[EMFStore][EMF Forms] NullPointerException [message #1696358] |
Tue, 26 May 2015 00:43  |
I downloaded and installed fresh modeling package, installed sample makeithappen model/edit/viewmodel projects from File -> New -> Example -> EMF Forms, configured Run configuration as explained in the documentation, and started new instance of eclipse.
The new instance was created (and looked ok) but there was NullPointerException in the console. Is there anything wrong with my emfstore or some other setting???
BTW, I am using Mac and info about eclipse modeling package is as follows:
Eclipse Modeling Tools
Version: Luna Service Release 2 (4.4.2)
Build id: 20150219-0600
Java: JDK1.8.0_40
!ENTRY org.eclipse.emf.emfstore.client 4 4 2015-05-26 13:21:52.428
!MESSAGE Exception occurred during command execution.
!STACK 0
at org.eclipse.emf.emfstore.internal.client.model.impl.ProjectSpaceBase.initResourcePersister(ProjectSpaceBase.java:682)
at org.eclipse.emf.emfstore.internal.client.model.impl.ProjectSpaceBase.init(ProjectSpaceBase.java:621)
at org.eclipse.emf.emfstore.internal.client.model.impl.WorkspaceBase.init(WorkspaceBase.java:152)
at org.eclipse.emf.emfstore.internal.client.model.ESWorkspaceProviderImpl$3.call(ESWorkspaceProviderImpl.java:325)
at org.eclipse.emf.emfstore.internal.client.model.ESWorkspaceProviderImpl$3.call(ESWorkspaceProviderImpl.java:1)
at org.eclipse.emf.emfstore.client.util.RunESCommand$1.doRun(RunESCommand.java:137)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.commandBody(EMFStoreCommand.java:51)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.execute(AbstractEMFStoreCommand.java:64)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at org.eclipse.emf.emfstore.internal.client.model.changeTracking.commands.EMFStoreBasicCommandStack.execute(EMFStoreBasicCommandStack.java:72)
at org.eclipse.emf.emfstore.internal.client.model.util.AbstractEMFStoreCommand.aRun(AbstractEMFStoreCommand.java:108)
at org.eclipse.emf.emfstore.internal.client.model.util.EMFStoreCommand.run(EMFStoreCommand.java:60)
at org.eclipse.emf.emfstore.client.util.RunESCommand.run(RunESCommand.java:145)
at org.eclipse.emf.emfstore.internal.client.model.ESWorkspaceProviderImpl.load(ESWorkspaceProviderImpl.java:323)
at org.eclipse.emf.emfstore.internal.client.model.ESWorkspaceProviderImpl.initialize(ESWorkspaceProviderImpl.java:511)
at org.eclipse.emf.emfstore.internal.client.model.ESWorkspaceProviderImpl.getInstance(ESWorkspaceProviderImpl.java:180)
at org.eclipse.emf.emfstore.client.ESWorkspaceProvider.<clinit>(ESWorkspaceProvider.java:32)
at org.eclipse.emf.ecp.emfstore.core.internal.EMFStoreProvider.getServerInfo(EMFStoreProvider.java:542)
at org.eclipse.emf.ecp.emfstore.core.internal.EMFStoreProvider.fillChildren(EMFStoreProvider.java:150)
at org.eclipse.emf.ecp.internal.core.ECPProviderRegistryImpl$ProviderDescriptor.fillChildren(ECPProviderRegistryImpl.java:231)
at org.eclipse.emf.ecp.internal.ui.model.ECPContentProvider.fillChildren(ECPContentProvider.java:50)
at org.eclipse.emf.ecp.internal.ui.model.RepositoriesContentProvider.fillChildren(RepositoriesContentProvider.java:92)
at org.eclipse.emf.ecp.internal.ui.model.TreeContentProvider.fillChildrenDetectError(TreeContentProvider.java:198)
at org.eclipse.emf.ecp.internal.ui.model.TreeContentProvider.getChildrenList(TreeContentProvider.java:190)
at org.eclipse.emf.ecp.internal.ui.model.TreeContentProvider.hasChildren(TreeContentProvider.java:61)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2141)
at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer.java:553)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2171)
at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(AbstractTreeViewer.java:2863)
at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.java:804)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:844)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:818)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:791)
at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:611)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:762)
at org.eclipse.jface.viewers.AbstractTreeViewer.internalInitializeTree(AbstractTreeViewer.java:1543)
at org.eclipse.jface.viewers.TreeViewer.internalInitializeTree(TreeViewer.java:790)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractTreeViewer.java:1527)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1436)
at org.eclipse.jface.viewers.TreeViewer.preservingSelection(TreeViewer.java:366)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1397)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(AbstractTreeViewer.java:1519)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentViewer.java:292)
at org.eclipse.jface.viewers.StructuredViewer.setInput(StructuredViewer.java:1675)
at org.eclipse.emf.ecp.spi.common.ui.TreeViewerFactory.createTreeViewer(TreeViewerFactory.java:62)
at org.eclipse.emf.ecp.spi.common.ui.TreeViewerFactory.createTreeViewer(TreeViewerFactory.java:36)
at org.eclipse.emf.ecp.ui.common.ECPViewerFactory.createRepositoryExplorerViewer(ECPViewerFactory.java:143)
at org.eclipse.emf.ecp.ui.views.ModelRepositoriesView.createViewer(ModelRepositoriesView.java:58)
at org.eclipse.emf.ecp.ui.views.TreeView.createPartControl(TreeView.java:113)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:141)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:155)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:327)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:127)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:531)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:69)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1246)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:69)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:156)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4732)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:108)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:4059)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:733)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:85)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:73)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1480)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1453)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:943)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:137)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:703)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1098)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4195)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1467)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1490)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1471)
at org.eclipse.swt.widgets.Shell.windowDidBecomeKey(Shell.java:2159)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5686)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:214)
at org.eclipse.swt.widgets.Widget.becomeKeyWindow(Widget.java:366)
at org.eclipse.swt.widgets.Shell.becomeKeyWindow(Shell.java:525)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5510)
at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:5139)
at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5288)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3666)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.emf.ecp.application3x.Application.start(Application.java:37)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Thank you very much for your help in advance.
Akira
FUDForum. Page generated in 0.07325 seconds
