Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down(After shutting down the OSGi system, two waiting teneo threads are waiting forever and prevent the JVM from shutting down.)
[Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696144] Fri, 22 May 2015 07:17 Go to next message
Hello everybody,
in my OSGi/Equinox based application I have the following problematic situation: When shutting down the OSGi system via "shutdown" command on the OSGi console, the OSGi system terminates, but the JVM process remains running forever. A thread dump shows, that there are still three threads running or waiting respectively which obviously prevent the JVM from terminating:
Full thread dump Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode):
"DestroyJavaVM" #42 prio=5 os_prio=0 tid=0x000000005f614800 nid=0xdac waiting on condition [0x0000000000000000]
   java.lang.Thread.State: RUNNABLE
   Locked ownable synchronizers:
        - None
"teneoHibernateVersionMapPurging-41" #41 prio=5 os_prio=0 tid=0x000000005f612800 nid=0x26c waiting on condition [0x000000006260e000]
   java.lang.Thread.State: TIMED_WAITING (parking)
        at sun.misc.Unsafe.park(Native Method)
        - parking to wait for  <0x000000008301b4f8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
        at java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:215)
        at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2078)
        at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:1093)
        at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(ScheduledThreadPoolExecutor.java:809)
        at java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1067)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1127)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
        - None
"teneoHibernateIdMapPurging-40" #40 prio=5 os_prio=0 tid=0x000000005f611800 nid=0x1b9c waiting on condition [0x000000006244e000]
        - parking to wait for  <0x000000008301b0c0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
        - None
"EMF Reference Cleaner" #20 daemon prio=5 os_prio=0 tid=0x000000005b1fe800 nid=0x1910 in Object.wait() [0x000000005c75f000]
   java.lang.Thread.State: WAITING (on object monitor)
        at java.lang.Object.wait(Native Method)
        at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:142)
        - locked <0x00000000812f2d60> (a java.lang.ref.ReferenceQueue$Lock)
        at java.lang.ref.ReferenceQueue.remove(ReferenceQueue.java:158)
        at org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
        - None
"Service Thread" #12 daemon prio=9 os_prio=0 tid=0x0000000058d8b800 nid=0x1a64 runnable [0x0000000000000000]
        - None
"C1 CompilerThread2" #11 daemon prio=9 os_prio=2 tid=0x0000000058d6b000 nid=0x120c waiting on condition [0x0000000000000000]
        - None
"C2 CompilerThread1" #10 daemon prio=9 os_prio=2 tid=0x0000000058d26000 nid=0x1378 waiting on condition [0x0000000000000000]
        - None
"C2 CompilerThread0" #9 daemon prio=9 os_prio=2 tid=0x0000000058d1e800 nid=0x16bc waiting on condition [0x0000000000000000]
        - None
"JDWP Command Reader" #8 daemon prio=10 os_prio=0 tid=0x0000000058d12800 nid=0x1640 runnable [0x0000000000000000]
        - None
"JDWP Event Helper Thread" #7 daemon prio=10 os_prio=0 tid=0x0000000058d0f800 nid=0x1490 runnable [0x0000000000000000]
        - None
"JDWP Transport Listener: dt_socket" #6 daemon prio=10 os_prio=0 tid=0x0000000058d05000 nid=0x1b78 runnable [0x0000000000000000]
        - None
"Attach Listener" #5 daemon prio=5 os_prio=2 tid=0x0000000058d00800 nid=0x1430 waiting on condition [0x0000000000000000]
        - None
"Signal Dispatcher" #4 daemon prio=9 os_prio=2 tid=0x0000000057916800 nid=0x1968 runnable [0x0000000000000000]
        - None
"Finalizer" #3 daemon prio=8 os_prio=1 tid=0x00000000578b9000 nid=0x1480 in Object.wait() [0x0000000058cff000]
        - locked <0x00000000814947f8> (a java.lang.ref.ReferenceQueue$Lock)
        at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:209)
        - None
"Reference Handler" #2 daemon prio=10 os_prio=2 tid=0x00000000578b0000 nid=0x1a1c in Object.wait() [0x0000000058bff000]
        at java.lang.Object.wait(Object.java:502)
        at java.lang.ref.Reference$ReferenceHandler.run(Reference.java:157)
        - locked <0x0000000081494838> (a java.lang.ref.Reference$Lock)
        - None
"VM Thread" os_prio=2 tid=0x00000000578ab000 nid=0x1878 runnable
"GC task thread#0 (ParallelGC)" os_prio=0 tid=0x000000000245e000 nid=0x1914 runnable
"GC task thread#1 (ParallelGC)" os_prio=0 tid=0x000000000245f800 nid=0x844 runnable
"GC task thread#2 (ParallelGC)" os_prio=0 tid=0x0000000002461000 nid=0x1840 runnable
"GC task thread#3 (ParallelGC)" os_prio=0 tid=0x0000000002462800 nid=0x1abc runnable
"VM Periodic Task Thread" os_prio=2 tid=0x0000000058d8e000 nid=0x2e4 waiting on condition
JNI global references: 6393
Does anyone of you have any hint what those two teneo threads are good for and why they are not terminating?
Thanks for any hint.
Timo
Re: [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696266 is a reply to message #1696144] Sun, 24 May 2015 15:55 Go to previous messageGo to next message
Hi Timo,
I recently encountered a similar issue in another project I do (outside of EMF). These threads should be changed to
daemon threads. At least I see now that I need to make this change for Teneo. But I checked and the EMF
org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread is already a deamon. So I am surprised that
it also prevents the jvm from exiting.
Can you enter an issue for Teneo? I can easily make this change for the Teneo threads.
Which EMF/Teneoe versions are you using?
gr. Martin
On 22-05-15 13:17, Timo Rohrberg wrote:
> Hello everybody,
> from terminating:
> - None
> at
> - None
> at
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> - None
> Regards
> Timo
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696280 is a reply to message #1696266] Mon, 25 May 2015 04:54 Go to previous messageGo to next message
Hi Martin,
thanks for your reply. You're right: We also figured on friday that the third thread named "EMF Reference Cleaner" is a daemon and should not prevent the JVM from shutting down. So I guess, it's only the two Teneo threads which are not daemons and are waiting for a semaphore. Our analysis revealed that the two threads are scheduled regularly via an Executor and this regular activation is done with a semaphore. However, it seems that the Executor is never shutdown correctly (calling its shutdown method) and thus does not terminate executing these two threads regularly. However, making the threads daemon threads should also solve the problem.
I opened a bug (468151) here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=468151
I am really looking forward for this issue to be fixed.
Thank you so much.
Re: [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696281 is a reply to message #1696280] Mon, 25 May 2015 04:58 Go to previous messageGo to next message
Hi Timo,
As it was a simple change I did it already yesterday evening and published a new build. Can you try and let me know if
it worked?
Otherwise I have to think on somehow calling the shutdownnow method on the service, but not sure what hook I can use for
that (in a webapp there is the context shutdown, but not sure if there is anything for the jvm).
gr. Martin
On 25-05-15 10:54, Timo Rohrberg wrote:
> Hi Martin,
> Thank you so much.
The Netherlands
Re: [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696292 is a reply to message #1696281] Mon, 25 May 2015 06:14 Go to previous messageGo to next message
Hi Martin,
ah yes, I already wondered why there was a new version of Teneo available on the download site. Well, I'm not in the office today due to a holiday in Germany. I'll be back tomorrow and will try it right away tomorrow morning. I'll give you some feedback here, ok?
Thank you very much for your help.
By the way, did you notice my latest reply on the other thread concerning logging with Teneo/Hibernate a couple of days ago (https://www.eclipse.org/forums/index.php/t/1066404/)? Maybe you could adapt that change as well if it is reasonable for others, too - and I guess it is.
Timo
Re: [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696301 is a reply to message #1696292] Mon, 25 May 2015 06:56 Go to previous messageGo to next message
Hi Timo,
Hmm I use thunderbird as email/news client and apparently your reply does not get downloaded or maybe the sync between
the forum and newsgroup is not fine...
In any case I did not see your reply on that one. Seems like an easy one, will check it and solve it.
gr. Martin
On 25-05-15 12:14, Timo Rohrberg wrote:
> Hi Martin,
> Regards
> Timo
The Netherlands
Re: [Teneo] Waiting Teneo Threads Prevent JVM From Shutting Down [message #1696368 is a reply to message #1696301] Tue, 26 May 2015 03:03 Go to previous message
Hello Martin,
I checked the fixed version of Eclipse Teneo/Hibernate and it works now. The JVM is shutting down correctly. From my point of view you can close the bug.
Thank you very much for your quick help.
Timo
Previous Topic: [EMFStore] Detecting changes of operations
Next Topic:[EMFStore][EMF Forms] NullPointerException
Current Time: Sat Jul 19 11:42:26 EDT 2025
Powered by FUDForum. Page generated in 0.04290 seconds
