I can't get Nattable working [message #1698552] |
Tue, 16 June 2015 07:38  |
Hello everybody!
Here is the thing: I've been using SWT for a while and it's cool, just SWT, not Jface, wich I can't get working as well. My problem is I'm behind a sever that not allows my Eclipse Luna 4.4.0 to directly connect with Eclipse.org downloads, then I used the alternative choice to download the projects and plugins. I downloaded the last SWT, the NatTable 1.3.0 zip repository, the Eclipse Orbit and then I put all of them together with zero complications. Eclipse recognized all these plugins and dependencies. Great! I thoutgh... Eclipse WindowsBuilder works fine... but no NatTable widget showed up. Then I tried to put it to work by typing it directly into the source code:
NatTable nattable = new NatTable(composite);
Eclipse told me that NatTable was not recognized... Oh my! Then I went back into Eclipse.org and I tried unsuccesfully to locate the properly plugins and dependencies. So, what to do? How can I put NatTable to work if I my Eclipse can't go into Eclipse.org by itself?
I will appreciate all the help you guys can give.
Thanks in advance!
FUDForum. Page generated in 0.04470 seconds
