Home » Archived » Eclipse SCADA » How to run Master Server from Equinox OSGi console?
How to run Master Server from Equinox OSGi console? [message #1697871] Tue, 09 June 2015 05:25 Go to next message
Hello there,
I just set up a new application profile project (Eclipse SCADA Configuration Project).
After generating the output files from the .esim infrastructure file, I would run the master node (master.profile.xml) externally from Eclipse, just by using the Equinox OSGi console, instead of right clicking on it and use "Run as -> Run Equinox Application Profile" inside Eclipse.
Could someone tell me if it is possible ?
Thank you
Re: How to run Master Server from Equinox OSGi console? [message #1697921 is a reply to message #1697871] Tue, 09 June 2015 11:27 Go to previous messageGo to next message
Yes it is. You need to add a deployment mechanism beneath the system node. Either Red hat, Ubuntu or Windows and generate again.
Then install the RPM, deb or MSI.
Please note that the windows platform deployment is not very well tested. It is best to use Ubuntu for a start.
Re: How to run Master Server from Equinox OSGi console? [message #1698004 is a reply to message #1697921] Wed, 10 June 2015 05:53 Go to previous messageGo to next message
Hi Jens,
thank you for answering. Could you give me a hint (or some documentation link) on how to set up a deployment configuration for sys node? I'm new to application profiles, I tried to deploy it in the same manner of RCP app, but probably I am missing something.
Thank you again.
[Updated on: Wed, 10 June 2015 05:58] by Moderator
Re: How to run Master Server from Equinox OSGi console? [message #1698152 is a reply to message #1698004] Thu, 11 June 2015 11:40 Go to previous messageGo to next message
Solved!
There is no need to deploy. It is necessary to run the launch configuration.
Re: How to run Master Server from Equinox OSGi console? [message #1805587 is a reply to message #1698152] Thu, 18 April 2019 04:20 Go to previous message
hi,
I am new to this. If you still have some project configurations. could you please share them with me ?
Previous Topic:Data Export from NeoSCADA using IEC 60870-5-104
Next Topic:Is this project (neoSCADA) still under maintenance?
Current Time: Sat Jul 19 21:56:18 EDT 2025
Powered by FUDForum. Page generated in 0.06378 seconds
