Home » Eclipse Projects » Oomph » Where are the supported annotations documented?
Where are the supported annotations documented? [message #1700565] Fri, 03 July 2015 14:53 Go to next message
When configuring tasks it becomes very easy and intuitive because it uses the EMF model. So the context menu only offers what makes sense in that context.
But the same doesn't happen with the Annotations. I would expect that there is some wiki or similar where I can find all supported annotation for all tasks. However I followed all links from the wiki and I didn't find anything.
Does anyone know where I can find this information?
Thanks in advance.
Re: Where are the supported annotations documented? [message #1700567 is a reply to message #1700565] Fri, 03 July 2015 15:28 Go to previous messageGo to next message
Silvestre,
Comments below.
> in that context.
Yes, you can only create syntactically valid instances...
Indeed. But we ought to make that smarter with specializations in the
child creation of the item providers...
Indeed, and a few months ago I did start working on documentation (along
with a nice generator to make it cool and maintainable)... But then all
the release pressures took priority, and now some personal issues take
priority...
No, because it just doesn't exist.
No, it's basically completely undocumented at this point, so only
examples of setups serve as a guide, or worse yet, looking at code...
Sorry, it will be a while yet...
> Thanks in advance.
Re: Where are the supported annotations documented? [message #1700569 is a reply to message #1700567] Fri, 03 July 2015 15:58 Go to previous messageGo to next message
Ok, I see.
I wonder if is there some way I can at least know what annotations exist so I can know where to look in the code.
For instance, if I checkout the oomph source code, can I look for all classes implementing a specific interface, or can I look for references to some method?
Thanks.
Ed Merks wrote on Fri, 03 July 2015 15:28
Silvestre,
Comments below.
> in that context.
priority...
> Thanks in advance.
Re: Where are the supported annotations documented? [message #1700581 is a reply to message #1700569] Sat, 04 July 2015 02:54 Go to previous messageGo to next message
Am 03.07.2015 um 21:58 schrieb Silvestre Martins:
> Ok, I see.
There are some interfaces that declare annotation constants:
org.eclipse.oomph.base.BaseAnnotationConstants
org.eclipse.oomph.setup.AnnotationConstants
org.eclipse.oomph.setup.EAnnotationConstants
Other annotations are declared directly in the classes that exclusively use them:
org.eclipse.oomph.targlets.internal.core.listeners.PomModulesUpdater
org.eclipse.oomph.targlets.internal.core.listeners.PomArtifactUpdater
org.eclipse.oomph.targlets.internal.core.listeners.TargetDefinitionGenerator
Another way to find the usage of annotations is the Call Hierarchy of these two methods:
org.eclipse.oomph.base.ModelElement.getAnnotations()
org.eclipse.oomph.base.ModelElement.getAnnotation(String)
I hope that helps. If you find the time you could start a new wiki page to collect your findings ;-)
Cheers
/Eike
http://www.esc-net.de
> Thanks.
>> Silvestre,
>> Comments below.
>> > When configuring tasks it becomes very easy and intuitive because it > uses the EMF model. So the context menu only
>> offers what makes sense > in that context.
>> > But the same doesn't happen with the Annotations. Indeed. But we ought to make that smarter with specializations in
>> the child creation of the item providers...
>> > I would expect that there is some wiki or similar where I can find all > supported annotation for all tasks.
>> Indeed, and a few months ago I did start working on documentation (along with a nice generator to make it cool and
>> maintainable)... But then all the release pressures took priority, and now some personal issues take priority...
>> No, it's basically completely undocumented at this point, so only examples of setups serve as a guide, or worse yet,
>> looking at code... Sorry, it will be a while yet...
>> > Thanks in advance.
Re: Where are the supported annotations documented? [message #1700594 is a reply to message #1700581] Sat, 04 July 2015 05:29 Go to previous messageGo to next message
Ok, I'll try.
Thanks.
Re: Where are the supported annotations documented? [message #1700681 is a reply to message #1700581] Mon, 06 July 2015 08:42 Go to previous messageGo to next message
Hi, Eike,
I have to ask: how is it decided whether some particle of information
is modeled explicitly in the pertinent setup Ecore model or whether it
is modeled in more ad hoc fashion as an annotation?
Also, annotations could be ever so much helpful if I could define my
own and plug in (via an extension point or something) an annotation
processor. Preferably with the option to process before the main loop
that interprets/expands the setup model. I have a use case for an
annotation that would calculate variable values so that I don't have to
repeat them in every one of three streams for dozens of
sub-sub-projects.
Christian
>> Ok, I see.
>> to some method?
> use them:
> these two methods:
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Thanks.
>>> Silvestre,
>>> Comments below.
>>> (along with a nice generator to make it cool and maintainable)... But
>>>> Thanks in advance.
Re: Where are the supported annotations documented? [message #1700684 is a reply to message #1700681] Mon, 06 July 2015 09:05 Go to previous message
Am 06.07.2015 um 14:42 schrieb Christian W. Damus:
> Hi, Eike,
> I have to ask: how is it decided whether some particle of information is modeled explicitly in the pertinent setup
> Ecore model or whether it is modeled in more ad hoc fashion as an annotation?
That has been decided by the team on a case by case basis. Maybe Ed remembers some general rules ;-)
> Also, annotations could be ever so much helpful if I could define my own and plug in (via an extension point or
> something) an annotation processor. Preferably with the option to process before the main loop that
> interprets/expands the setup model. I have a use case for an annotation that would calculate variable values so that
> I don't have to repeat them in every one of three streams for dozens of sub-sub-projects.
The more general facility would probably "just" a pluggable model preprocessor mechanism. On the one hand that sounds
very powerful and interesting, on the other hand it sounds pretty scary if, for example, an arbitrary plugin can hook in
a preprocessor that sets disabled=true on all tasks, always. I'm not sure how we could control the ultimate force once
we've passed it to the public.
Cheers
/Eike
> Cheers,
> Christian
>>> Ok, I see.
>> Cheers
>> /Eike
>>> Thanks.
>>>> Silvestre,
>>>> Comments below.
>>>> yet, looking at code... Sorry, it will be a while yet...
>>>>> Thanks in advance.
Previous Topic:Targlet cannot be resolved
Next Topic:Passing VM args from the self extracting archive to eclipse-inst.exe
Current Time: Sun Jul 20 14:09:11 EDT 2025
Powered by FUDForum. Page generated in 1.07594 seconds
