Home » Modeling » EMF » How can I integrate ecore models?
How can I integrate ecore models? [message #1697281] |
Tue, 02 June 2015 17:55  |
I could fine an ariticle regarding to the model integration.
In that case, it seemed to need each model will be independently developed and one projec will have dependencies. However, my case is more complex.
I would like not only to develop independently, but also to integrate some elements of a model A and some elements of a model B. How should I do in this case?
If someone know this, please let me know.
Thanks.
Eunjung Park
Re: How can I integrate ecore models? [message #1697334 is a reply to message #1697308] |
Wed, 03 June 2015 05:05   |
Hi Ed,
Thank you for your explanation.
Sorry for incomplete my explanation.
Yes, M1, M2, M3 are model packages, and E1, E2,.. are elements.
"When you
create the GenModel, you should be sure to reuse the GenPackages from
the GenModels for M1 and M2 so you generate new projects containing only
things for M3 and reusing the things it needs from M1 and M2."
How can I inform the EMF that I reuse the GenPacages from existing Models?
Is there any way?
Another thing is that I would like to have one tool which includes all applications of the M1, M2, M3 packages. Is this possible?
Thank you so much.
Best Regards,
Eunjung Park
Re: How can I integrate ecore models? [message #1697337 is a reply to message #1697334] |
Wed, 03 June 2015 05:20   |
The wizard has a "Referenced generator models" section. Perhaps
http://ed-merks.blogspot.de/2008/01/creating-children-you-didnt-know.html is
of interest.
On 03/06/2015 11:05 AM, eunjung park wrote:
> Hi Ed,
> "When you create the GenModel, you should be sure to reuse the
> GenPackages from the GenModels for M1 and M2 so you generate new
> projects containing only things for M3 and reusing the things it needs
> from M1 and M2."
> Models?
> Is there any way?
> Thank you so much.
> Best Regards,
> Eunjung Park
Re: How can I integrate ecore models? [message #1697550 is a reply to message #1697398] |
Thu, 04 June 2015 15:34   |
Hi Ed,
I could find editable attributes.
Thank you so much.
By the way, how about integrating models by using independent project and project dependency?
For example, Model1 is developed by Project1(P1), M2 is developed by Project2(P2).
What I'm thinking is that I make a Integrated model M3 in P3(elements from M1, elements from M2, and newly defined elements) and P3 has dependency on P1 and P2.
I tried to do it and it was successful.
Finally, I want to have P1, P2, P3 in one application.
By the way, is this way reasonable?
Thanks again.
Best Regards,
Eunjung Park
Re: How can I integrate ecore models? [message #1697569 is a reply to message #1697550] |
Fri, 05 June 2015 01:20   |
Eunjung,
Comments below.
On 04/06/2015 9:35 PM, eunjung park wrote:
> Hi Ed,
The editors are not so user friendly or obvious, and the Gen* things
have way too many properties, but such is life...
> Thank you so much.
Yes that's a common scenario.
> Project2(P2).
Yes, that's fine.
Of course.
> Finally, I want to have P1, P2, P3 in one application. By the way, is
It's extremely common. In Oomph we use EMF a lot (of course), and have
more than a dozen models, many of them related in much this way, and
then used together in our Eclipse Installer application as well as in a
normal Eclipse IDE application.
> Thanks again.
> Best Regards,
> Eunjung Park
Re: How can I integrate ecore models? [message #1697650 is a reply to message #1697646] |
Fri, 05 June 2015 11:53   |
Eunjung,
If you have two Ecore Models in the same project (generally avoid that),
they should have a single GenModel or they'll ovewrite each other's
changes (especially for the .edit and .editor projects).
I think the warning you're talking about is that the plugin.xml doesn't
exist, but the model should always generated a plugin.xml, so I'm not
sure why that would go wrong. Is it empty? Does it generate an empty
one if you delete it?
On 05/06/2015 5:04 PM, eunjung park wrote:
> Thank you so much.
> I have another problem related to integrate models.
> I make a new ecore file from existing ecore file and the two ecore
> files are in the same model directory (i.e. same project).
> I used ecore tool which supports to make a ecore model visually.
> The problem is that when I tried to generate codes, there were
> warning, saying that "A plug-in manifest must contain at least one
> extension or extension point".
> Why does this problem occur and How can I solve this problem?
> Thank you every time.
> Regards,
> Eunjung Park
Re: How can I integrate ecore models? [message #1697662 is a reply to message #1697650] |
Fri, 05 June 2015 15:34  |
Thanks Ed.
I could find out what is the problem.
The new echo model(M3) which refers to existing model(M1, M2) does not have its own elements, but has referenced elements from M1, M2.
I think that cause a problem.
Any way, thank you so much.
Best Regards,
Eunjung Park
Current Time: Sun Jul 20 04:15:39 EDT 2025
Powered by FUDForum. Page generated in 0.06807 seconds
