Home » Eclipse Projects » Oomph » Java Virtual Machines / Installed JREs
Java Virtual Machines / Installed JREs [message #1697341] Wed, 03 June 2015 06:02 Go to next message
Dear community
I'm using eclipse installer build 1216 using linux.
I have 2 Questions:
1) If I add the following tasks to my setup, the JVM appears in Oomph Java Virtual Machines under User and Window>Preferences>Java>Installed JREs which name is set to 'JRE for JavaSE-1.8'. How can I change the name to jdk8?
<xmi:XMI xmi:version="2.0"
    xmlns:jdt="http://www.eclipse.org/oomph/setup/jdt/1.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    xsi:schemaLocation="http://www.eclipse.org/oomph/setup/jdt/1.0 http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/models/JDT.ecore">
  <setup:VariableTask
      name="jre.1.8.location"
      value="/opt/java/java8"/>
  <jdt:JRETask
      id="jdk8"
      version="JavaSE-1.8"
      location="${jre.1.8.location}"/>
</xmi:XMI>
2) Is there a possibility to display the user Jvm's (.eclipse/org.eclipse.oomph.jreinfo/extra.txt) only on the simple mode installer page? (See marked elements at attached file)
index.php/fa/22059/0/
Thank you in advance for the response.
Nik
Re: Java Virtual Machines / Installed JREs [message #1697355 is a reply to message #1697341] Wed, 03 June 2015 07:07 Go to previous messageGo to next message
Nik,
Comments below.
On 03/06/2015 12:02 PM, Niklaus Bucher wrote:
> Dear community
> I have 2 Questions:
No, right now the perform for that task just does
vmStandin.setName("JRE for " + version);
So there's no control over the label. That would need to be modeled in
the JRE Task, which would be an enhancement request...
> xmlns:xmi="http://www.omg.org/XMI"
> <setup:VariableTask
> <jdt:JRETask
> id="jdk8"
> </xmi:XMI>
I'm not sure I parse what the word "only" implies in this sentence. You
want only the user added JVMs displayed in the dropdown? Or you're
asking if you can only display the user added JVMs in the installer
page? In any case, wherever the dropdown is available, the Java Virtual
Machines dialog is available, and you can use that to make a
selection. Your selections are also remembered across all
applications, so you'll generally get what you selected the last time,
so if that's the user added one, that's what you'll get...
> Nik
Re: Java Virtual Machines / Installed JREs [message #1697358 is a reply to message #1697355] Wed, 03 June 2015 07:33 Go to previous messageGo to next message
Thank you for the quick response.
Concerning the JRE name I created an enchancment request hopefully that it is suitable. https://bugs.eclipse.org/bugs/show_bug.cgi?id=469257
Sorry about my bad english, I meant that I want list only the user added jvms as selection options, without the standard system jvms.
Nik
Re: Java Virtual Machines / Installed JREs [message #1697364 is a reply to message #1697358] Wed, 03 June 2015 08:38 Go to previous message
Niklaus,
No, it will always list all valid available JVMs.
> Thanks
> Nik
Previous Topic:clone existing project
Next Topic:Beginner Level: simplest Bitbucket integration with passphrase
Current Time: Sat Jul 19 09:18:41 EDT 2025
Powered by FUDForum. Page generated in 0.04414 seconds
