.
Good point. Sorry.
Please open an enhancement request. Probably we should focus on a
design that allows any of the configuration properties to be set...
Re: autocrlf on GitCloneTask [message #1701727 is a reply to message #1701623] Wed, 15 July 2015 05:26 Go to previous messageGo to next message
Ed Merks wrote on Tue, 14 July 2015 09:42
well we have set
* -text
in the .gitattributes, as it is recommended by GIT, to prevent any line ending conversion... but unfortunately that is ignored by JGIT as described in the bug ticket above.
that is indeed true, but even if that would be the case. It would not be a problem for anybody, whereas broken files that were incorrectly detected as text files by GIT are a serious problem which you might not even notice.
But this is a general GIT/SVN problem ...
I will do so...
thanks for your feedback.
Re: autocrlf on GitCloneTask [message #1710727 is a reply to message #1701727] Thu, 08 October 2015 13:09 Go to previous messageGo to next message
Hey Michael,
could you please share the bug id? I wasn't able to find it. I do have the same issue with some resource files Sad
Kon
Re: autocrlf on GitCloneTask [message #1710756 is a reply to message #1710727] Thu, 08 October 2015 23:50 Go to previous message
Kon,
Note that its important specify which file types are binary because
those should not be processed. That can be specified with a preference
task for /instance/org.eclipse.team.core/file_types
In any case, this is the bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=474647
On 08/10/2015 7:09 PM, kon f wrote:
> Hey Michael,
> the same issue with some resource files :(
> Best regards,
> Kon
Previous Topic:Guidance Required for Eclipse Luna checkstyle Configuration
Next Topic:Creating setup files in existing Eclipse version
Current Time: Sun Jul 20 14:45:24 EDT 2025
Powered by FUDForum. Page generated in 0.09347 seconds
