Home » Modeling » TMF (Xtext) » How to inject a mocked dependency into the tested instance?
How to inject a mocked dependency into the tested instance? [message #1701182] Thu, 09 July 2015 12:51 Go to next message
Hey Smile
my StringGenerator class accesses the workspace being able to look up certain information from different files in the workspace. Now I'm writing an isolated unit test that should work without the eclipse workspace. Unfortunately I'm not able to inject the mocked dependency.
How do I inject the mocked instance of ResourceLookUp into the StringGenerator instance?
The class to be tested:
class StringGenerator {
	@Inject extension ResourceLookUp resourceLookUp
	def dispatch initStep(TestRequired o) '''
		Test Case «o.name.testNameLookUp» (Test Case ID: «o.name») has been successfully performed.'''
The Test:
import static org.mockito.Mockito.*
@RunWith(JUnitParamsRunner)
class StringGeneratorInitialisationTest {
	@Inject extension ValidationTestHelper validationTestHelper = new ValidationTestHelper
	@Inject extension StringGenerator stringGenerator = new StringGenerator
	@Inject extension ParseHelper<Model> parseHelper = new ParseHelper
	@Before
	def void before() {
		var i = new TestStandaloneSetup().createInjectorAndDoEMFRegistration
		i.injectMembers(parseHelper)
		val resourceLookUp = mock(ResourceLookUp)
		when(resourceLookUp.testNameLookUp("TEST XYZ")).thenReturn("TEST NAME AS STRING")
		// how do I get this mocked ResourceLookUp instances injected into StringGenerator instance?
		i.injectMembers(stringGenerator)
		i.injectMembers(validationTestHelper)
	 // here comes my test ....
I was playing around with the debugger but could not find any solution Sad
Thank you!
Kon
Re: How to inject a mocked dependency into the tested instance? [message #1701196 is a reply to message #1701182] Thu, 09 July 2015 15:04 Go to previous messageGo to next message
simply use a StandaloneSetup that uses a Module that has an instance binding for the thing you are looking for
Re: How to inject a mocked dependency into the tested instance? [message #1701236 is a reply to message #1701196] Fri, 10 July 2015 03:48 Go to previous messageGo to next message
Hey Christian,
thank you for your reply Smile Do you have an example how to achieve this? I tried the following but could not find a Guice-Factory to wrap the actual instance with the Binding type.
Binding<ResourceLookUp> instance = // WRAP resourceLookUp instance with Binding interface
i.bindings.put(TypeLiteral.get(ResourceLookUp),  instance)
I also thought of getting the modul (couldn't find the it in IjectorImpl) and use:
bind(ResourceLookUp).toInstance(resourceLookUp)
Thank you! Smile
Kon
Re: How to inject a mocked dependency into the tested instance? [message #1701237 is a reply to message #1701236] Fri, 10 July 2015 03:52 Go to previous messageGo to next message
no i have not. you have to read, understand and modify the code of the standalonesetup.createinjector yourself
Re: How to inject a mocked dependency into the tested instance? [message #1701247 is a reply to message #1701237] Fri, 10 July 2015 04:45 Go to previous messageGo to next message
Hey Christian,
thank you again! I actually thought I that I could simply exchange the map value from the bindings map. But I'm not sure if this is an intended. So I did what you suggested:
@Before
	def void before() {
		val i = new TestStandaloneSetup() {
			override createInjector() {
				Guice.createInjector(new TestRuntimeModule() {
					override configure(Binder binder) {
						super.configure(binder)
						binder.bind(ResourceLookUp).toInstance(resourceLookUp)
		}.createInjectorAndDoEMFRegistration
Kon
Re: How to inject a mocked dependency into the tested instance? [message #1702578 is a reply to message #1701247] Thu, 23 July 2015 07:47 Go to previous messageGo to next message
Hey,
noticed that the injection does not work completely as expected. The StringGenerator class gets the mocked ResourceLookUp instance.
but if the test-case contains an error assertion like model.assertNoErrors my TestValidator gets called. Unfortunately the ResourceLookUp instance there is not the mocked one Sad
class TestValidator extends AbstractTestValidator {
It somehow ignores my guice setup:
val mockedResourceLookUp = mock(ResourceLookUp)
when(mockedResourceLookUp.testNameLookUp("TEST XYZ")).thenReturn("TEST NAME AS STRING")
bind(ResourceLookUp).toInstance(mockedResourceLookUp)
and uses the "real" class for injection. Is there anything spezial about the dependency injection for the validator class?
Thank you.
Kon
Re: How to inject a mocked dependency into the tested instance? [message #1702581 is a reply to message #1702578] Thu, 23 July 2015 07:59 Go to previous messageGo to next message
the validators are created early
Re: How to inject a mocked dependency into the tested instance? [message #1702884 is a reply to message #1702581] Mon, 27 July 2015 04:35 Go to previous message
Hey Christian,
if I let my test class derive from AbstractXtextTests, it works as expected Smile
class StringGeneratorInitialisationTest extends AbstractXtextTests {
Thank you!
Previous Topic:How to align text elements of more lines
Next Topic:global scope and importedURI
Current Time: Sun Jul 20 10:18:27 EDT 2025
Powered by FUDForum. Page generated in 0.04624 seconds
