Home » Modeling » UML2 » memberEnds not correctly ordered?
memberEnds not correctly ordered? [message #1701048] Wed, 08 July 2015 17:58 Go to next message
Hi there,
I'm having an issue with AssociationClass' memberEnds, and I'm not quite sure if it's a bug or not.
The order of two memberEnds in the XMI and in the model differs, although it's not supposed to.
I've attached a simple model with which I have the issue. The XMI has an AssociationClass C with two memberEnds e1 and e2. The unserialized list contains e2 and e1 on my machine.
Can anyone help me, or tell me if it's a bug?
Thanks!
Raphael
Re: memberEnds not correctly ordered? [message #1701059 is a reply to message #1701048] Thu, 09 July 2015 02:15 Go to previous messageGo to next message
I see e1 then e2 consistently.
The AssociationClass E has three ends; e1, e2, e21
Ed Willink
On 08/07/2015 22:58, Raphael B wrote:
> Hi there,
> Thanks!
> Raphael
Re: memberEnds not correctly ordered? [message #1701127 is a reply to message #1701059] Thu, 09 July 2015 09:18 Go to previous messageGo to next message
The file I uploaded was not the "simple" one, but I still get a wrong order, unlike you.
I'm attaching a model that can be opened directly in Papyrus, along with a screenshot showing the wrong order. Just to prove that I'm not dreaming Smile
Perhaps I need to provide a specific option to the XMI reader.
  • Attachment: model.uml
    (Size: 3.71KB, Downloaded 329 times)
  • Attachment: memberEnds.jpg
    (Size: 168.32KB, Downloaded 247 times)
Re: memberEnds not correctly ordered? [message #1701133 is a reply to message #1701127] Thu, 09 July 2015 09:35 Go to previous messageGo to next message
You complained only about the serialization order which is not at fault.
There does seem to be an issue with the rendering order in the
Properties View.
If you adjust the order in the Properties View and save you will see
that EMF/UML2 uses attribute rather than element style:
i.e
<packagedElement xmi:type="uml:AssociationClass"
xmi:id="_18_1_85c026e_1435345554139_248855_13811" name="C"
memberEnd="_18_1_85c026e_1435345554139_870795_13812
_18_1_85c026e_1435345554140_858779_13813"
navigableOwnedEnd="_18_1_85c026e_1435345554140_858779_13813
_18_1_85c026e_1435345554139_870795_13812">
rather than
<packagedElement xmi:type='uml:AssociationClass'
xmi:id='_18_1_85c026e_1435345554139_248855_13811' name='C'>
<memberEnd
xmi:idref='_18_1_85c026e_1435345554139_870795_13812'/>
<memberEnd
xmi:idref='_18_1_85c026e_1435345554140_858779_13813'/>
<navigableOwnedEnd
<navigableOwnedEnd
so I suspect that UML2 (or possibly EMF) has failed to respect the
element-style ordering.
Please raise a UML2 Bugzilla.
Ed Willink
> I'm attaching a model that can be opened directly in Papyrus, along with a screenshot showing the wrong order. Just to prove that I'm not dreaming :)
Re: memberEnds not correctly ordered? [message #1701138 is a reply to message #1701133] Thu, 09 July 2015 09:49 Go to previous message
Actually, I complained about the deserialization. I use UML2 only to read XMI files and parse UML models.
Sure, I'll go ahead. Thanks!
Raphael
Previous Topic:[Searching] for UML-Lib to draw an Component diagram
Next Topic:Resolving relative URI's in references
Current Time: Sat Jul 19 20:11:03 EDT 2025
Powered by FUDForum. Page generated in 0.29102 seconds
