Home » Eclipse Projects » NatTable » Problem with resizing table after scrollbar is hidden
Problem with resizing table after scrollbar is hidden [message #1698600] Tue, 16 June 2015 11:10 Go to next message
Hi, I've spotted a problem with resizing table after scrollbar is hidden. I use percentage column sizing, when the scrollbar was displayed and I remove some rows from the table so that it dissapears I get an white stripe on the right side of the table where the scrollbar was displayed. I think that the problem is in ClientAreaResizeCommand handling in ViewportLayer .
Calling this:
Rectangle calcArea = clientAreaResizeCommand.getCalcArea();
before the scroll bar handling:
if (this.hBarListener == null && this.horizontalScrollbarEnabled) {
                ScrollBar hBar = scrollable.getHorizontalBar();
                if (this.horizontalScroller != null) {
                    hBar.setEnabled(false);
                    hBar.setVisible(false);
                } else {
                    this.horizontalScroller = new ScrollBarScroller(hBar);
                this.hBarListener = new HorizontalScrollBarHandler(this, this.horizontalScroller);
                if (scrollable instanceof NatTable) {
                    this.hBarListener.setTable((NatTable) scrollable);
            if (this.vBarListener == null && this.verticalScrollbarEnabled) {
                ScrollBar vBar = scrollable.getVerticalBar();
                if (this.verticalScroller != null) {
                    vBar.setEnabled(false);
                    vBar.setVisible(false);
                } else {
                    this.verticalScroller = new ScrollBarScroller(vBar);
                this.vBarListener = new VerticalScrollBarHandler(this, this.verticalScroller);
                    this.vBarListener.setTable((NatTable) scrollable);
causes that in ClientAreaResizeCommand calcArea field is set to current clientArea of the table, before updating visibility of the scrollbars . All the resize commands set while updating the scorllbars are ignored by line 992 in ViewportLayer:
if (this.processingClientAreaResizeCommand)
                return false;
so the DataLayer which calls recalculation of percentage sizes gets the table width from before the scrollbars update via the ClientAreaResizeCommand.
Correct me if I'm wrong, but I think that this block of code:
Scrollable scrollable = clientAreaResizeCommand.getScrollable();
            Rectangle clientArea = scrollable.getClientArea();
            int widthDiff = clientArea.width - calcArea.width;
            int heightDiff = clientArea.height - calcArea.height;
should be moved few lines down, to be called after scrollbar handling is done.
If somebody have the same problem, I've temporarily resolved this issue by extending DataLaye class, and overriding
public boolean doCommand(ILayerCommand command) {
method to use
clientAreaResizeCommand.getScrollable().getClientArea().width
instead of
clientAreaResizeCommand.getCalcArea().width
Re: Problem with resizing table after scrollbar is hidden [message #1698626 is a reply to message #1698600] Tue, 16 June 2015 14:32 Go to previous messageGo to next message
Please open a ticket and contribute a fix. Seems you have found the reason and the solution for the issue already
Re: Problem with resizing table after scrollbar is hidden [message #1698712 is a reply to message #1698626] Wed, 17 June 2015 07:53 Go to previous messageGo to next message
Bug reported here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=470338 Hope it's, the right place, and the description is sufficient.
Re: Problem with resizing table after scrollbar is hidden [message #1698722 is a reply to message #1698712] Wed, 17 June 2015 08:36 Go to previous messageGo to next message
Yes, but a Gerrit contribution of the code would be also nice.
Re: Problem with resizing table after scrollbar is hidden [message #1698781 is a reply to message #1698722] Wed, 17 June 2015 17:03 Go to previous messageGo to next message
I had a quick look into this, and I have to tell you that your proposed solution doesn't work. It looks like you don't have a GridLayer composition and therefore your workaround works for you. But it doesn't work for a grid, because in that case the available area is less than the client area.
Also moving the mentioned lines of code doesn't have an effect. And if you look at the code comments, they are placed there by intention.
Nevertheless I can confirm that something isn't correct here. Looks like an issue on calculating the remaining space. Maybe a rounding issue. I need to dig deeper into this.
Re: Problem with resizing table after scrollbar is hidden [message #1698826 is a reply to message #1698781] Thu, 18 June 2015 04:49 Go to previous messageGo to next message
You're right, I'm displaying only column headers and table body, that may be the reason why it's working for me. I forgot about possibility of displaying row headers.
Re: Problem with resizing table after scrollbar is hidden [message #1699093 is a reply to message #1698826] Sat, 20 June 2015 15:18 Go to previous message
Looks like I've found the solution. Could you try to test the Gerrit patch?
Previous Topic:I can't get Nattable working
Next Topic:Odd row spacing on large table
Current Time: Sun Jul 20 02:34:02 EDT 2025
Powered by FUDForum. Page generated in 0.06246 seconds
