Home » Modeling » TMF (Xtext) » Parse XExpressions
icon5.gif  Parse XExpressions [message #1697063] Mon, 01 June 2015 05:47 Go to next message
As part of my thesis I wrote a small DSL which describes special flowcharts. The decision nodes of those charts use the following parser rule:
Decision:
	'decision' name=ValidID '{'
		expression=XExpression
In my IJvmModelInferrer I map each decision to a method and set the XExpression as its body. Most of the time those expressions contain a simple if clause (sometimes switch statements) to evaluate one or more system properties and to decide which node or leaf comes next.
In order to visualize a flowchart I have to analyze the given XExpressions (and therefore parts of the AST) to draw links between nodes. A short example for this (in DSL syntax):
decision myDecision {
	if  (foo)
		return anotherDecision
	else
		return MY_LEAF
So what I want to do is show myDecision (which I already accomplished) and have outgoing links to anotherDecision and MY_LEAF, ideally with a label "if (foo)" and "else".
What is the best or easiest way to parse my XExpressions to achieve this? I'm new to the world of EMF/Xtext/Xbase and thankful for any help or advice.
[Updated on: Tue, 02 June 2015 04:34] by Moderator
Re: Parse XExpressions [message #1697093 is a reply to message #1697063] Mon, 01 June 2015 10:02 Go to previous messageGo to next message
Hi Daniel,
the expressions are already parsed. I assume what you are looking for is
ILogicalContainerProvider.getAssociatedExpression(JvmIdentifiableElement) and
a means to walk the expression tree that is obtained from there.
Please check whether the XbaseSwitch or a plain xtend dispatch method
for the various expression types suite your needs.
Best,
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Find help at http://xtext.itemis.com or xtext(@)itemis.com
Blog: zarnekow.blogspot.com
Twitter: @szarnekow
Google+: https://www.google.com/+SebastianZarnekow
Re: Parse XExpressions [message #1697186 is a reply to message #1697093] Tue, 02 June 2015 04:38 Go to previous message
Hey Sebastian,
I'm sorry for the ambiguous wording, your assumption was correct. I was able to get the parts of those XExpressions with a dispatch method, so thanks for your food for thought!
Daniel
Previous Topic:Highlighting of hidden elements is not as expected
Next Topic:Scoping query
Current Time: Sun Jul 20 11:09:41 EDT 2025
Powered by FUDForum. Page generated in 0.04096 seconds
