Home » Language IDEs » Java Development Tools (JDT) » find references slow(Find references function slower than before)
find references slow [message #1699436] Wed, 24 June 2015 06:36 Go to next message
Version: Luna Service Release 2 (4.4.2)
Build id: 20150219-0600
I noticed find references (CTRL + SHIFT + G) is a number of times slower. It used to be really quick, under a second. Now it takes over 20 seconds. The progress bar quickly gets to half way then stays there till the search is finished.
I wondered if it might be my workspace, so I tried tidying it. Then I tried creating a new workspace with just the one project. I then re-installed eclipse. Still slow.
Any ideas?
Re: find references slow [message #1699643 is a reply to message #1699436] Thu, 25 June 2015 09:11 Go to previous messageGo to next message
Degradation from 1 sec to 20 sec. is certainly worth investigation.
Can you reproduce the difference with two installations that only differ in the Eclipse version? (Same set of plug-ins installed? Identical workspaces?)
If you succeed to reproduce in this way, the workspace and your exact configuration should provide a good test bed for performance analysis.
OTOH, a degradation of this magnitude is more likely to be caused by a fundamental difference (different plugins, different configuration).
Additionally, it would be good if you'd test whether Mars (released yesterday) suffers from the same problem!
best,
Stephan
Re: find references slow [message #1699669 is a reply to message #1699643] Thu, 25 June 2015 12:27 Go to previous message
Apologies, forgot to update forum.
After some asking around it turns out to be Panda anti-virus. When hitting ctrl+shift+g Panda would kick in and block.
I've ended up killing Panda. I might be exposed to viruses but at least I can actually do something now!!
Previous Topic: code en java de signature-based detection
Next Topic:Compile error: Eclipse confuses Type with Window.Type
Current Time: Sat Jul 19 19:49:00 EDT 2025
Powered by FUDForum. Page generated in 0.03792 seconds
