Home » Eclipse Projects » EclipseLink » javax.validation.ConstraintViolationException not found
javax.validation.ConstraintViolationException not found [message #1699041] Fri, 19 June 2015 14:15 Go to next message
i have updated my existing project to the target platform of Eclipse 4.4.2.
This goes as well for moxy 2.5.1 to 2.7.0.
Now I get this exception:
Caused by: java.lang.ClassNotFoundException: javax.validation.ConstraintViolationException cannot be found by org.eclipse.persistence.moxy_2.7.0.v20150619-f94d156
I tried to disable validation like this
TreeMap<String, Object> map = new TreeMap<>();
map.put( UnmarshallerProperties.BEAN_VALIDATION_MODE, BeanValidationMode.NONE);
JAXBContext context = JAXBContext.newInstance(new Class[] { .... }, map);
Unmarshaller unmarshaller = context.createUnmarshaller();
But this did not help.
Can someone help?
thx
Frank
Re: javax.validation.ConstraintViolationException not found [message #1699097 is a reply to message #1699041] Sat, 20 June 2015 17:33 Go to previous messageGo to next message
it's a bug Sad I filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=470648 - workaround should be to make sure that javax.validation is available in your target platform. I am not sure if 1.0 would be sufficient, if not you can find 1.1 on eclipselink update sites, ie http://download.eclipse.org/rt/eclipselink/milestone-updates/2.6.1.v20150605-31e8258_RC1/plugins/
thanks,
--lukas
Re: javax.validation.ConstraintViolationException not found [message #1699176 is a reply to message #1699097] Mon, 22 June 2015 06:38 Go to previous messageGo to next message
Thanks that solved it.
Re: javax.validation.ConstraintViolationException not found [message #1714307 is a reply to message #1699176] Wed, 11 November 2015 10:52 Go to previous messageGo to next message
Hi Frank,
How did you solve it specifically? I'm having the same issue with a target platform project that's using http://download.eclipse.org/rt/eclipselink/updates/ as the MOXy update site and currently version 2.6.1.v20150916-55dc7c3 of the plugin. When I click on the "Content" tab in the target definition, I do not see javax.validation. (I see a bunch of over javax.* packages like javax.inject). I can see the javax.validation .jar whilst browsing to http://download.eclipse.org/rt/eclipselink/updates/2.6.1.v20150916-55dc7c3/plugins/, though.
Cheers!
Re: javax.validation.ConstraintViolationException not found [message #1714622 is a reply to message #1714307] Fri, 13 November 2015 23:11 Go to previous message
Just figured it out. Makes sense now Smile
[Updated on: Fri, 13 November 2015 23:13] by Moderator
Previous Topic:Possible BUG: @XmlPaths and 'Self Mappings'
Next Topic:HELP! What are the possible types of value an @XmlPath can have?
Current Time: Sat Jul 19 11:13:38 EDT 2025
Powered by FUDForum. Page generated in 0.06302 seconds
