Home » Eclipse Projects » WindowBuilder » WB Fails to render custom component with NoDefClassFoundException
WB Fails to render custom component with NoDefClassFoundException [message #1698979] Fri, 19 June 2015 05:30 Go to next message
hello,
I'm currently running into a big issue with WB.
I'm running Eclipse Kepler SR2 ( 20140224-0627) under Java 1.6 (jdk1.6.0_45) and compiling my project with maven 3.2.5 under Java 1.6 as well.
The problem is that WB fails to render my components. It only renders a pink box with an error icon.
I'm having trouble finding the issue. The only thing i can see is that WB fails with a NoDefClassFound Exception on one of my messages class (containing my resources Bundle)
Full context stack trace:
org.eclipse.wb.internal.core.utils.exception.DesignerException: 308 (Exception during method invocation evaluation). InventoryMessages.getString("ScanPanel.progress.selection.title") public static java.lang.String [package-name].inventory.common.InventoryMessages.getString(java.lang.String) {ScanPanel.progress.selection.title}
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.invokeMethod(InvocationEvaluator.java:458)
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:101)
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:73)
	at org.eclipse.wb.core.eval.AstEvaluationEngine.evaluate0(AstEvaluationEngine.java:177)
	at org.eclipse.wb.core.eval.AstEvaluationEngine.evaluate(AstEvaluationEngine.java:61)
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.getArgumentValues(InvocationEvaluator.java:560)
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:242)
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.evaluate(InvocationEvaluator.java:81)
	at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluateExpression(JavaInfoEvaluationHelper.java:630)
	at org.eclipse.wb.internal.core.model.JavaInfoEvaluationHelper.evaluate(JavaInfoEvaluationHelper.java:502)
	at org.eclipse.wb.core.model.JavaInfo$8.postVisit(JavaInfo.java:1143)
	at sun.reflect.GeneratedMethodAccessor33.invoke(Unknown Source)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:399)
	at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$ed52f93b.postVisit(<generated>)
	at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2517)
	at org.eclipse.jdt.core.dom.ASTNode.acceptChild(ASTNode.java:2562)
	at org.eclipse.jdt.core.dom.Assignment.accept0(Assignment.java:312)
	at org.eclipse.jdt.core.dom.ASTNode.accept(ASTNode.java:2514)
	at org.eclipse.jdt.core.dom.ExpressionStatement.accept0(ExpressionStatement.java:144)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:354)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement(ExecutionFlowUtils.java:315)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.visitStatement0(ExecutionFlowUtils.java:336)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:247)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.access$1(ExecutionFlowUtils.java:235)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.endVisit(ExecutionFlowUtils.java:442)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils$1.intercept(ExecutionFlowUtils.java:391)
	at org.eclipse.jdt.core.dom.ASTVisitor$$EnhancerByCGLIB$$ed52f93b.endVisit(<generated>)
	at org.eclipse.jdt.core.dom.MethodInvocation.accept0(MethodInvocation.java:247)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:228)
	at org.eclipse.wb.core.eval.ExecutionFlowUtils.visit(ExecutionFlowUtils.java:191)
	at org.eclipse.wb.core.model.JavaInfo.refresh_create(JavaInfo.java:1199)
	at org.eclipse.wb.core.model.ObjectInfo.refreshCreate0(ObjectInfo.java:550)
	at org.eclipse.wb.core.model.ObjectInfo.access$0(ObjectInfo.java:546)
	at org.eclipse.wb.core.model.ObjectInfo$5$1.run(ObjectInfo.java:486)
	at org.eclipse.wb.internal.core.utils.execution.ExecutionUtils.runDesignTime(ExecutionUtils.java:145)
	at org.eclipse.wb.core.model.ObjectInfo$5.run(ObjectInfo.java:484)
	at org.eclipse.wb.internal.swing.utils.SwingUtils$2.run(SwingUtils.java:76)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:672)
	at java.awt.EventQueue.access$400(EventQueue.java:81)
	at java.awt.EventQueue$2.run(EventQueue.java:633)
	at java.awt.EventQueue$2.run(EventQueue.java:631)
	at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:87)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:642)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Caused by: java.lang.NoClassDefFoundError: Could not initialize class [package-name].inventory.common.InventoryMessages
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.wb.internal.core.eval.evaluators.InvocationEvaluator.invokeMethod(InvocationEvaluator.java:456)
	... 66 more
The program launches just fine in both eclipse or intelliJ so it seems to be a WB classpath related issue.
I've tried to upgrade Eclipse to Luna, uninstall and reinstall WB...
I'm kind of stuck here, can anyone help me?
Clément
ps: i've volountarly removed my company's name package from the captures and stacktrace
Re: WB Fails to render custom component with NoDefClassFoundException [message #1699320 is a reply to message #1698979] Tue, 23 June 2015 07:17 Go to previous message
The pink box with the error icon means that there is a problem rendering your custom component at design time. I would recommend reading the WIndowBuilder FAQ (in the docs) on custom components. All custom components need to be valid Java Beans in order to use them in WB. Asside from classpath issues, the most likely issue is trying to use a private class as a component, or relying on some internal behavior that is only valid at runtime (leaving some important state null at design time).
Previous Topic:WB causes Eclipse to hang after closing Preview window
Next Topic:How can I install WindowBuilder for Eclipse Mars?
Current Time: Sun Jul 20 07:12:50 EDT 2025
Powered by FUDForum. Page generated in 0.03825 seconds
