Home » Modeling » EMF » [CDO] Audit view on branch before base timestamp
[CDO] Audit view on branch before base timestamp [message #1696686] |
Wed, 27 May 2015 17:25  |
Given
- a repository creation timestamp t(0),
- two commits on branch "MAIN" with timestamps t(1) and t(2) and
- a branch creation point for branch "MAIN/a" with timestamp t(3),
is it expected that an audit view opened on branch "MAIN/a" with timestamp t(0) < t(1) <= t(view) < t(2) < t(3) will return CDO objects with state corresponding to timestamp t(2) (or more precisely, t(3))? Looking at the code, revision loading and the cache seem to clamp incoming timestamps to branch basepoints when they are set before the proverbial "fork in the road", and lookup requires moving up to a parent branch.
The only utility method I've seen which compensates for this behavior is CDOBranchUtil#normalizeBranchPoint(CDOBranch, long). Should client code call it before initializing the view?
András
Re: [CDO] Audit view on branch before base timestamp [message #1696772 is a reply to message #1696721] |
Thu, 28 May 2015 09:45   |
Hi Eike,
Quote:A CDOView should deliver a consistent model for any branch and any timestamp
between now and repo creation time, including timestamps before the branch creation (or better: base point).
Thanks, this is also what I was expecting. Unfortunately the actual behavior of CDOView was a bit different for me.
Consider the two similar blocks of code in CDORevisionManagerImpl#getCachedRevisionRecursively and Repository#loadRevisionTarget:
private InternalCDORevision loadRevisionTarget(CDOID id, CDOBranchPoint branchPoint, int referenceChunk,
IStoreAccessor accessor)
CDOBranch branch = branchPoint.getBranch();
while (!branch.isMainBranch())
branchPoint = branch.getBase();
InternalCDORevision revision = accessor.readRevision(id, branchPoint, referenceChunk, revisionManager);
if (revision != null)
revision.freeze();
return revision;
return null;
For uncached loads, when loading a revision with branchPoint on a child branch set before the base point, we can be sure that the revision will not be found on the current branch, as the branch was not existing in the repository at that point in time. As a result, loadRevisionTarget gets called, where branchPoint is updated to point to the next branch base inside the while() block. When the revision is finally found on a parent, the timestamp part will no longer match the one which was passed in; it will be set to one of the base timestamps.
This way, regardless of what timestamp is chosen for the view, if it is set before the branch base, it will show the state corresponding to the base timestamp for objects that don't have a relevant revision on the view's branch.
If the view is opened on a parent branch where revisions are present, loadRevisionTarget is not invoked, the timestamp does not change and these revisions become distinguishable.
Re: [CDO] Audit view on branch before base timestamp [message #1696869 is a reply to message #1696772] |
Fri, 29 May 2015 03:31   |
Am 28.05.2015 um 15:45 schrieb Andras Peteri:
> Hi Eike,
> Quote:
>> A CDOView should deliver a consistent model for any branch and any timestamp between now and repo creation time,
> revision.freeze();
> return revision;
> return null;
Correct.
Correct, if the revision in the parent branch is valid at that time.
What do you mean by "the timestamp does not change" and "these revisions become distinguishable"?
I have the feeling you're looking at some code and theorizing. Or are you experiencing wrong behaviour? If so, can you
please provide a test case so that I can reproduce it?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Audit view on branch before base timestamp [message #1696910 is a reply to message #1696904] |
Fri, 29 May 2015 06:40   |
* Copyright (c) 2010-2013 Eike Stepper (Berlin, Germany) and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Eike Stepper - initial API and implementation
package org.eclipse.emf.cdo.tests;
import org.eclipse.emf.cdo.common.branch.CDOBranch;
import org.eclipse.emf.cdo.common.branch.CDOBranchManager;
import org.eclipse.emf.cdo.common.branch.CDOBranchPoint;
import org.eclipse.emf.cdo.common.commit.CDOCommitInfo;
import org.eclipse.emf.cdo.common.revision.CDORevision;
import org.eclipse.emf.cdo.common.revision.CDORevisionUtil;
import org.eclipse.emf.cdo.eresource.CDOResource;
import org.eclipse.emf.cdo.internal.common.revision.AbstractCDORevisionCache;
import org.eclipse.emf.cdo.internal.server.mem.MEMStore;
import org.eclipse.emf.cdo.server.IStore;
import org.eclipse.emf.cdo.session.CDOSession;
import org.eclipse.emf.cdo.tests.config.IRepositoryConfig;
import org.eclipse.emf.cdo.tests.config.impl.ConfigTest.Requires;
import org.eclipse.emf.cdo.tests.model1.OrderDetail;
import org.eclipse.emf.cdo.tests.model1.Product1;
import org.eclipse.emf.cdo.transaction.CDOTransaction;
import org.eclipse.emf.cdo.view.CDOView;
import org.eclipse.net4j.util.ReflectUtil;
import org.eclipse.emf.spi.cdo.InternalCDOSession;
import java.lang.reflect.Field;
import java.util.List;
import java.util.Map;
* @author Eike Stepper
@Requires(IRepositoryConfig.CAPABILITY_BRANCHING)
public class BranchingAuditTest extends AbstractCDOTest
protected CDOSession session1;
protected void doSetUp() throws Exception
super.doSetUp();
Field disableGC = ReflectUtil.getField(AbstractCDORevisionCache.class, "disableGC");
ReflectUtil.setValue(disableGC, null, true);
protected void doTearDown() throws Exception
session1 = null;
ReflectUtil.setValue(disableGC, null, false);
super.doTearDown();
protected CDOSession openSession1()
session1 = openSession();
return session1;
protected void closeSession1()
session1.close();
session1 = null;
protected CDOSession openSession2()
return openSession();
protected String getBranchName(String name)
// New scenarios get clean repositories, no need to disambiguate them.
return getClass().getSimpleName() + "_" + getName() + "_" + name;
public void testAuditViewOnBranch() throws Exception
String name = getBranchName("subBranch");
CDOSession session = openSession1();
CDOBranchManager branchManager = session.getBranchManager();
// Commit to main branch
CDOBranch mainBranch = branchManager.getMainBranch();
CDOTransaction transaction = session.openTransaction(mainBranch);
assertEquals(mainBranch, transaction.getBranch());
assertEquals(CDOBranchPoint.UNSPECIFIED_DATE, transaction.getTimeStamp());
Product1 product = getModel1Factory().createProduct1();
product.setName("CDO");
OrderDetail orderDetail = getModel1Factory().createOrderDetail();
orderDetail.setProduct(product);
orderDetail.setPrice(5.0f);
CDOResource resource = transaction.createResource(getResourcePath("/res"));
resource.getContents().add(product);
resource.getContents().add(orderDetail);
CDOCommitInfo commitInfo = transaction.commit();
dumpAll(session);
assertEquals(mainBranch, commitInfo.getBranch());
long commitTime1 = commitInfo.getTimeStamp();
// Modify main branch (change existing OrderDetail)
orderDetail.setPrice(10.0f);
dumpAll(session);
long commitTime2 = commitInfo.getTimeStamp();
transaction.close();
// Commit to sub branch
CDOBranch subBranch = mainBranch.createBranch(name);
transaction = session.openTransaction(subBranch);
assertEquals(subBranch, transaction.getBranch());
resource = transaction.getResource(getResourcePath("/res"));
orderDetail = (OrderDetail)resource.getContents().get(1);
assertEquals(10.0f, orderDetail.getPrice());
product = orderDetail.getProduct();
assertEquals("CDO", product.getName());
// Modify sub branch (add new OrderDetail)
OrderDetail orderDetail2 = getModel1Factory().createOrderDetail();
orderDetail2.setProduct(product);
orderDetail2.setPrice(20.0f);
resource.getContents().add(0, orderDetail2);
dumpAll(session);
assertEquals(subBranch, commitInfo.getBranch());
long commitTime3 = commitInfo.getTimeStamp();
closeSession1();
session = openSession2();
subBranch = mainBranch.getBranch(name);
check(session, mainBranch, commitTime1, 5.0f, "CDO");
check(session, mainBranch, commitTime2, 10.0f, "CDO");
check(session, mainBranch, CDOBranchPoint.UNSPECIFIED_DATE, 10.0f, "CDO");
check(session, subBranch, commitTime1, 5.0f, "CDO"); // !
check(session, subBranch, commitTime2, 10.0f, "CDO");
check(session, subBranch, commitTime3, 10.0f, 20.0f, "CDO");
check(session, subBranch, CDOBranchPoint.UNSPECIFIED_DATE, 10.0f, 20.0f, "CDO");
session.close();
private void check(CDOSession session, CDOBranch branch, long timeStamp, float price, String name, int size)
CDOView view = session.openView(branch, timeStamp);
CDOResource resource = view.getResource(getResourcePath("/res"));
int actualSize = resource.getContents().size();
assertEquals(size, actualSize);
dumpAll(session);
OrderDetail orderDetail = (OrderDetail)resource.getContents().get(1);
dumpAll(session);
float actualPrice = orderDetail.getPrice();
assertEquals(price, actualPrice);
Product1 product = orderDetail.getProduct();
dumpAll(session);
String actualName = product.getName();
assertEquals(name, actualName);
view.close();
private void check(CDOSession session, CDOBranch branch, long timeStamp, float price, String name)
check(session, branch, timeStamp, price, name, 2);
private void check(CDOSession session, CDOBranch branch, long timeStamp, float price, float price2, String name)
assertEquals(3, resource.getContents().size());
dumpAll(session);
OrderDetail orderDetail2 = (OrderDetail)resource.getContents().get(0);
OrderDetail orderDetail = (OrderDetail)resource.getContents().get(2);
dumpAll(session);
assertEquals(price, orderDetail.getPrice());
assertEquals(price2, orderDetail2.getPrice());
Product1 product2 = orderDetail2.getProduct();
dumpAll(session);
assertEquals(name, product.getName());
assertEquals(name, product2.getName());
view.close();
private void dumpAll(CDOSession session)
IStore store = getRepository().getStore();
if (store instanceof MEMStore)
MEMStore memStore = (MEMStore)store;
dump("MEMStore", memStore.getAllRevisions());
dump("ServerCache", getRepository().getRevisionManager().getCache().getAllRevisions());
dump("ClientCache", ((InternalCDOSession)session).getRevisionManager().getCache().getAllRevisions());
public static void dump(String label, Map<CDOBranch, List<CDORevision>> revisions)
System.out.println();
System.out.println(label);
System.out
.println("===============================================================================================");
CDORevisionUtil.dumpAllRevisions(revisions, System.out);
public static void assertEquals(Object expected, Object actual)
if (expected instanceof CDOBranch && actual instanceof CDOBranch)
if (((CDOBranch)expected).getID() != ((CDOBranch)actual).getID())
failNotEquals(null, expected, actual);
return;
AbstractCDOTest.assertEquals(expected, actual);
Re: [CDO] Audit view on branch before base timestamp [message #1696949 is a reply to message #1696910] |
Fri, 29 May 2015 12:14   |
I can reproduce it with your test and a fix will be in RC3:
468834: Audit views with timestamp < branch.getBase().getTimeStamp() deliver wrong revisions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=468834
Good catch!
Cheers
/Eike
Am 29.05.2015 um 12:40 schrieb Andras Peteri:
> * Contributors:
> @Override
> super.doSetUp();
> @Override
> session1 = null;
> super.doTearDown();
> return session1;
> session1.close();
> session1 = null;
> dumpAll(session);
> dumpAll(session);
> dumpAll(session);
> closeSession1();
> session.close();
> dumpAll(session);
> dumpAll(session);
> dumpAll(session);
> view.close();
> dumpAll(session);
> dumpAll(session);
> dumpAll(session);
> view.close();
> System.out
> return;
Current Time: Sat Jul 19 08:28:01 EDT 2025
Powered by FUDForum. Page generated in 0.10459 seconds
