Home » Modeling » QVT-OML » Run qvto transformation(I need run a transformation)
Run qvto transformation [message #1699624] Thu, 25 June 2015 07:36 Go to next message
Which are the steps to execute a transformation in Eclipse QVTo?
I followed the steps in http://www.levysiqueira.com.br/2011/01/eclipse-qvto-hello-world/ but i work with java MoDisco metamodel therefore i did the following:
1- Create a new EMF Project (in "File->New->Project" and "Eclipse Modeling Framework->Empty EMF Project"). Create your metamodel or copy-it.
I copy the java metamodel to project workspace.
http://www.subeimagenes.com/img/1-1358985.png
2- Create a new "EMF Generator Model" (right click the metamodel in the package explorer, "New->Other" and "Eclipse Modeling Framework->EMF Generator Model").
i did it
http://www.subeimagenes.com/img/2-1358989.png
3- Open the genmodel (it is normally opened automatically) and right click in its root and select "Generate All". The source code for a basic model editor will be generated.
http://www.subeimagenes.com/img/3-1359412.png
As can you see, i recieve an error
Why?
Thanks.
Re: Run qvto transformation [message #1699843 is a reply to message #1699624] Sat, 27 June 2015 01:41 Go to previous message
"As can you see, i recieve an error "
I see no error.
QVTo provdes the Simple UML to RDBMS example. Understand it and emulate it.
Ed Willink
On 25/06/2015 12:36, Gonzalo Bressan Zuber wrote:
> copy-it.
> i did it
> Why?
> Thanks.
Previous Topic:Map one object into two models
Next Topic:objectsOfType problem in Mars release
Current Time: Sat Jul 19 09:31:58 EDT 2025
Powered by FUDForum. Page generated in 0.03145 seconds
