Home » Eclipse Projects » RCP Testing Tool » [SOLVED] Use custom procedures in multiple test cases
[SOLVED] Use custom procedures in multiple test cases [message #1698525] Tue, 16 June 2015 05:05 Go to next message
Hi all,
Since I need to do some stuff in multiple test cases, I would like to create some procedures and use those procedures in my test cases. I have some problems creating/using them, though.
First, is it correct to create the procedures in a *.test file? I would like to separate the procedures from the other test cases, so I've created a new folder (say "myproc") and created the procedures there.
Now, my second problem is that I cannot use those defined procedures in my other test cases. This is the error message that appears: "Scriptlet X not found at Y".
Simple example: I have two files, one for the procedure, one is my test case
/myproc/MyHelloWorldProcedure
/MyTestCase
MyHelloWorldProcedure:
proc "say-hello-world-procedure" {
  show-alert "Hello, you"
MyTestCase:
my-hello-world-procedure
Error Message that I got: Scriptlet MyHelloWorldProcedure not found at my-hello-world-procedure .
When I'm using the procedure in the same file in which it is defined (i.e. MyHelloWorldProcedure), it works. But in that case I need to define the same procedure in every test case that uses it? There is probably an easy solution to it, I'm just not seeing it.. Smile
Andreas
[Updated on: Mon, 05 October 2015 02:56] by Moderator
Re: Use custom procedures in multiple test cases [message #1698528 is a reply to message #1698525] Tue, 16 June 2015 05:14 Go to previous messageGo to next message
Hi Andreas,
You should use ECL Script Context for this purpose.
Just place your procedure in a Context and it will be available in a Test Cases which have this context added.
You can also add ECL Script Context with a procedure as a Default Context, so the procedure will be available for all test cases in a Project.
Kind regards,
Ulyana.
[Updated on: Tue, 16 June 2015 06:07] by Moderator
Re: Use custom procedures in multiple test cases [message #1698529 is a reply to message #1698528] Tue, 16 June 2015 05:21 Go to previous messageGo to next message
Hi Ulyana,
Thanks for the rapid answer, works like a charm!
Re: Use custom procedures in multiple test cases [message #1698541 is a reply to message #1698529] Tue, 16 June 2015 06:10 Go to previous message
Hi Andreas,
Happy to hear it Smile
Kind regards,
Ulyana.
Previous Topic:Stuck loading AUT
Next Topic:[SOLVED] how to get value of childcount to put on variable
Current Time: Sun Jul 20 08:51:18 EDT 2025
Powered by FUDForum. Page generated in 0.05106 seconds
