Home » Eclipse Projects » Oomph » [SOLVED] Startup trigger not executed
[SOLVED] Startup trigger not executed [message #1696553] Wed, 27 May 2015 04:48 Go to next message
I created a setup profile at home and it worked as expected.
Now I tried to use the same profile on my company PC and - whatever I try - after the successful setup and the automatic launch of the IDE the startup task of the Oomph install is not executed. If I trigger it manually (perform setup task), the dialog lists no tasks. And in the list of profiles only the predefined ones are listed (User, Workspace, Installation). My setup profile is missing.
Can you give me a hint on how to solve this problem?
Thanks in advance.
Dieter
[Updated on: Thu, 28 May 2015 10:57] by Moderator
Re: Startup trigger not executed [message #1696559 is a reply to message #1696553] Wed, 27 May 2015 05:18 Go to previous messageGo to next message
Dieter,
Comments below.
On 27/05/2015 10:48 AM, Dieter Scholz wrote:
By profile you mean you have a project setup?
Where is the setup stored? In your git repository? You're adding it to
one of the project catalogs?
In this use case, you've chosen your project on the projects page? And
in the confirmation page you see evidence that the p2 task is installing
additional things (if there are any).
If you ask it to show all tasks, including the ones that don't need to
perform, is there still no evidence of your project there?
If you open the workspace setup, doe it show your project as one of the
stream for the workspace's properties?
Not yet. It's not clear what you've done... I'll need to understand
what your Workspace setup looks like. Your project should be referenced
there...
> Thanks in advance.
> Dieter
Re: Startup trigger not executed [message #1696564 is a reply to message #1696559] Wed, 27 May 2015 05:45 Go to previous messageGo to next message
Ed,
I'm sorry, but I do not understand your answer (all my fault because probably I do not completely overlook how the Oomph installer works).
Ok. I created a setup file (p2 and some changed preferences - see attached file). Then I use this file with the installer. At home - after the installer finished and the IDE is started - the icon for the startup task appears. That's not the case when I execute the same file in my company environment.
I don't understand what that has to do with my workspace and a project I should reference. Can you please explain that to me? Thanks.
I attached the setup log, too.
Dieter
Re: Startup trigger not executed [message #1696577 is a reply to message #1696564] Wed, 27 May 2015 06:44 Go to previous messageGo to next message
Dieter,
Comments below.
On 27/05/2015 11:45 AM, Dieter Scholz wrote:
> Ed,
So you added it to the project catalog on the project page so that you
could use it with the install?
When you perform manually on the Confirmation page, and you choose "Show
all triggered tasks", are the tasks you're expecting really not listed
there?
It looks like it installed all the extra things you've specified.
Perhaps the state of your workspace already matches all these
preferences and there really is nothing to do. In that case you won't
see any startup tasks performed.
> Dieter
Re: Startup trigger not executed [message #1696593 is a reply to message #1696577] Wed, 27 May 2015 08:18 Go to previous messageGo to next message
Ed,
Comments below.
Correct. I dropped it into the product selection page.
>there?
I've added three screenshots (summary of installer, toolbar of installed IDE & 'Perform setup task dialog' of installed IDE).
The plugins are available but all my preference settings are not applied.
Dieter
  • Attachment: oomph1.png
    (Size: 51.59KB, Downloaded 166 times)
  • Attachment: oomph2.png
    (Size: 3.92KB, Downloaded 159 times)
  • Attachment: oomph3.png
    (Size: 38.50KB, Downloaded 181 times)
Re: Startup trigger not executed [message #1696617 is a reply to message #1696593] Wed, 27 May 2015 09:47 Go to previous messageGo to next message
Dieter,
Comments below.
On 27/05/2015 2:18 PM, Dieter Scholz wrote:
> Ed,
> Comments below.
You mean Project page? The product page isn't extensible via drag and
drop. Which Project catalog did you add it to? Then you double
clicked on it and it appeared in the bottom stream table at the bottom
of the Project page?
>> there?
It certainly looks like this installation's workspace is not aware of
you having added any setup projects to it. Can use the menu you
showed to Open Workspace to open the workspace setup. You can use the
context menu to "Open in Text Editor" and paste what you see textually.
There should be at least one element at the end like this:
<stream
href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='oomph']/@streams[name='master']"/>
I.e., the workspace setup should reference the stream of your setup project.
No, and from what you show, the workspace's setup doesn't appear to be
aware of your project...
> Dieter
Re: Startup trigger not executed [message #1696709 is a reply to message #1696617] Thu, 28 May 2015 03:20 Go to previous messageGo to next message
Ed,
of course it was to the project page I dropped the setup file.
After opening the workspace setup file an error message is displayed:
The feature 'streams' of ' Workspace file:/D:/Entwicklung/projekte/eclipse/nagvis/' contains an unresolved proxy ' index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='user.project']/@projects[name='rudolf.eclipse.setup']/@streams[name='master']'
The content of the setup file is:
<setup:Workspace
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    name="workspace">
  <stream href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='user.project']/@projects[name='rudolf.eclipse.setup']/@streams[name='master']"/>
</setup:Workspace>
Could this be the cause for the not working startup trigger? There are no errors in the user and installation files.
Dieter
Re: Startup trigger not executed [message #1696731 is a reply to message #1696709] Thu, 28 May 2015 05:32 Go to previous messageGo to next message
Dieter,
Comments below.
On 28/05/2015 9:20 AM, Dieter Scholz wrote:
> Ed,
> proxy '
Okay that explains why nothing is working in the IDE. What are the
contents of your
~/.eclipse/org.eclipse.oomph.setup/setups/org.eclipse.projects.setup
file? This should contain a reference to your project setup resource.
<project href="{URI-of-your-project-setup}#/"/>
It should have been added and saved by the installer when you did the
drag and drop thing...
> <setup:Workspace
> xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> name="workspace">
> <stream
> </setup:Workspace>
> Dieter
Re: Startup trigger not executed [message #1696796 is a reply to message #1696731] Thu, 28 May 2015 11:03 Go to previous messageGo to next message
Ed,
thanks for your help and patience.
In the end it was a Windows problem. We use roaming profiles in our company. Because of reasons I do not understand there are two .eclipse folders. One on a network share and a local one. And the content of these folders was different.
I copied one into the other and - voila - it works.
So again thank you.
Dieter
Re: Startup trigger not executed [message #1696798 is a reply to message #1696796] Thu, 28 May 2015 11:13 Go to previous message
Dieter,
I'm glad to hear it's resolved. Sorry it took so many cycles...
On 28/05/2015 5:03 PM, Dieter Scholz wrote:
> Ed,
> So again thank you.
> Dieter
Previous Topic:How to import a non eclipse project?
Next Topic:proper value for "Logical Project Container" for internal projects
Current Time: Sat Jul 19 07:57:59 EDT 2025
Powered by FUDForum. Page generated in 0.09563 seconds
