Home » Eclipse Projects » Oomph » git clone location
git clone location [message #1700653] Mon, 06 July 2015 05:01 Go to next message
I'd like to specify the location where the git repository is to be cloned.
I tried using "absolute folder location", but in that case it looks like
Oomph expects to find an already cloned repository there (and by the
way, if that's not the case, there's no error feedback, simply the
workspace stays empty and only if I try to run the setup tasks from the
workspace I get the error).
So what's the correct way to specify "please clone the git repository in
this specific path"?
thanks in advance
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: git clone location [message #1700658 is a reply to message #1700653] Mon, 06 July 2015 05:29 Go to previous messageGo to next message
maybe: "git clone" -> location -> ex.: ${installation.location}/git ?
bye
> Hi
> thanks in advance
> Lorenzo
Re: git clone location [message #1700660 is a reply to message #1700658] Mon, 06 July 2015 05:49 Go to previous messageGo to next message
On 06/07/2015 11:29, Ralf Reinders wrote:
> bye
>> Hi
>> cloned.
>> thanks in advance
>> Lorenzo
Apparently, it works only if I choose another option like
${git.container.root/}${@id.remoteURI|gitRepository/}
and set the root git-container folder accordingly.
But I found it misleading that choosing an absolute path has a different
semantics, i.e., "the repository must have already been cloned" :)
cheers
Lorenzo
Xtext Book:
Re: git clone location [message #1700664 is a reply to message #1700660] Mon, 06 July 2015 06:17 Go to previous messageGo to next message
Am 06.07.2015 um 11:49 schrieb Lorenzo Bettini:
At the time the GitCloneTask is performed it already has an absolute path, no matter how this was computed (e.g. what
attribute rule you picked and what what rule-specific properties you've entered). Can you please outline the exacts
steps needed to reproduce the problem?
Cheers
/Eike
http://www.esc-net.de
Re: git clone location [message #1700705 is a reply to message #1700664] Mon, 06 July 2015 10:37 Go to previous messageGo to next message
Just like the workspace location, the clone location is determined by
rules. Those rules include being able to decide exactly the location
of the clone, having all the clones in some common root folder, or
having the clones in a folder relative to the installation. We mostly
use/test the latter, and it's the default. If the other rules don't work
for some reason, please open a bugzilla. If some other rule makes
sense (e.g., it's nested in the workspace), we could add it. But in the
end, one shouldn't need to be defining your own approach within your
project setup, because then there will be no uniformity across projects
where some respect the general rule, and others do some other arbitrary
thing...
> path, no matter how this was computed (e.g. what attribute rule you
> please outline the exacts steps needed to reproduce the problem?
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: git clone location [message #1700723 is a reply to message #1700664] Mon, 06 July 2015 12:13 Go to previous messageGo to next message
Hi Eike
here are the steps:
- select any project, e.g., Oomph itself
- in the variables dialog select from the dropdown box "located in the
specified absolute folder location"
- then specify an absolute path in the text field of an existing
directory, e.g., "/home/myuser/tmp/git" (where "git" exists but it's empty)
the IDE is installed and started and then no other feedback is given (no
animated icon is shown in the status bar). Now try to run the setup
tasks manually and a dialog is shown with this exception (so it looks
like when an absolute path is specified then it expects the repository
has already been cloned):
java.lang.Exception:
org.eclipse.jgit.errors.RepositoryNotFoundException: repository not
found: /home/bettini/tmp/git
at
org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.isNeeded(GitCloneTaskImpl.java:660)
at
org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.initNeededSetupTasks(SetupTaskPerformer.java:1496)
at
org.eclipse.oomph.setup.ui.wizards.ConfirmationPage.initNeededSetupTasks(ConfirmationPage.java:325)
at
org.eclipse.oomph.setup.ui.wizards.ConfirmationPage.enterPage(ConfirmationPage.java:229)
at
org.eclipse.oomph.setup.ui.wizards.SetupWizard.pageChanged(SetupWizard.java:404)
at org.eclipse.jface.wizard.WizardDialog$9.run(WizardDialog.java:1505)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at
org.eclipse.jface.wizard.WizardDialog.firePageChanged(WizardDialog.java:1502)
at org.eclipse.jface.wizard.WizardDialog.update(WizardDialog.java:1308)
at
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1234)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1208)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1197)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1194)
at
org.eclipse.oomph.setup.ui.wizards.SetupWizardPage.advanceToNextPage(SetupWizardPage.java:153)
at
org.eclipse.oomph.setup.ui.wizards.VariablePage$5.run(VariablePage.java:556)
at org.eclipse.oomph.ui.UIUtil$5.run(UIUtil.java:539)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3794)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3433)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at
org.eclipse.oomph.setup.ui.wizards.SetupWizard.openDialog(SetupWizard.java:487)
at
org.eclipse.oomph.setup.ui.wizards.SetupWizard$Updater.openDialog(SetupWizard.java:1239)
at
org.eclipse.oomph.setup.presentation.handlers.PerformHandler.run(PerformHandler.java:45)
at
org.eclipse.oomph.setup.presentation.handlers.AbstractDropdownItemHandler.execute(AbstractDropdownItemHandler.java:50)
at
org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at
org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at
org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at
org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at
org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at
org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at
org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
at
org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1327)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at
at
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: org.eclipse.jgit.errors.RepositoryNotFoundException:
repository not found: /home/bettini/tmp/git
at
org.eclipse.jgit.lib.BaseRepositoryBuilder.build(BaseRepositoryBuilder.java:581)
at org.eclipse.jgit.api.Git.open(Git.java:116)
at org.eclipse.jgit.api.Git.open(Git.java:99)
at
org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.isNeeded(GitCloneTaskImpl.java:619)
... 73 more
Xtext Book:
Re: git clone location [message #1700734 is a reply to message #1700723] Mon, 06 July 2015 13:30 Go to previous messageGo to next message
Lorenzo,
That's because you need to specify the entire folder name for this rule,
including the name of the folder for the git clone. You've specified a
folder that isn't empty and isn't an existing clone, so no clone can be
created there.
> Hi Eike
> here are the steps:
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 73 more
Re: git clone location [message #1700843 is a reply to message #1700734] Tue, 07 July 2015 10:23 Go to previous message
On 06/07/2015 19:30, Ed Merks wrote:
> Lorenzo,
> created there.
OK, now I got it :)
thanks
Lorenzo
Xtext Book:
Previous Topic:Passing VM args from the self extracting archive to eclipse-inst.exe
Next Topic:setup:VariableTask
Current Time: Sun Jul 20 09:01:53 EDT 2025
Powered by FUDForum. Page generated in 0.25327 seconds
