Re: [ETL]Creating xmi file from ETL transformation output file(.model) [message #1838126 is a reply to message #1701206] |
Tue, 16 February 2021 20:20   |
Hello Everyone,
I have a related question. How can I generate XMI output when running a standalone ETL application?
I reproduced the above YouTube example and I got DBInstance(1).model (please see the attached). I suppose this is a valid XMI file.
Then I tried to execute the same transformation as a standalone application using the following code.
package test;
import java.nio.file.Path;
import java.nio.file.Paths;
import org.eclipse.epsilon.common.util.StringProperties;
import org.eclipse.epsilon.emc.emf.EmfModel;
import org.eclipse.epsilon.etl.launch.EtlRunConfiguration;
public class Main {
public static void main(String[] args) throws Exception {
String mapping = "OO2DB.etl";
String sourceMetaModel1 = "OO.ecore";
String sourceMetaModel2 = "TM.ecore";
String targetMetaModel1 = "DB.ecore";
String targetMetaModel2 = "SimpleTrace.ecore";
String sourceModel1 = "OOInstance.model";
String sourceModel2 = "OO2DB.model";
String targetModel1 = "DBInstance.model";
String targetModel2 = "Trace.model";
String sourceName1 = "OO";
String sourceName2 = "OO2DB";
String targetName1 = "DB";
String targetName2 = "Trace";
Path root = Paths.get(Main.class.getResource("").toURI());
Path modelsRoot = root.getParent().resolve("models");
String sourceMetaModelPath1 = modelsRoot.resolve(sourceMetaModel1).toAbsolutePath().toUri().toString();
String sourceMetaModelPath2 = modelsRoot.resolve(sourceMetaModel2).toAbsolutePath().toUri().toString();
String targetMetaModelPath1 = modelsRoot.resolve(targetMetaModel1).toAbsolutePath().toUri().toString();
String targetMetaModelPath2 = modelsRoot.resolve(targetMetaModel2).toAbsolutePath().toUri().toString();
String sourceModelPath1 = modelsRoot.resolve(sourceModel1).toAbsolutePath().toUri().toString();
String sourceModelPath2 = modelsRoot.resolve(sourceModel2).toAbsolutePath().toUri().toString();
String targetModelPath1 = modelsRoot.resolve(targetModel1).toAbsolutePath().toUri().toString();
String targetModelPath2 = modelsRoot.resolve(targetModel2).toAbsolutePath().toUri().toString();
StringProperties sourceProperties1 = new StringProperties();
sourceProperties1.setProperty(EmfModel.PROPERTY_NAME, sourceName1);
sourceProperties1.setProperty(EmfModel.PROPERTY_FILE_BASED_METAMODEL_URI, sourceMetaModelPath1);
sourceProperties1.setProperty(EmfModel.PROPERTY_MODEL_URI, sourceModelPath1);
StringProperties sourceProperties2 = new StringProperties();
sourceProperties2.setProperty(EmfModel.PROPERTY_NAME, sourceName2);
sourceProperties2.setProperty(EmfModel.PROPERTY_FILE_BASED_METAMODEL_URI, sourceMetaModelPath2);
sourceProperties2.setProperty(EmfModel.PROPERTY_MODEL_URI, String sourceModelPath2);
StringProperties targetProperties1 = new StringProperties();
targetProperties1.setProperty(EmfModel.PROPERTY_NAME, targetName1);
targetProperties1.setProperty(EmfModel.PROPERTY_FILE_BASED_METAMODEL_URI, targetMetaModelPath1);
targetProperties1.setProperty(EmfModel.PROPERTY_MODEL_URI, targetModelPath1);
StringProperties targetProperties2 = new StringProperties();
targetProperties2.setProperty(EmfModel.PROPERTY_NAME, targetName2);
targetProperties2.setProperty(EmfModel.PROPERTY_FILE_BASED_METAMODEL_URI, targetMetaModelPath2);
targetProperties2.setProperty(EmfModel.PROPERTY_MODEL_URI, targetModelPath2);
targetProperties1.setProperty(EmfModel.PROPERTY_READONLOAD, "false");
targetProperties1.setProperty(EmfModel.PROPERTY_STOREONDISPOSAL, "true");
targetProperties2.setProperty(EmfModel.PROPERTY_READONLOAD, "false");
targetProperties2.setProperty(EmfModel.PROPERTY_STOREONDISPOSAL, "true");
EtlRunConfiguration runConfig = EtlRunConfiguration.Builder()
.withScript(root.resolve(mapping))
.withModel(new EmfModel(), sourceProperties1)
.withModel(new EmfModel(), sourceProperties2)
.withModel(new EmfModel(), targetProperties1)
.withModel(new EmfModel(), targetProperties2)
.withProfiling()
.build();
runConfig.run();
runConfig.dispose();
I generated DBInstance(2). Which is, if I understand correctly, not in XMI format.
How can I fix this?
Dmitriy
[Updated on: Thu, 18 February 2021 07:05] by Moderator
FUDForum. Page generated in 0.05066 seconds
