Home » Eclipse Projects » RCP Testing Tool » Is there option to run tests only with certain tags for Runner (opposite to skipTags)
Is there option to run tests only with certain tags for Runner (opposite to skipTags) [message #1696298] Mon, 25 May 2015 06:43 Go to next message
Is there option to run tests only with certain tags for Runner (opposite to skipTags).
We have a TestSuite which consists feature testing & bug driven testing, we would like to separate execution of those two by tags.
2 jobs would execute the same TestSuite, one with skipTags for Bugs, other with something like "includeTags" for Bugs. This way when issue is fixed, only tag entry needs to be changed.
Is there anything planned in next releases ?
Re: Is there option to run tests only with certain tags for Runner (opposite to skipTags) [message #1696305 is a reply to message #1696298] Mon, 25 May 2015 07:59 Go to previous message
This feature isn't available now. How critical is this feature for you?
I may suggest you to create separate test suites and add there test cases with needed tag (button "Add with Tag" in test suite editor).
Previous Topic:Error on a test case without fail
Next Topic:Issue with Maven
Current Time: Sun Jul 20 08:53:50 EDT 2025
Powered by FUDForum. Page generated in 0.04096 seconds
