Home » Eclipse Projects » e(fx)clipse » Help setting target platform for e4 + fx + emf forms
Help setting target platform for e4 + fx + emf forms [message #1698441] Mon, 15 June 2015 12:59 Go to next message
I am currently trying to code an e4 application with javafx rendering, and came to an issue on target when trying to add emf forms to it.
I am following the guidelines of not using the
import javafx.*
directives on manifests, but the bundles from
org.eclipse.emf.ecp.view.sdk.fx.feature
use them so i added the
org.eclipse.fx.runtime.min.feature.feature.group
to my target (along with the
[org.eclipse.fx.runtime.e4fx.feature
Eclipse validates the plugins on run configuration but when launching the application, when the handler calls the part object i get:
java.lang.ClassNotFoundException: javafx.scene.Node cannot be found by org.eclipse.emf.ecp.view.model.fx_1.5.0.201411161608
Thanks in advance.
Re: Help setting target platform for e4 + fx + emf forms [message #1698452 is a reply to message #1698441] Mon, 15 June 2015 14:57 Go to previous messageGo to next message
What version of e(fx)clipse are you using?
Tom
On 15.06.15 18:59, Derek Vasconcelos wrote:
> Hello,
> I am following the guidelines of not using the import javafx.*
> org.eclipse.emf.ecp.view.sdk.fx.feature use them so i added the
> org.eclipse.fx.runtime.min.feature.feature.group to my target (along
> with the [org.eclipse.fx.runtime.e4fx.feature) .
> Thanks in advance.
Re: Help setting target platform for e4 + fx + emf forms [message #1698458 is a reply to message #1698452] Mon, 15 June 2015 15:08 Go to previous messageGo to next message
the nightly one 2.0.0
and jdk 8u45 on eclipse mars
[Updated on: Mon, 15 June 2015 15:12] by Moderator
Re: Help setting target platform for e4 + fx + emf forms [message #1698464 is a reply to message #1698458] Mon, 15 June 2015 15:20 Go to previous messageGo to next message
So do you launch with -Dorg.osgi.framework.bundle.parent=ext?
Tom
Re: Help setting target platform for e4 + fx + emf forms [message #1698465 is a reply to message #1698464] Mon, 15 June 2015 15:22 Go to previous messageGo to next message
yes
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS" value="-Dorg.osgi.framework.bundle.parent=ext"/>
Should i launch without it?
my full launch is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.pde.ui.RuntimeWorkbench">
<setAttribute key="additional_plugins"/>
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="askclear" value="true"/>
<booleanAttribute key="automaticAdd" value="false"/>
<booleanAttribute key="automaticValidate" value="true"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="true"/>
<booleanAttribute key="clearws" value="true"/>
<booleanAttribute key="clearwslog" value="false"/>
<stringAttribute key="configLocation" value="${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/br.unicamp.cepetro.unisim.mero.app.product.product"/>
<booleanAttribute key="default" value="false"/>
<stringAttribute key="featureDefaultLocation" value="workspace"/>
<stringAttribute key="featurePluginResolution" value="workspace"/>
<booleanAttribute key="includeOptional" value="true"/>
<stringAttribute key="location" value="${workspace_loc}/../runtime-br.unicamp.cepetro.unisim.mero.app.product"/>
<booleanAttribute key="org.eclipse.jdt.launching.ATTR_USE_START_ON_FIRST_THREAD" value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.JRE_CONTAINER" value="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-1.8"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS" value="-nl ${target.nl} -consoleLog -nosplash -console -clearPersistedState"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER" value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="pde.version" value="3.3"/>
<stringAttribute key="product" value="br.unicamp.cepetro.unisim.mero.app.product"/>
<stringAttribute key="productFile" value="/br.unicamp.cepetro.unisim.mero.app.product/br.unicamp.cepetro.unisim.mero.app.product.product"/>
<setAttribute key="selected_features">
<setEntry value="br.unicamp.cepetro.unisim.mero.app.feature:default"/>
<setEntry value="org.eclipse.emf.ecp.emfforms.runtime.feature:default"/>
<setEntry value="org.eclipse.fx.runtime.e4fx.feature:default"/>
<setEntry value="org.eclipse.fx.runtime.min.feature:default"/>
</setAttribute>
<booleanAttribute key="show_selected_only" value="false"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useCustomFeatures" value="true"/>
<booleanAttribute key="useDefaultConfig" value="true"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<booleanAttribute key="useProduct" value="true"/>
<booleanAttribute key="usefeatures" value="false"/>
</launchConfiguration>
[Updated on: Mon, 15 June 2015 15:25] by Moderator
Re: Help setting target platform for e4 + fx + emf forms [message #1698473 is a reply to message #1698465] Mon, 15 June 2015 16:57 Go to previous messageGo to next message
Well i guess they do package imports so they wire against our fake bundle! This means you need the adapter hooks as well
Re: Help setting target platform for e4 + fx + emf forms [message #1698474 is a reply to message #1698473] Mon, 15 June 2015 17:02 Go to previous messageGo to next message
Darn Sad
I dont like the idea of going against the most recent conventions, so i shall abort the emf forms usage for now. Is there any other alternative to make editors bound to an emf model in an easy manner? I know efxclipse has some emf features but i didnt find much documentation on usage
Re: Help setting target platform for e4 + fx + emf forms [message #1698479 is a reply to message #1698474] Mon, 15 June 2015 17:43 Go to previous messageGo to next message
As I've never used EMF-Forms myself all i say is speculative! Have you
asked at their forum?
If they are doing package imports they should stop doing so or at least
mark them optional because this would allow you to run with the
min.feature and things would still work!
Did using "-Dosgi.framework.extensions=org.eclipse.fx.osgi
-Dorg.osgi.framework.bundle.parent=ext" fix the problems?
As of today the best other option is to use EMF-Databinding and
JavaFX-Eclipse-Databinding but this means you need to craft your UI by
hand or eg through SceneBuilder.
Tom
On 15.06.15 23:02, Derek Vasconcelos wrote:
> Darn :(
> usage
Re: Help setting target platform for e4 + fx + emf forms [message #1698480 is a reply to message #1698479] Mon, 15 June 2015 17:53 Go to previous messageGo to next message
I'm interested on doing the interface on the fxgraph/fxml + databinding way. Is there any source i could checkout that contains examples on this?
[Updated on: Thu, 18 June 2015 16:11] by Moderator
Re: Help setting target platform for e4 + fx + emf forms [message #1699276 is a reply to message #1698480] Tue, 23 June 2015 04:18 Go to previous messageGo to next message
Hi Derek, Hi Tom,
We are using package imports in our bundles. This was the way the example did it in version 1.0.0 and 1.1.0 of e(fx)clipse.
As the EMFForms implementation for JavaFX never found any (known) users we kept it on maintenance.
Would it be enough to change the package imports to bundle imports?
We would happily accept a contribution and provide any help needed.
Eugen
Re: Help setting target platform for e4 + fx + emf forms [message #1699283 is a reply to message #1699276] Tue, 23 June 2015 04:47 Go to previous message
In 2.x you don't need any package imports at all!
Our advice for > 2.x is:
* in RCP use -Dorg.osgi.framework.bundle.parent=ext
* in Plugin-Dev use the adapter hooks
=> they have changed in 2.x to work as a last resort strategy
so they work with/without package imports!
Tom
On 23.06.15 10:18, Eugen Neufeld wrote:
> Hi Derek, Hi Tom,
> we kept it on maintenance. Would it be enough to change the package
> Cheers,
> Eugen
Previous Topic:Eclipse 3.* plugin issues when trying to create a stage.
Next Topic:l10n files generate a gitignore file ?
Current Time: Sun Jul 20 13:18:29 EDT 2025
Powered by FUDForum. Page generated in 0.11813 seconds
