Home » Modeling » TMF (Xtext) » using common terminal names as keywords(parse errors when using INT, STRING as keywords)
using common terminal names as keywords [message #1699292] Tue, 23 June 2015 05:16 Go to next message
I am trying to use 'INT' and 'STRING' as keywords. When I write a sample DSL code, I see the errors saying 'String literal is not properly closed' when STRING is used and the error saying **For input string: "INT"** when INT is used as a keyword.
For some reason ID does not have this problem.
Ajay
Re: using common terminal names as keywords [message #1699346 is a reply to message #1699292] Tue, 23 June 2015 09:58 Go to previous messageGo to next message
can you give a complete grammar and sample model
[Updated on: Tue, 23 June 2015 10:02] by Moderator
Re: using common terminal names as keywords [message #1699388 is a reply to message #1699346] Tue, 23 June 2015 19:07 Go to previous messageGo to next message
Thanks for the quick reply. Please see the minimal grammar below that produces the errors previously mentioned:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "eclipse.org/emf/2002/Ecore" as ecore
generate myDsl "xtext.org/example/mydsl/MyDsl"
MyDsl :  (sc+=Section)+ ;
Section : '<'
	 pm='parameter' name=ID (pas=ParamAttrs)? '/>'
ParamAttrs : name='type' '=' tm=Singletype ;
Singletype :
     name='INT'
    | name='FLOAT'
    | name='STRING'
    |  name='ID'
Example DSL code:
<parameter in type=STRING /> (shows the error String literal is not properly closed)
<parameter in type=INT /> (shows the error For input string: "INT")
<parameter in type=ID /> (No errors here)
Re: using common terminal names as keywords [message #1699394 is a reply to message #1699388] Wed, 24 June 2015 00:00 Go to previous messageGo to next message
The Problem comes from the String/IntValueConverters. these converters are called for terminal rule called STRING and INT. by using keywords you are introducing these.
the solution may be to introduce alternate terminals or a different value converter service.
Singletype :
name=STN
terminal STN: 'INT'|'FLOAT'|'STRING'|'ID';
you may have to adopt the content assist.
Re: using common terminal names as keywords [message #1699398 is a reply to message #1699394] Wed, 24 June 2015 00:45 Go to previous message
Introducing alternate terminals worked. Thank you!
Previous Topic:Call a jar library function from generated code in src-gen
Next Topic:Includes, global constants in DSL files
Current Time: Sat Jul 19 17:36:25 EDT 2025
Powered by FUDForum. Page generated in 0.03958 seconds
