Re: Testexec cannot run AUT with relative path [message #1698708 is a reply to message #1698699] |
Wed, 17 June 2015 07:39   |
*OS : win7 x64
*jubula version : 8.1.00294
*external AUT Agent
* log content =
[i]2015-06-17 11:53:46.623 [Connection.ReaderThread:Socket[addr=localhost/127.0.0.1,port=60000,localport=57891]] ERROR o.e.j.c.i.c.StartAUTServerStateCommand - No Java found: Cannot run program "W4 BPMN plus Composer.exe": CreateProcess error=2, Le fichier spécifié est introuvable
2015-06-17 11:53:46.625 [Connection.ReaderThread:Socket[addr=localhost/127.0.0.1,port=60000,localport=57891]] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: AUT could not be started, because no valid Java JRE was specified
2015-06-17 13:15:38.522 [Connection.ReaderThread:Socket[addr=localhost/127.0.0.1,port=60000,localport=59213]] ERROR o.e.j.c.i.c.StartAUTServerStateCommand - No Java found: Cannot run program "W4 BPMN plus Composer.exe": CreateProcess error=2, Le fichier spécifié est introuvable
2015-06-17 13:28:07.586 [main] WARN o.e.j.client.core.ClientTestImpl - connecting the AUT Agent failed
2015-06-17 13:28:07.648 [main] ERROR o.e.j.app.testexec.TestexecClient - Connection to AUT Agent could not be established.
org.eclipse.jubula.tools.internal.exception.CommunicationException: Connection to AUT Agent could not be established.
at org.eclipse.jubula.app.testexec.batch.ExecutionController.prepareAUTAgentConnection(ExecutionController.java:650) ~[na:na]
at org.eclipse.jubula.app.testexec.batch.ExecutionController.executeJob(ExecutionController.java:411) ~[na:na]
at org.eclipse.jubula.app.testexec.TestexecClient.doRun(TestexecClient.java:79) ~[na:na]
at org.eclipse.jubula.client.cmd.AbstractCmdlineClient.run(AbstractCmdlineClient.java:416) [org.eclipse.jubula.client.cmd_3.0.0.201501191443.jar:na]
at org.eclipse.jubula.client.cmd.AbstractLauncher.start(AbstractLauncher.java:24) [org.eclipse.jubula.client.cmd_3.0.0.201501191443.jar:na]
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) [org.eclipse.equinox.app_1.3.200.v20130910-1609.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) [org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) [org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) [org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) [org.eclipse.osgi_3.10.1.v20140909-1633.jar:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.7.0_72]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) ~[na:1.7.0_72]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.7.0_72]
at java.lang.reflect.Method.invoke(Method.java:606) ~[na:1.7.0_72]
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at org.eclipse.equinox.launcher.Main.run(Main.java:1465) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at org.eclipse.equinox.launcher.Main.main(Main.java:1438) [org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar:na]
at com.exe4j.runtime.LauncherEngine.launch(Unknown Source) [i4jruntime.jar:na]
at com.exe4j.runtime.WinLauncher.main(Unknown Source) [i4jruntime.jar:na]
at com.install4j.runtime.launcher.WinLauncher.main(Unknown Source) [i4jruntime.jar:na]
2015-06-17 13:28:07.648 [main] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Connection to AUT Agent could not be established.
2015-06-17 13:28:07.649 [main] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: Connection to AUT Agent has been unexpectedly lost during test execution
2015-06-17 13:28:52.191 [Connection.ReaderThread:Socket[addr=localhost/127.0.0.1,port=60000,localport=59729]] ERROR o.e.j.c.i.c.StartAUTServerStateCommand - No Java found: Cannot run program "W4 BPMN plus Composer.exe": CreateProcess error=2, Le fichier spécifié est introuvable
2015-06-17 13:28:52.193 [Connection.ReaderThread:Socket[addr=localhost/127.0.0.1,port=60000,localport=59729]] ERROR o.e.j.c.cmd.AbstractCmdlineClient - An error ocurred: AUT could not be started, because no valid Java JRE was specified[/i]
I think it iss linked to directory name
I tried 3 directories with different names at the same place
1 - W4-temp
2- W4.temp
3- W4
the first and second didn't work , but the last one worked !!!
The AUT agent is in the same machine as ITE and testexec
FUDForum. Page generated in 0.05286 seconds
