Home » Eclipse Projects » RCP Testing Tool » RRCPT does not add the URL (update sites) when run the AUT.
RRCPT does not add the URL (update sites) when run the AUT. [message #1699654] Thu, 25 June 2015 10:42 Go to next message
I would like to ask two question:
1 ) Why RRCPT not add the update sites url of my Eclipse when running it through RRCPT.
I have checked it by running the APP without RRCPT and the urls are ok (by default), but not when running it with RRCPT.
Is it a bug or am I missing something? I have attached a screenshot of both situations in order to clarify.
2) Is there a problem when a make a test which restart the AUT? Basically, when I run this kind of test, the AUT does work similar as the first run.
Agustin Celentano
Re: RRCPT does not add the URL (update sites) when run the AUT. [message #1700363 is a reply to message #1699654] Thu, 02 July 2015 03:38 Go to previous messageGo to next message
Hi Agustin,
1) Information about update site links is stored in Eclipse workspace.
Since AUT workspace differs from a workspace which you use when you run your Eclipse standalone, you see two different "pictures".
2) There shouldn't be any problems with AUT restarts, could you please give more details?
Kins regards,
Ulyana.
Re: RRCPT does not add the URL (update sites) when run the AUT. [message #1701473 is a reply to message #1700363] Mon, 13 July 2015 11:02 Go to previous messageGo to next message
Hi Ulyana,
2) When I restart the AUT through a test, I get this exception.
Failed to close report node
at restart-studio (/studio-q7-sanity/recorder.test:1)
Connection is not Available
Stack Trace: Connection is not Available
java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267)
at org.eclipse.rcptt.ecl.internal.core.EMFStreamPipe.take(EMFStreamPipe.java:91)
at org.eclipse.rcptt.ecl.client.tcp.EclTcpSession.writeOutput(EclTcpSession.java:199)
at org.eclipse.rcptt.ecl.client.tcp.EclTcpSession.access$6(EclTcpSession.java:196)
at org.eclipse.rcptt.ecl.client.tcp.EclTcpSession$1.run(EclTcpSession.java:96)
at java.lang.Thread.run(Thread.java:745)
It seems to lose the AUT connection
Agustin Celentano
Re: RRCPT does not add the URL (update sites) when run the AUT. [message #1701567 is a reply to message #1701473] Tue, 14 July 2015 04:09 Go to previous message
Do you restart AUT manually or with the command restart-aut?
Could you please attach the whole ECL code?
Try to add the command wait-until-eclipse-is-ready after code which restarts AUT.
Please let me know if it helps.
Previous Topic:How to set relative path in ECL
Next Topic:How to edit global time limit?
Current Time: Sun Jul 20 02:38:37 EDT 2025
Powered by FUDForum. Page generated in 0.03781 seconds
