Home » Modeling » EMF » Copy&paste / drag&drop into (different) FeatureMap attributes
Copy&paste / drag&drop into (different) FeatureMap attributes [message #1699019] Fri, 19 June 2015 10:11 Go to next message
It doesn't seem to be possible to paste / drop elements into a FeatureMap attribute from any other attribute. It only works if an elements is copied/dragged from the same attribute of another node of the same type.
I have attached a minimal xsd to show my problem.
Steps to reproduce:
Create model/edit/editor code from that xsd.
Create a structure containing two elements of type A and two elements of type B. Both have a "group" attribute which can hold arbitrary numbers of X and Y nodes (mixed). Now one is able to copy&paste / drag&drop say a X from one A to another A, but not from an A to a B and vice versa.
Is that a bug or is it meant that way? Is there a workaround. I already know that this couldn't be solved by simply overwriting ItemProviderAdapter#isValidValue(Object,Object,EStructuralFeature).
Re: Copy&paste / drag&drop into (different) FeatureMap attributes [message #1699023 is a reply to message #1699019] Fri, 19 June 2015 11:04 Go to previous messageGo to next message
Patrick,
It sounds like a bug. Please open a bugzilla. I can't promise to look
at it very soon though...
> Steps to reproduce:
Re: Copy&paste / drag&drop into (different) FeatureMap attributes [message #1699126 is a reply to message #1699023] Sun, 21 June 2015 15:44 Go to previous message
Ok, the corresponding bug can be found here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=470661
Ed Merks wrote on Fri, 19 June 2015 15:04
Previous Topic:Run CDO Hibernate server feature
Next Topic:Drived attributes and custom bodies with EAttribute annotations with OCL
Current Time: Sun Jul 20 18:58:57 EDT 2025
Powered by FUDForum. Page generated in 0.04072 seconds
