Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] ComboBox CellEditor
[EMF Forms] ComboBox CellEditor [message #1700597] Sat, 04 July 2015 08:12 Go to next message
Hey,
i would like to add a combobox as a cell in a table. I have searched for already implemented ones but was not succesful. The only thing i found was "ExtendedComboBoxCellEditor" from org.eclipse.emf.common.ui but it does not work and looks pretty outdated right?
So i tried to implement one by myself. The model to target part works fine, if i change the model value for example in the dialog the combo box gets updated correctly. But if i change the value in the combo box and click anywhere then the old value returns.
It looks like the "applyEditorValue()" part does not work correctly.
The "fireValueChange(...)" does not have any listeners but its the same with your BooleanCellEditor and this one is working fine. Where exactly is the ecore model updated after a celleditor change? Do i have to data bind anything more or add listeners?
Greetings,
Tobias
Re: [EMF Forms] ComboBox CellEditor [message #1700832 is a reply to message #1700597] Tue, 07 July 2015 09:31 Go to previous messageGo to next message
Databinding here works as follows:
EMFForms will call getValueProperty#observe and will hand in an instance of the ComboBoxCellEditor, which is to be observed, as the source.
This will be bound to the edited model value. When either the model or the target changes, the UpdateValueStrategy will be used to set the values on the target/model.
As far as I can see the problem with your code is, that in the TargetToModelStrategy a String is returned in the convert method. However you can't set a string as the enum value on the model, so you end up with an unexecutable command. You have to convert this String and return the result.
You can set a break point in the convert method and follow the execution path to see how the model is updated.
Best regards
Johannes
Re: [EMF Forms] ComboBox CellEditor [message #1701289 is a reply to message #1700832] Fri, 10 July 2015 10:07 Go to previous messageGo to next message
thanks for your fast reply.
I got it to work now, but with a very bad solution which works only for the one enum type i am currently using:
public Object convert(final Object value) {
	int getValue = (int) ComboBoxCellEditor.this.getValue();
	return VariableType.get(getValue);
My question is now if there is any way to make it generic? Working for every EEnum/Enumerator.
I played around with the EEnum i get from the feature but wasnt able to get the fitting Enumerator from it. And the Enumerator interface does not provide the .get(...) method which i need for conversion.
Is there any easy way to implement this?
Greetings,
Tobi
Re: [EMF Forms] ComboBox CellEditor [message #1701389 is a reply to message #1701289] Mon, 13 July 2015 04:06 Go to previous message
I think the easiest way is to directly set all possible Enumerators as the input of the combo and set a suitable label provider.
You can get the Enumerators from the EEnum like this:
final EEnum eEnum = (EEnum) feature.getEType();
final List<Enumerator> input = new ArrayList<Enumerator>();
for (final EEnumLiteral literal : eEnum.getELiterals()) {
	input.add(literal.getInstance());
But you could also use the other EEnum methods to get a specific EEnumLiteral based on your String and use getInstance to get the Enumerator.
Johannes
Previous Topic:Question: How to import an XMI model into EMFStore Model Explorer
Next Topic:MatchService.doMatch ConcurrentModificationException
Current Time: Sun Jul 20 06:01:40 EDT 2025
Powered by FUDForum. Page generated in 0.05023 seconds
