Home » Eclipse Projects » NatTable » Alternating Row Configuration (Even Odd Row Color )
Alternating Row Configuration [message #1698420] Mon, 15 June 2015 09:15 Go to next message
I am using white and grey for even and odd rows. But when I scroll row colors are not maintained i.e. suppose row 0 is white, 1 is grey and so on. Now when I scroll down row 1 becomes row 0 and it changes the color to white. But ideally it should retain its original color grey irrespective of its current position.
Please help!
Re: Alternating Row Configuration [message #1698421 is a reply to message #1698420] Mon, 15 June 2015 09:21 Go to previous messageGo to next message
AlternatingRowConfigLabelAccumulator is using row positions maybe because of that???
Re: Alternating Row Configuration [message #1698423 is a reply to message #1698421] Mon, 15 June 2015 09:48 Go to previous messageGo to next message
Yes it is because of the row position, because the row position changes because of the ViewportLayer.
Which version of NatTable? In my code base I can see that if the AlternatingRowConfigLabelAccumulator is created with a layer parameter, the row position is translated to the row index. The DefaultGridLayerConfiguration is doing that. So either you have an older version of NatTable or you are using custom configuration where the AlternatingRowConfigLabelAccumulator is created using the empty default constructor instead of the parameterized constructor.
Re: Alternating Row Configuration [message #1698502 is a reply to message #1698423] Tue, 16 June 2015 02:48 Go to previous messageGo to next message
I am using NatTable core 1.2.0
Re: Alternating Row Configuration [message #1698517 is a reply to message #1698502] Tue, 16 June 2015 04:09 Go to previous messageGo to next message
It was fixed with 1.1.0.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=432127
You need to check that your AlternatingRowConfigLabelAccumulator is created with the ILayer reference to the body layer. And you need to ensure that the layers are set to the GridLayer before the configurations are added.
Re: Alternating Row Configuration [message #1698814 is a reply to message #1698517] Thu, 18 June 2015 03:03 Go to previous messageGo to next message
Thank u so much. Let me try creating AlternatingRowConfigLabelAccumulator with body layer
Re: Alternating Row Configuration [message #1699163 is a reply to message #1698814] Mon, 22 June 2015 05:02 Go to previous message
Awesome! Got it fixed Smile
Thanks a lot Dirk..
Previous Topic:SpanningDataLayer paint problems when scrolling fast
Next Topic:I can't get Nattable working
Current Time: Sun Jul 20 18:33:20 EDT 2025
Powered by FUDForum. Page generated in 0.05683 seconds
